Question about Roper RAX7244KQ Top Load Washer
Water fill problem
The machine is filling and draining at the same time, and will just continue to try to fill.
    Genius:
  • 1,028 Answers
Raise hose from standpipe standpipe needs to be min 30-36 ins from floor drain line 6-8 ins into stand pipe also standpipe needs to be slightly bigger round than drain pipe to prevent siphoning
Posted on Jul 02, 2008
I have an Estate heavy duty top loader that continually fills then drains and constantly runs water never initiating wash cycle
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
And in some modern washers that come with THERMISTORS:
One symptom of a washing machine that thinks it's overheating and thus fills and drains at same time ( possibly because of a faulty thermistor) is if it's filling with cold water and pumping out at the same time. This is covered in this articleWashing machine fills and drains at same timealthough the same symptom can be caused by other faults.
By the way my advice is free cuz God is good!
Apr 26, 2014 | Estate Washing Machines
Washer continuously fills
Not sure if you mean that it fills all the time and overflows or you mean that it just always fills and never has enough water.
The first problem would refer to a faulty water level switch - need to replace.
The second would be that the washer drains as it fills - if the drain hose is lower than the washer, inspect the anti-siphon valve.
Apr 10, 2014 | Maytag PAV2300 Top Load Washer
Water doesnt stop fillinG in panasonic NA F60A6 WASHING MACHINE
Fyi. All new washing maching already tested on their functionality and features but not test run with water intake and drain function. I would like to share My experience last time with this model. The water outlet valve will release by motor when you set to drain mode.it suppose manage to retract back by spring when drain process finish or afte small you change to wash mode.
Take a look on the spring movement.normally it not properly hold valve switch hence the retracted spring not block the valve to stop water drain. Just rectify the alignment of the valve swich which directly connected to the retractable spring.
Dec 26, 2010 | Washing Machines
Washing machine does not cut off at the preset capacity.
check to make sure your drain hose is positioned higher than the highest water level in the machine, loop the drain hose up higher than the drain and secure it to keep the water from siphoning out.
May 29, 2010 | GE Profile WPRE6100G Top Load Washer
Water runs continuously tub never fills My Fisher & Paykel top loader keeps filling and draining at the same time. It never gets full of water. The hose is way higher than the machine, but still drains...
where is water draining into? have u got grey water hose attached to it?make sure u can see end of drain hose, put into bucket at lid level, if it still drains as it fills u have a faulty control module.please reply for more help
Apr 06, 2010 | Fisher and Paykel IWL12 Top Load Washer
Can not hold wash temps at 150 degress F.? Once filled the resorvior tank stays filled, but water continues to run out main drain?
If it's drain water and filling with water at the same time your drain hose is lower than the water fill line of the washer. try raising the drain hose up higher
Jan 26, 2010 | Hobart 42 in. AM14C-154 Free-standing...
Water continues to fill after it should have
first does it over flow.if not pull your drain hose up from the drain till it is aleast the same level as the back of the waher control panel.
If the Drain hose is to far down in the pipe this will cause the water to drain out by gravity.the other least likely problem is a bad fill pressure switch.
Sep 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer fills, begins to agitate, then drains
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
moz-screenshot.jpgThe washer fills and drains at the same time only on the rinse cycle.
Shut the machine off with timer during this period and raise the drain hose. If the water continues to drain, you will need to install an anti-siphon kit.
Please leave a solved rating before you sign out
Jan 31, 2009 | Whirlpool LBR4121JQ Top Load Washer
Washer fills then drains
Daisy, check your drain hose going into the drain. It sounds like you have a siphoning problem. If the drain hose does not have a air gap the water filling will siphon right out. Check this first and post back, Catriver.
Sep 21, 2006 | Kenmore 98702 Stacked Washer/Dryer
Roper RAX7244KQ Top Load Washer Logo
65 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
