SOURCE: Whirlpool 465 super capacity burner not working
I am having a Whirpool 465 gas stove for 8 years with 3 top burners do not work - burn but with very low flame. Please provide suggestion to repair - remove the burners and replace them?
SOURCE: 2 of 4 burners ignite, all tick?
The two front burners are used most often. On the side of the burners are tiny holes that become plugged and keep the burner from lighting. If all the burners are the same size try swapping the heads around. If they are not all the same size be sure they are in the correct position and fully seated on the top. Sometimes the heads have to be replaced when cleaning no longer works.
SOURCE: stove top burners won't light
Take a fine file and file the igniter tips and where the spark connects to the burner head. The ignitors get a buildup on them that doesn't allow a clean bright spark. If this doesn't work then you will need to replace your spark module which sends the voltage to the ignitors. Good Luck, Appliance Specialists
SOURCE: Whirlpool Super Capacity 465 Electric. Left Front
there are 3 screws under the front of the top with the oven door open actually there are 6 screws but only 3 you need to remove to raise the glass top up!! to service the burners
