Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Verizon Westell 327w - can't get all devices going
We have a Westell 327W from Verizon. It was WEP with MAC filtering. At some point Verizon upgraded the firmware and now the 192.168.1.1 interface is new (nicer looking, too). The other day, we decided to switch to WPA for better security. But we couldn't get all devices (we have 8) connected. At the 192.168.1.1 UI, under wireless settings --> advanced security settings --> Wireless MAC Authentication, the list of connected devices shows only four items. Other devices are hooked up and working, but not listed. Clicking "Add" to add a new one brings up a screen filled with data, and adding a device seems to remove another one. We tried going back to WEP, but now some devices don't see the router at all. Verizon is no help at all. Can you guys help us with this?
  • douvanjou Jan 05, 2009
    I have Westell 327w and I want to use Wireless MAC Authentication to control any computer in my network through their mac address to allow or block any computer I want. But Westell 327 only give me the option of 4 computers, however, I got more than 4 computers to control. Any help?
    Problem Solver:
  • 6 Answers
I have the same device (Verizon Westell 327w), and same symptoms.  It seems the Verizon firmware only permits MAC filtering for four wireless devices.  The hard-wired connections are not affected.  One solution would be to use one of the connected computers (either hard-wired or one of the four wireless ones) to perform "bridging" or "internet connection sharing" by using a different networking connection.  That is, the "briding" computer might have a second wireless adapter (set to a different channel) to use for "ad hoc" connections to the other wireless devices, or it might have an ethernet port that could be connected to the ethernet port of another device or hub, using a "crossover" ethernet cable (or standard cable with a crossover adapter at one end).
This is an awkward, laborious approach.  The alternative would be to turn off MAC filtering, and use another security system instead, like WEP encryption or not broadcasting the SSID name.  Or, you could try to make the westell device directional, by putting it in the bottom of a very big metal can or pot and pointing the open end in the direction of the units you want to be able to use.  There are many ways to skin a cat.
As a possible extreme, desperate alternative, the westell modem can be flashed to replace the verizon firmware with the manufacturer's firmware.  I would bet that this might make the device unusable for verizon dsl service, though.  I'm also not certain that the manufacturer's firmware permits additional wireless units to be MAC filtered.  Attempting to try this would not be for a novice, and might well turn the hardware into a brick.
Proceed with the above suggestions at your own risk.  I assume no liability for anyone following my hare-brained ideas.
Steve
SteveMDFP4@yahoo.com
Posted on Jun 14, 2009
    Problem Solver:
  • 30 Answers
You need to select the Reset option on the interface, so it reassign news IPs to all the 8 devices. Hope that will helps!
Posted on Aug 09, 2008
I have Verizon DSL service on my Westell 327w. It
whenever the connection drops, is the DSL light blinking?
because, it is just normal for the E1 light to blink, but the DSL light should be solid at all times.
It can be a possible issue with the cable or the LAN card, but you still need to have your line checked by Verizon to make sure that it is not a modem or a network issue.
Feb 21, 2010 | Westell Wirespeed VersaLink...
Switching DSL Modems
Your dsl line stays the same. you're only changing your dsl equipment.
if you are not able to go online using the 327w, you might need to have it configured depending on the type of connection that you have. if you are using PPPoE (which means you enter a username and password on the modem to connect to verizon) you need your 327w configured for pppoe. but if you are using DHCP connection, any modem or routers should be plug and play.
Most verizon customers from the west coast uses DHCP while those on the east coast uses PPPoE.
You can call tech support to make sure which type of connection you are using.
Mar 29, 2009 | Westell Wirespeed VersaLink...
I configured my verizon westell 327W to connect to the internet using an ATT FastAccess DSL connection but when the IE window comes up - i get the verizon activation startup page - how do i get around...
You most likely have to call and setup you mac address with your ISP. There is really no way around this is your ISP requires your MAC address. This is located on your modem. Give them a call and tell them the MAC Address of the Moden and you should be good to go.
Jan 15, 2009 | Westell Wirespeed VersaLink...
My brother just gave me a Westell versa-link model 327w router. there isn't any instruction/opeartor's manual with it. is there a web site with instructions on how to go about hooking this up? Thanx Wayne
The 327w router is distributed by Verizon, an internet service provider. On their website you find tons of info on this model.
Go to the Verizon support page and enter
<westell versalink 327w> in the search field.
Furthermore here some interesting info for you:
Westell versalink 327w Quick Start Guide (700k)
Westell versalink 327w User Manual (10M)
Cheers
Critter
Dec 26, 2008 | Westell Wirespeed VersaLink...
I cannot get my Westell 327w to connect to the internet
Internet light will turn on once you configure the router with your user name and password and once it is authenticated by the server.
Nov 16, 2008 | Westell Wirespeed VersaLink...
Westell 327W & Verizon DSL
I have centrytel DSL and westell Model 327W
Sep 09, 2008 | Westell Wirespeed VersaLink...
Westell versalink 327w i need default password
If the 327 was never set up for wireless you need to connect to it with an Ethernet cable and plug that into your Mac and one of the RJ45 ports on the back of the 327. Type http://192.168.1.1 into your browser, this should take you to the Westell Home Page (Your Router). The default for wireless in this router is disable. There are tabs across the top on the page, select Configuration>Wireless>Basic. This opens the Wireless Operation Window. If Wireless is disabled, click arrow to enable. You can also enable and disable encryption in this same window and if you choose to use the basic WEP in the device, the WEP key is on the label on the bottom of the router. If all this is good your laptop should be able to detect the wireless connection, the default is the serial number on the bottom of the router so you will know which connection is yours. REMEMBER TO CLICK SAVE before exiting the window! Hope this helps.
May 21, 2008 | Westell Wirespeed VersaLink...
Westell 327w
xbox live connection test MTU failed
Mar 12, 2008 | Microsoft Xbox 360 Console
VPN through Westell Versalink 327w
do you have login access into the Modem/Router?
if yes, look for port forwarding and set it to your IP of your computer. open port 500 or what ever is required by MS fro the VPN
Nov 01, 2007 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
818 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
