Question about Samsung SYNC SGH-A707 Cellular Phone
HELP!!! My phone seems to have a software problem to where the buttons aren't reading right. The "Menu" key goes to the calendar and the "7" key types in a "1" among other problems with pressing keys. I can't seem to get to the master reset through the software itself, is there any other way I can reset the phone? I can't press the menu key or "7,8,9" on my phone
  • 1 more comment
  • MrsKurtonic Jul 02, 2008
    it types in when you press the buttons, they just enter different numbers...
    it works after you leave it alone for about an hour and then it goes back to not working...
    My husband went and short circuited the phone when he got a hold of it... it forced the software to reset in a more manual way and fixed the phone.
  • 983 Answers
I think the keypad sensor is the problem ...
if your good at opening then just remove the handset take off the keypad check the keypad is it in good condition or not ..
if not you replace with the new one ...
& also clear if there is any obstacles in the keypad sensor ...
this will solve your problem .
it cant be the firmware problem so just do this it will be fixed ..
if you are not good at opening then just tap the phone lightly so that if there is any loose contact in the keypad with sensor it may get fixed .... otherwise you must & should open the handset & do it ...
if you are afraid then just visit the technician ...
it is just a matter of some bucks ... i think you can only do this simple thing by opening...
any doubts reply me
i am always here to assist you
thank you
bye
dnt forget to rate my solution
Posted on Jul 02, 2008
  • 2 more comments
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jul 02, 2008
    ya i know this happens when the rubber keypad is teared inside
    so replace the keypad that s all
    or there may be some obstacles check for it first ...
    dnt forget to rate the solution
How do I get birthdays to show up in green on my calendar?
Under the options button you should see "calendars to show" or "enable calendars", click on this. When you see the Birthdays option, there should be a color pulldown menu where you can select the green color. Hope this helps.
Sep 01, 2014 | Samsung Focus SGH-I917 Windows Phone 7...
Tip
Siemens MODELS CODES & DESCRIPTIONS
*#0003*(secret code 8 digits)# All Siemens Phones: Service Provider Unlock
Siemens S25/C25
SP unlock *#0003*(secret code 8 digits)#
Show IMEI code: * # 06 #
Resets language to automatic selection : * # 0000 # then Green button
Pin Out
Data Cable schematics
Phone's connector pin-out:
1- GND
2- SB
3- POWER
4- NC
5- TX
6- RX
7- CLOCK
8- DATA
9- GND MIC
10- HF MIC
11- AUDIO
12- GND AUDIO
Siemens S1/S3/S3 Com
To view the software date and else with S3 com, S4, S4Power, Sony cmdx 1000e press with SIM removed *#06# and left softkey.
To view some other stuff with S4Power, Sony cmdx 1000e press with SIM removed *#06# and left softkey twice.
To view the software date with S3 com, S4, S4Power, Sony cmdx 1000e press with SIM installed menu 98 and left softkey twice.
ACTIVATE MONITOR MODE
Siemens S1/S3
Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 5553756, Hang-Up Button (Red Handset key)
Siemens S3 COM/S4
Menu, 9 (Phone Options), 7 (Phone Status - 8 on Some), Left Display Button (left MENU key), 7684666, Hang-Up Button (Red Handset key)
Note: Now Monitor should appear at the bottom of the Network Options menu.
MONITOR MODE
Pressing the right Display Button when in monitor mode will toggle into 1 and 2 modes
Pressing the right Display Button when in monitor mode will show a list of the six cells with the strongest signals.
Test Mode Indicators: (* = only available when call in progress )
CH Channel Number
RX Signal Strength (dB)
N NCC (Colour Code)
B BCC (Colour Code)
CI Cell ID (in Hex)
C1+ How long before phone does forced hand over. (see RX and RXAM)
LAI Location Area Identity. Display Network ID code (42F010 = 240.01) and MSC
TXPWR Transmit Power (dB)
RXAM Receive signal strength cut-off point
TS* Time Slot Number
TA* Timing Advance. Distance from tower in Km X 2
PL* Power Level
POWER table
PL: 5 6 7 8 9 10 11 12 13 14 15
dB: 33 31 29 27 25 23 21 19 17 15 13
Watts: 2 1.3 .8 .5 .3 .2 .13 .08 .05 .03 .02
LF* C1 value with continuous transmission from tower
LS* C1 Value with discontinuous transmission from tower
QF* Bit Error Rate with continuous transmission from tower
QS* Bit Error Rate with discontinuous transmission from tower
BER (bit error rate) table
QF/QS register: 0 1 2 3 4 5 6 7
% of bit sent: 0.2 0.8 0.4 1.6 3.2 6.4 12.8 25.6
Siemens S1/S3
Here's a trick to play Tetris, also known as Klotz on a Siemens S1.
Turn the phone on. Enter PIN. Before the telephone has logged in to the your GSM net do the following steps.
1: Choose F 9 (function settings)
2: Choose send own number and push the right button for choose.
3: Push 9
USE 2 as < and 8 as > , rotate the klotz with 5 and drop with 4.
[I have just heard from one of the programmers of the phone that Tetris was in the phone during development, but it was removed before it was produced. Apparently someone has the patent on games in mobile phones and Siemens didn't want to pay the licensing fees. It was either in Menu F-9-9 or it's not there at all.]
Siemens S3 Comfort
MONITOR MODE
The Siemens S3 Com series have a Monitor mode that can be activated directly from the standard user keypad. In order to activate this mode, you must enter the special access code currently programmed into the phone.
TO ACTIVATE MONITOR MODE:
Turn the phone on.
Enter the PIN access code on press OK. (Only if is enabled).
Press Menu. (Left top button).
Press 9. (Phone Options).
