Question about Roper 24 in. RUD3000 Built-in Dishwasher
Just stopped working
My Roper Dishwasher just stopped working what can it be is there a reset button?
sdmanis@yahoo.com
  • 6,784 Answers
Check the following to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Posted on Jun 11, 2009
Roper dishwasher just stopped working
does it just click when u turn the knob have u not used it in a while put water in bottom of it and leave it the seals dry up and wont let motor start may take a week or so
Jul 04, 2012 | Dishwashers
For a ge dishwasher mod#ghda485nools:on startup mode lights blink and pump turns for 10 seconds then shuts off
00023396.gif small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
transparent1.gif Find a part for your Dishwasher godark_3.gif How Dishwashers work godark_3.gif What is wrong with your Dishwasher? godark_3.gif Email the RepairGuru for help with your specific problem godark_3.gif Maintenance tips for your Dishwasher godark_3.gif Answers to common questions about Dishwashers (FAQ) godark_3.gif Locate your Dishwasher model number godark_3.gif Accessories for Dishwashers godark_3.gif Appliance Recall Information godark_3.gif RepairClinic.com is the web's best resource to buy parts for your Dishwasher and get free Dishwasher repair advice for all major brands of Dishwashers including Admiral, Amana, Asko, Bosch, Caloric, Crosley, Electrolux, Estate, Frigidaire, GE, Gibson, Glenwood, Hotpoint, Insinkerator, JC Penney, Jenn Air, Kelvinator, Kenmore, Kitchen Aid, Magic Chef, Maytag, Modern Maid, RCA, Roper, Tappan, Thermador, Westinghouse, Whirlpool, White-Westinghouse, and more.
Jul 04, 2008 | GE Dishwashers
I have a roper dryer that was working fine than all of a sudden just stopped turning. I've checked everything I know circuit breaker. Does the roper dryer have a reset button???
No, reset button on these. It may be the lid switch or the thermal fuse. This is what I find most of the time. Check out the diagram on apwagner.com and you'll see the parts locations. Oh, if it's not the thermal fuse of the lid switch it may be the timer. I've seen this a couple of times.
Oct 24, 2010 | Roper RGX4634KQ Gas Dryer
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Frigidaire dishwasher pld2855rfc stuck on lower rack, 65 mins, hi-heat temp and sanitize lights flashing
http://www.retrevo.com/support/Frigidaire-PLD2855RFC-Dishwashers-manual/id/1060bh943/t/2/
user manual above.
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
service and repair manual, above is the user manual.
Dishwasher Repair Guide: How To Fix a Dishwasher - ACME HOW TO.com
http://www.applianceblog.com/mainforums/forum17/
http://www.applianceaid.com/dishwash.html
You need to use the service manual, work through, all the procedures, to isolate your problem,and repair. The DIY sites will also help
Also try to unplug and leave unplugged for 5 - 10 mins, and reconnect, this sometimes "Resets" it. Also it may NOT apply, but the Fix below regardless, works, many times, and is well worth a try.
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Apr 25, 2010 | Frigidaire PLD2855RFC Dishwasher
I have a Whirlpool Dishwasher Model #GU240CXTPB1. The normal light won't stop blinking. Tried turning the breaker to reset, but still blinks. No other button works.
Whirlpool dishwasher reset sequence is usually to hit the heat dry then normal then heat dry then normal buttons within 5 seconds and it usually resets.
Mar 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
No power is there a reset button?
Check your circuit breaker or fuse box.
Also, check under the sink. Some models plug in and some are wired in. The plug might have been knocked out. Also, someone may have plugged it into the disposal plug. Try turning the switch on for the disposal and see if the dishwasher comes on.
No, there is not a reset button on a diskwasher.
Are you sure you have no power to the dishwasher?
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Oct 24, 2009 | Roper RUD3000H Dishwasher
Dishwasher stopped working!!
On your unit there is a thermal fuse that disrupts power due to a power spike, over amping heater or just age, the thermal fuse is located in the console clipped to the top of the control board, it's light in color and has 2 black wires going to it. the replacement part number is 8193762 the part runs about $20 or so in cost. good luck hope this helps
Jan 06, 2009 | Dishwashers
DISHWASHER
this is a sign of a defective timer mechanism. replacing the timer will fix this issue. Replace the timer/control model asap.
Nov 03, 2008 | Roper 24 in. RUD3000 Built-in Dishwasher
Roper dishwasher
Here is the link to the user manual if you need it; http://www.roperappliances.com/data/8575997.pdf Page 17 gives all the numbers to call for replacement front panels. here is the link to the installation manual; http://www.roperappliances.com/data/3385181.pdf Page 13 onwards tells you all you need to change the panel. Hope this helps :)
Mar 16, 2007 | Roper 24 in. RUD1000DB Built-in Dishwasher
Roper 24 in. RUD3000 Built-in Dishwasher Logo
328 people viewed this question
Top Roper Dishwashers Experts
Mike
paul
paul
Adzhall
Are you a Roper Dishwasher Expert? Answer questions, earn points and help others
