Problem with Epson DFX-9000 Dot Matrix Printer
I have an Epson DFX 9000 printer. Error 03 When I
2 Solutions
I have an Epson DFX 9000 printer. Error 03 When I power on I get 5 beeps and Tear Off, Top of Form, Paper Out, Pause and Tractor Select Lights all Flash. Any ideas
  • View Previous Comments...
  • avatar
    flipper_ibp I thought you are an expert. Telling someone to turn machine off and back on. Do yo think that we haven't tried this? Either you are THE EXPERT or don't know sht from gravy. Do you know what is actually wrong
    Dec 17, 2010
  • avatar
    flipper_ibp No new info. Last EXPERT told me to turn machine off and back on again. Not an Expert
    Dec 17, 2010
  • avatar
    flipper_ibp I checked all connectors on the motor control board all solder joints look good. Any further ideas to troubleshoot this
    Thanks
    Dec 17, 2010
331 people viewed this problem
  • 1 person found this problem to be helpful.
  • 0 people are following this problem. Be the first!
More Insights on Fixboard
2 Solutions
This solution has been voted best by the Fixya Commnunity
Hi
Hope you already know that Error 3 is a carriage return horizontal position error and flashes when the printer turns on & the SP Motor Brake signal is not switched on within 3 seconds of it turning on. To solve this issue you should check the SP motor connection, if that is fine then the unit should be serviced. Hope this helps...please post back for further assistance.
Daniel
  • avatar
    Daniel Scott Sorry for the late response, if you have checked the motor control and the connections look good then check to make sure all the wires are fine not burned or broken. If the issue returns then the motor control can be replaced.
    Dec 17, 2010
Shut it off then turn it back on.
Add your solution
Full Name
Top Epson Printers & Copiers Experts
cns assoc
  • Solutions: 677
  • Level: 3
  • Achievements: 1
Anjazmoro Wicaksono
  • Solutions: 500
  • Level: 3
  • Achievements: 2
Edgar Allan Pagayona
  • Solutions: 1447
  • Level: 3
  • Achievements: 1
Expert Badge
Are you an Epson Printer and Copier Expert?
Answer questions and help others.
Users Who Viewed This Problem Also Viewed:
See More DFX-9000 Dot Matrix Printer Related Problems
Loading... Loading...
