I recently moved into a new office and was given a pc, but I am unable to boot up as the previous user set a black screen password...what should i do??
    Sergeant:
  • 287 Answers
Sounds like it may be a BIOS password, when you reboot do you get any thing on the screen? is there an option to "press DEL to enter setup" or similar?
If so go into the BIOS and see if the password can be reset or removed there.
If it is a bios p[assword, you may be able to clear the BIOS by removing the BIOS battery whith the power OFF
Posted on Jul 02, 2008
Enter system password
Which operating system ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
or
Click "Start," then select "Run." In the text box displayed, enter "control userpasswords2" and press "Enter." This opens a configuration window.
Click the user for whom you want to disable the password login.
After selecting the user, remove the check mark labeled "Users must enter a username and password to use this computer."
Click "Apply."
A dialog box will prompt you for the password.
Enter the user's password to authorize the changes and press "OK."
Reboot your Windows XP computer.
When it shows the list of user profiles, click the user whose password was disabled.
You should be able to log in without a password.
Jan 22, 2014 | Dell Dimension 5100 (D51L1) PC Desktop
Wont start i go to safe moode it dont work f11 asking for pass word
Which operating system ????.....
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
http://wiki.ljackson.us/Control_Userpasswords2
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Oct 14, 2013 | Medion M3 Composer 5100 PC Desktop
Cannot bypass first password
At boot hit f8 boot in safe mode and then go to control to user accounts.If you cant change your user password make a new user or use Hiren's BootCD to unlock any user passwords on that system.
http://www.hirensbootcd.org/download/
http://www.ezsystemrepairs.com/ Live Tech Here !
Nov 09, 2012 | Dell Dimension XPS 400 PC Desktop
Forgot my acer laptop password
During the boot up process you will see on the screen press a certain key to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
hope this helps
Nov 02, 2010 | HQRP AC Power Adapter Battery Charger +...
I was given a compaq computer running Windows XP. It boots up to a previous user and is looking for that user's password. How can I reset password or access administrator account?
I would suggest you to try the following :
Boot the computer in safe mode.
Press F8 while booting the system, It will give you Windows Advance boot option, Select Safe mode and press Enter. You will see two accounts, Administrator and the Previous User's . Select the Administrator. If it allows you to log in, go to control Panel, User Accounts and delete the previous user's account and create a New user with your name. Reboot the computer in normal mode.
Hope this works. Please let me know if you need further Assistance. Your comments and ratings are highly appreciated.
Thank you for choosing Fixya
Oct 14, 2009 | Compaq Presario S6000CL (DT072A) PC...
Unable to login to laptop due to forgotten login password
First thing you can try is:
1: When booting up the laptop Press F8 until you see a screen show that has an option to boot in "Safe Mode"
2: Once it has finished booting up you can Select Administrator and hopefully there is no password set.
3: If there is no password set then login as Administrator and goto "Control Panel", Select User Accounts and change your daughter's password to something she wont forget ;p
if that fails then you can try this
http://www.lostpassword.com/
Offers a program that resets your passwords.
Hope this helped.
Apr 12, 2009 | Computers & Internet
Previous user apparently password protected Windows.
Well first off you can use the restore feature and it will only reinstall crucial windows files it won't mess with software that was already installed.
There are password recovery programs out there you would have to search for one and install the program onto a disc and boot of it (just follow the instructions)
Jan 04, 2009 | Acer Aspire AM1640-U1401A Desktop PC
Password
see that is little bit difficult for you bcoz you need to reset the bios bcoz it is startup password and which is set in motherboard bios. what you can do is just show it any service repair pesonnel and they will reset it. bye
Oct 10, 2007 | ASUS A3H Notebook
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
