Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Our garage door will not shut unless you hold the switch down. If you release the switch the garage door will open. Any suggestions?
  • ezmerelda Jul 04, 2008
    what color are the sensors supposed to be? i've got one green and one orange
    Scholar:
  • 91 Answers
Check the photo sensors at the bottom of the garage door tracks, and make sure each sensor can 'see' each other. Normally theres LED lights on them to let you know they are aligned. Both LEDs should be on and not blinking.
Posted on Jul 02, 2008
I have an older craftsman garage door opener that I just replaced the drive gear on. Everything seems to be working properly except that it will not go down unless you hold the button down until it closes...
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Oct 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
The power went out in my area about a month ago. When I came home, I had no way in b/c I didn't have a key since I depend on the garage door all the time. I did attempt to open it from the outside but I...
SOUNDS LIKE YOUR SAFETY EYES MAY BE OUT OF ALIGNMENT OR A BAD CONNECTION.
WHEN HOLDING DOWN THE WALL BUTTON MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
HOPE THIS HELPS
Nov 03, 2010 | liftmaster Chamberlain Garage Door Opener...
Door won't go down unless I continue to hold the button. Once I release the button the garage door goes back up.
Check your door sensors. They have either been bumped and no longer point at one another or one of them has quit. Make sure the small light on each one is lit and not flickering. Tweak them a bit.
Apr 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door won't close unless I hold the button all the way down.
make sure the eyes are clean and aligned if the opener thinks something is obstructing its path it will not close
Oct 07, 2009 | liftmaster Chamberlain Garage Door Opener...
Liftmaster pro 1/2 hp wont shut in one button press
You have a door sensor problem. Either your main light bulb is burned out or you don't have one in your opener. The clicking sound you hear is the relay for the light. Both of the door sensors should have a small light that is lit. Tweak them until they are.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door will not close unless...
Check your down limit switch and even your up one too almost sounds like one is stuck one way or the other.
Jun 19, 2009 | liftmaster Chamberlain Garage Door Opener...
My garage door wont go down.I habe to hold the switch down but if i let it go the door will go up again.
I have a Liftmaster garage door that won't go down unless you press and hold the wall button. The sensor lights are both on. The green light on the unit flashes unless I press the reset button. As soon as you press the wall button it flashes again and the door won't go down unless you hold the button the whole time. The remote wont' make it go down either. It begins to sometimes and retracts, but sometimes the light bulb just flashes (like it is obstructed). I tried replacing the wall switch and that did nothing. Help!
May 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman garage door opener
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE THEY AIMED AT EACH OTHER?
Jul 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Door will not close
the eyes are a little bit out of adjustment
Jan 09, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
160 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
