Question about Microsoft Xbox 360 Console
Tray won't close - Microsoft Xbox 360 Console
  • 839 Answers
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Posted on Dec 17, 2010
SOURCE:
CD drive won't close
If the CD tray won't close then it's probably a mechanical issue with the drive and needs to be replaced.
May 07, 2013 | Dell Inspiron 530 Desktop Computer
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
The dvd tray on my Sony BDV-E780W won't stay closed. Whenever I turn it on the tray opens and wont close from the remote or device.
Have you checked to see if it is off track? Sometimes when these machines get bumpbed, dropped, or fall they can jump track. You have to take the cover off and inspect to see if it is off track when it closes and opens. It should go all the way back on the track when it closes. Be careful not to shock yourself. If it is on when you do it and your hand touches the metal parts inside you can get seriously burned or shocked.
Dec 01, 2012 | Televison & Video
Problem with the tray.it is not working properly and cant come out
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual
God bless you
Sep 27, 2012 | Philips DVP-3005 DVD Player
Problem with the dvd tray
God bless you
Sep 27, 2012 | Televison & Video
Cd tray won't close
Use a can of compressed air to clean out any dust or dirt, if that won't work! gently pull all the way out to see if anything is catching, if the tray is stiff to move it is out of alignment. Have a computer shop take a quick look at it, may need to be replaced.
Apr 12, 2012 | Computers & Internet
My 360 kinect won't read disks. It says open tray,
my x box 360 Kinect want work because when I put the game in it said open and close the tray
Apr 08, 2012 | Video Game Consoles & Games
Tray won't close fully then pops open again what needs to be done.
Hello
Its loading mechanism has the fault. It must be replaced. Check its loading belt, before replacing the loader mechanism.
Picture of the loader mechanism is given here.
http://www.dataentryjobs.us/67948.html2_28_2012_4_54_10_am.jpg
Feb 27, 2012 | Sony DVP-NC600 Multi-disc DVD Player
Ashtray in my 2005 Kia Amanti Stays open
It sounds like the spring mechanism on the tray is either bent or broken. You can try removing the tray and bending the spring steel to increase the friction or you may have to purchase new or used ash trays.
Nov 23, 2011 | 2005 Kia Amanti
Paper tray 1 on my aficio 1232c won't close. It keeps getting caught on something.
Hello!
I advise you to take the all tray out and take a look inside. Probably it have any obstruction on it.
Sep 01, 2011 | Ricoh Aficio 1232C Color Copier
Microsoft Xbox 360 Console Logo
656 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
