Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-52825 Noise issue
I have a 3-year old WD-52825. I've searched the forum but did not see any post with a similar issue. I have a noise that manifests itself in two different ways. On HD channels there are digital artifacts that are about 1-inch across throughout the entire display. On analog channels, there vertical lines throughout the image (similar to an RF noise artifact).
I first thought it was a power issue, or another device (cable box or XBOX) causing the issue. I even suspected a lamp. I've eliminated all of these as possible causes. If I play a DVD on the XBOX, the image is really noisy.
Ideas?
  • 1 more comment
  • mooredriven Jul 02, 2008
    Big Irish,
    Thanks for the response. I forgot to mention that after about an hour the picture starts to flicker. I attribute this to a heat issue. A board or component is breaking down once heating up.
    I tend to believe the caps on the formatter board may be the issue.
    Dale
  • EdP2W Jul 31, 2008
    Mitsubishi WD-52825 Started having video noise and now the Green LED blinks but TV will not power on. Repairman from Sound Advice came out and told me he would have to replace the chassis.
  • Mitsoshitti Oct 14, 2008
    If the flashing green light will not stop. Try plugging it straight into the wall. If the TV does not read it is getting enough power then the green timer light will prevent you from turning it on. As this TV ages for some reason the power supply will give you problems. If you are able to get it back on. Be aware there are a lot more problems to come.
I had the noise issue and the flashing green light issue. Now The picture is not there. It looks like a bunch of flashing stars. If I pull up the device menu I can see in flashing in and out and rolling up the screen. Should I take it out back and beat it with a hammer then hit it with my car or is it worth fixing? This is my 3rd Mits, I can't get one to last more than 3 years. Mitsoshitti.
Posted on Oct 14, 2008
The timer won;t stop
Posted on Oct 04, 2008
  • 927 Answers
Good Day, mooredriven;
If the picture looks like checker board pattern the TV may have a problem with part:
D8F00 PART # 264P828010-diode-DAN202U/MA142W
D8FO1 " " " " "
C8F26 " 141P148000 CER (B25K-1M-K)
C8F29 " " " "
OR the formatter board #930B924001, on that board there are 5 caps 1000 ufd 35v that commonly go bad.
Good Luck, big irish.
Posted on Jul 02, 2008
2008 Mitsubishi lancer radio from loud squealing noise
What is causing that irritating noise? ' DSMtuners
www.dsmtuners.com > ... > Articles: Miscellaneous
Jun 1, 2009 - 2 posts - ‎1 author Check the ECU power relay in the console, under the radio. ... You hear a loud clicking type noise from under the hood when you try to start the car. .... You hear a squealing, grinding, or rubbing noise in the lower timing belt .... The Mitsubishi Eclipse, Eagle Talon, Plymouth Laser, Mitsubishi Galant VR-4, ... LOUD squeak when turning steering wheel (Video Inside)
Mar 5, 2011
Why does my alternator belt squeal so much on initial ...
May 14, 2010
More results from www.dsmtuners.com
Lancer Troubleshooting [Archive] - evolutionm.net
www.evolutionm.net/forums/mitsubishi-evolution-forums/f-203.html
NEED RADIO HELP! ... Help not start Lancer GT 2012 EngineOverheating STOP SAFELY warning on ... AC ISSUES 2011 Mitsubishi Lancer ES · 2008 Lancer GTS no start please ... 2011 lancer no sound · Driver/Passenger side floor squeaky? ... plastic piece of rear shelf rattles a lot · Very loud noise on Lancer ES 2008 ...
Dec 03, 2015 | 2008 Mitsubishi Lancer GTS CVT Sedan
I have a Mitsubishi WD-60738 - about 3 or 4 years old. On Sunday heard a electronic 'popping' noise and TV turned off. When I turn it back on, i get audio, but no video - screen stays dark. Did my
Check and replace the damaged component/s at its main power supply regulator section circuit. The sound you heard might be due to a busted capacitor. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 24, 2014 | Mitsubishi WD-60738 TV
After a power failure, I have a blinking green light on a mitsubishi wd 52825 that won't reset. What should I do?
Install the V26 DM repair kit and The V26 power repair kit. They are both available from www.tvrepairworld.com and also come with the CD with detailed instructions
Jan 09, 2010 | Mitsubishi WD-52825 52" Rear Projection...
Blinking green light for Model WD-52825. What
The usual cause is due to the DM not booting up due to failed capacitors. You can get the V26 DM repair kit at www.tvrepairworld.com which contains the replacement capacitors and the CD with detailed instructions.
Dec 20, 2009 | Mitsubishi WD-52825 52" Rear Projection...
Mitsubishi wd-52825. red lamp indicator, new lamp installed
Failed caps on the power supply will cause that. The V26 Power pwb repair kit will usually correct that issue. Its available from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Oct 30, 2009 | Mitsubishi WD-52825 52" Rear Projection...
Mitsubishi wd-73736 bulbs buzzing noise
The Ballast that ignites the Lamp could cause the Lamp to fail and/or cause a buzzing noise. That being said, the Color Wheel in the Optical Block assembly could also cause a similar symptom. If Mitsubishi would be willing to help with the Lamp cost, I would call a local Mitsubishi repair facility to install it and see if the noise is still there and find out exactly what is causing it. Mitsubishi Customer Service Phone number is 1800-332-2119.
I hope this helps,
Skyassoc
Oct 24, 2009 | Mitsubishi WD-73736 Television
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi Mod. WD-52825 projection tv
9 times out of 10 it is not an easy fix. however ot is not an expensive fix either. checkout www.tv-techs.com
Oct 31, 2008 | Mitsubishi WD-52825 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
304 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
