Question about Roper RGX4634KQ Gas Dryer
Heat to start, then no heat..
The dryer works fine at first. The heating element kicks on and then the gas kicks in and we get heat, after a few minutes the heat element glows but no gas for flame and an occasional buzzing sound comes from i think the regulator... I took the whole dryer apart and ran a cycle to watch the flame or lack there of.
Whats your thoughts
Thanks
Doug
    Genius:
  • 1,028 Answers
Replace both coils on gas valve ..those are the blacks things with wires attached they are bad for not pulling valve oper=n after warm up
Posted on Jul 02, 2008
I have a kitchenaid prestige gas clothes dryer. Model #KGYS677EQ1 . It is producing no heat at all, but it is tumbling fine. Can you please help me figure out the problem?
It could be a few things, but the most common is the heating element is burned out. Un-plug the dryer. Remove the cover to expose the wires attached to the heating element. Take a Ohm meter to test the heating element after the wires are un-plugged.
May 21, 2014 | Dryers
Dryer won't heat. How can I keep troubleshooting?
You may have to get a new heating element when they go out the jet dryer where the heat comes out will not work normally this is caused buy a bad heat element. If not take back panel off and check the little white fuse and replace it, Almost all dryers are the same in that area.. Hope that helps....
May 15, 2017 | Kenmore Dryers
Maytag neptune stacked MLG2000AWW wont heat
It's either the fuse, heating element, thermal cut-off or thermostat
May 20, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
I have an Kenmore 300 series electric dryer and there is not heat. The heating element is fine. Please help!!
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Kitchen Ranges
Heating element went bad in whirlpool dryer replaced it and worked fine for about 10 minutes then it stopped heating. took element back off and it looks fine help me plz
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 11, 2010 | Kenmore 84152 Electric Dryer
Dryer gets hot for the first few minutes only
first check your venting. if you have backed up lint then it will not heat as well. if it's not your venting i would check to see if your heating element is broken and shorted to the casing..some times it will still heat if the coils weld themselves to the casing...if the heating element looks good then i would turn to your electrical.
Jun 16, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag atlantis gas dry is not heating up its about 6 years old
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Mar 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Gas dryer tripping breaker when plugged in.
I have the same exact problem. Dryer works great....when empty. Put wet clothes in and 3 or 4 hours later they are as wet as when I started. I am going to kick the piece of junk to the curb and go get a GE dryer right now.....I suggest you do the same.
Oct 16, 2008 | Whirlpool LGR8648 Gas Dryer
White westinghouse
I have the same AEG T57800 dryer.  Problem, no heat. Couldn't find a service manual anywhere on the net. Checked for fuses and saw none. Thermostats on heater appeared fine, showing current flow. Replaced heating element 112 54 84 41/8, via local dealer - Respond Services from Electrolux UK in Durham DL5 6ED (£68), still no heat.  Called service tech who replaced the PCB - 973916012018008 (£135 + £85 callout charge). Very, Very annoyed at this as the dryer is only 3.5 yrs old.
Dec 11, 2007 | Dryers
Roper RGX4634KQ Gas Dryer Logo
167 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
