My hp vs15 lcd monitor goes black 3-5 seconds after power up... i can still barely see the desktop. should i bother with replacing the backlight and or inverter or just go with a new monitor? i'm fairly good with electronics.
    Sergeant:
  • 287 Answers
It does sound like a back light issue. Not under warranty?
The fact that it does light up suggests it may be a heat induced fault? May be just a simple dry solder joint. Although you cannot rule out the CCFL (Cold Cathode fluorescent lamps) being faulty either. A quick check with a meter may tell you if it is the light source or the driver cct that is at fault.
If its the lamps, salvaging some from another LCD may be a good cheap altenative.
Usually there is a simple fault (failed FET/Transistor) causing these problems so if you are good with a soldering iron and can work thru the cct to locate the offending FET/transistor it will be a relatively cheap and easy fix.
Posted on Jul 02, 2008
My hp vs19e monitor has dark screen and blinking power button.
Could be the power module or the backlights (more likely backlights if the "luminance" varies)- $156 sounds a little high but not insane, but you realize cost of replacement is lower, do you not?
Aug 13, 2009 | HP vs15 15"LCD Flat Panel Monitor
Backlight for display cuts out
Bad capacitors are a plague now, most likely cause of the black screen
simply remove the doomed and caps that have color leaking from the top. and replace with duplicate good caps from your local electronics store
Mar 22, 2009 | HP W2007 LCD Monitor
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
Flat panel hp f1503
Most likely you have degraded electrolytic capacitors in the internal power supply. If you can disassemble your monitor to liik at the power supply board you might notice bulging capacitors which if replaced will likely restore normal function.
Mike
May 29, 2008 | HP vs15 15"LCD Flat Panel Monitor
Black screen
Hi
my problem was fixed by viziks from FixYa dated Sep 12
replaced 2 push pull transistors 2sc5707 in high voltage transformer circuit
Transformer used for backlight lamps
Both monitors now working THANKS VIZIKS
Feb 09, 2008 | HP vs15 15"LCD Flat Panel Monitor
RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Sep 21, 2007 | Acer AL2017 20" LCD Monitor
HP 15 in. Flat panel Problem
plug in a different monitor temporarily, check your display settings (right click background, settings, advanced, monitor) and set refresh rate to 60hz. plug in this monitor again and see if that helps some monitors (lcd's especially) cannot handle beyond 60hz
Aug 14, 2007 | HP vs15 15"LCD Flat Panel Monitor
Hp vs15, black screen, power light goes on and off like it is in sleep mode
Monitor is dead. The LCD inverter board probably went out and needs replacing. More than likely, it will cost you over $100 to get it fixed. It's better to spend the money on a new monitor.
Jul 13, 2007 | HP vs15 15"LCD Flat Panel Monitor
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