Press 8. (Phone Status) (May be button 7 in some phones).
You may see your IMEI Number
Left Display Button (Top left MENU key).
7684666
Hang-Up Button. (Red Handset key).
Note: Monitor should appear now at the bottom of the Network Options menu.
MONITOR MODE
Siemens S4/S4 Power
In phonebook under "Own Phone No." enter +12022243121 (which is the number to the White House) and you'll get a greeting from the people who programmed the phone.
MONITOR MODE
The Siemens S4 series have a Monitor mode that can be activated directly from the standard user keypad. In order to activate this mode, you must enter the special access code currently programmed into the phone.
Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 7684666, Hang-Up Button (Red Handset key)
Now "Monitor" should appear at the bottom of the Network Options menu.
CH Channel Number
N NCC (Color Code)
B BCC (Color Code)
CI Cell ID (in Hex)
C1+ how long before phone does forced hand over. (see RX and RXAM)
RXAM Reeceive signal strength cut-off point
PL* Power Level
Power Table
Siemens S6/S10
In Phonebook, store as your own number: +12022243121
Then you get the sun and two palms in the display, also a greeting message of the "MMI-team".
It has been said that the phone number is the number of the Capitol building in Washington, DC (but not sure).
Siemens S15 Secret Menu's
Press * -> # -> 7 -> 4 -> 3 -> 6 -> 3 -> 6 -> 7 -> * -> 8 -> 3 ->
7 -> 8 -> # ,press clear key to clear screen and return to
stand-by mode
press Menu, it will show additional menu
Menu 3.3.4 Band selection,
Menu 3.3.4.1 Automatic band selection,
Menu 3.3.4.2 select GSM 900 only,
Menu 3.3.4.3 select GSM 1800 only,
Menu 10 Engineering,
Menu 10.1 MS info,
Menu 10.2 software detail,
Menu 10.2.1 software version,
Menu 10.2.2 EEPROM version,
Menu 10.3 Test/production details
Menu 10.3.1 Hardware deta
Menu 10.3.2 production deta
Menu 10.3.3 Service deta
Menu 10.3.4 Mechanical deta
Menu 10.1.1 MS info on, then on the screen show these, for example:
FCN RXL C1 C2
642 011+11+91 -> PAGE 1
CID DSC CB
11211 045 000 -> PAGE 2
BCC NCC TN
000 002 00 -> PAGE 3
RXf RXs RQf RQs
00 00 00 00 -> PAGE 4
ATa APa Hn Hf
001 000 05 00 -> PAGE 5
DTU DTD HP CI
+ ? - - -> PAGE 6
MM CC RR
IdNS Nul Idl -> PAGE 7
on Aug 30, 2009 | Nokia 9500 Communicator
W902 Sony Ericsson. My Walkman button and my volume up wont work properly.. i'we already opened up the phone and cant seem to find any damage or visible faulties on the buttons. They seem unharmed and they...
Seems like a known issue with the W902. Same here, dropped my w902 a few months back and the Walkman button and Volume up keys not workin now.
Walkman button not really an issue as you still can navigate to it via the menu system but no volume UP key is annoying. You can't increase volume especially when you volume it down. Power the w902 down and up, will reset volume to 6/10.
Solution: I came across a site where you can change volume without the volume up key.
1. Ensure you lock the phone (* and Contact key)
2. While holding down the disconnect button (the one that you switch the phone off) and camera button (on the right side, bottom button), pressing 7 will decrease volume while * key will increase volume.
You need to hold both button for 7 and * to work. Works great for me as I dont have to replace my phone, hope this help.
Ronnie
Sep 21, 2010 | Sony Ericsson Walkman W902i Cell Phone
I have a samsung gt-b3410 and i cant creat an alarm for a birthday
Manage your calendar Learn to change the calendar view and create events. Change the calendar view 1. In Menu mode, select Organiser → Calendar. 2. Select View by → Day or Week. Create an event 1. In Menu mode, select Organiser → Calendar. 2. Select Create → an event type. 3. Enter the details of the event as required and select Save. View events To view events of a specific date, 1. In Menu mode, select Organiser → Calendar. 2. Select a date on the calendar. 3. Select an event to view its details. To view events by event types, 1. In Menu mode, select Organiser → Calendar. 2. Select More → Event list → an event type. 3. Select an event to view its details.
but if u want the thing u specifically asked for http://www.getjar.com/mobile/25220/birthday-reminder-for-samsung-gt-s5233-avila/?s=phones
Jun 15, 2010 | Cell Phones
How do i set my autosignature ?
ok on cingular/at&t its not possible but there is a ghetto way of doing it go to ur quick notes and go down 4 lines then type what u would want as your autosignature then when u get done typing ur message press insert>then go to quicknotes then choose what u wanted as ur autosignature then send.
Jan 28, 2008 | Motorola Mobility RAZR V3
Buttons on my J600 seem to be mixed up
As per symptoms it looks like keypad IC fault or CPU falult. But it is true it is hardware type of problem and should be treated by skilled technician. It is not advisable to try if u r not skilled.
Dec 30, 2007 | Samsung SGH-E900 Cellular Phone
Keypad troubleshooting
when I open my phone it seems to be stuck on the right arrow button so it goes to "IM account". I was really confused this morning because even if I click exit, it goes back to the same thing on its own. when I get a chance to press menu, it just whirls around as if I'm pressing the arrow over to choose a category but I'm not.. its weird.. probably the weirdest phone I've ever had
Sep 23, 2007 | Motorola Mobility RAZR V3
Samsung SYNC SGH-A707 Cellular Phone Logo
43 people viewed this question
Top Samsung Cell Phones Experts
Fotis Papastamatiou
Bill Long
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
