Question about Avaya 6408D+ Answering Machine
Will the analog line card(TN2215) will work with CM3.1.2?
Please do not quote me, but I beleive it is for the Older Definity systems. But Please call for a second opinion.
Posted on Jul 03, 2008
My land lines are working but all my handsets say check tel line...no dial tone or response. Batteries are good according to tester. Anything I can do??
ck the red and green wire that goes to the system those 2 make the phones work just do the main main phone first , , it does not sound like the phones are broke you are not getting a dial tone due to no connection to the line itself
Dec 10, 2014 | Panasonic Kx-tga641m/kx-tga641 Cordless...
IS THE PANASONIC EASAPHONE KXT 2395 A DIGITAL PHONE?
It is an analog phone with some (digital) electronic circuitry for extra functions such as redialling.
Therefore I would answer: no.
May 10, 2014 | Panasonic Easa-phone model Kx-t2395
Can this machine work with 2 line phone?
Generally answer machines don't answer more than 1 line , you would need 2 machines f 1 for each line
Jul 11, 2012 | GE 29875GE Digital Answering Machine
Hi,i'm using wireless sharedphone that uses a sim
yes, they are called GSM gateways, they can use your SIM card for your GSM provider to connect any analog telephone, or device...
http://www.gsmsave.com/
there are also bluetooth gateways, that you can use for any bluetooth cell phone (GSM, CDMA, iDEN, etc...) and connect to an analog telephone, or other device...
Mar 21, 2012 | Lands Phones
Phone has crackling noise when speaking to people
It can be due to line available or from the service provider side or due to some loose connecting in your phone.
Check the phone line with a new phone and see everything work fine or not.If work fine,the fault lies within your phone machine get it repair to a phone mechanic. If the problem lies with your phone line,you can always called the service provider and get the line check for error.
Note : When phone tapping is done,the caller and the receiver hear cracking noise too.
Dec 21, 2009 | British Telecom Lands Phones
I have EL 42108 cordless phone and ans machine with call waiting. when using it stars to hVE STATIC AND FINNALLY SO MUCH CANNOT HEAR OR TALK. HAVE TO HANG UP PUT ON BASE AND WAIT AWHILE ALL THE HONES...
Couple things can cause this. First make sure that your phone line is clean, test it with an analog line. Then check for EMI and other radio interference by moving the wireless station as close to the base station as possible, if the problem goes away you know it is either your antennae or local interference. Next you can try changing the channel your broadcasting on, either the menu system should allow you to choose a channel or it'll be a switch somewhere on the unit. Finally, make sure that the speaker is not damaged or blown.
Dec 03, 2009 | AT&T 1717 Digital Answering Machine
My answering machine is cutting off callers after 10-12 seconds
dude??? for real??? you still have an ansering machine??? well, thats ok i guess. is it digital or analog??? if analog try changing tapes, or maybe erasing old messages. if its digital then i would chunk it and get call notes or get a caller id box an dscreen your calls. better yey just get rid of your home phone service and get all your calls on a cell phone...... much cheaper and more convienient.!!
Jul 15, 2009 | Southwestern Bell FA-970 Digital Answering...
Fax and answring machine on same line
I assume you have distinctive ringing since both numbers are on the same line. According to the manufacturer's specs, the fax machine supports distinctive ringing. Set it up for the ring pattern assigned to the fax number and to answer on the first ring. Then it will pick up right away when someone calls the fax machine, and the answering machine will pick up the other number.
Nov 19, 2008 | AT&T (1718B) Digital Answering Machine
Swatch TDA03-1US Answering Machine
try putting 01 into your analog phone after you have put in your 3 digit pin code
how do you put in your pin code we have lost our operators manual
Jan 16, 2008 | Swatch TDA03-1US Answering Machine
Parasonic auto-logic answering machine
Hello, yes it sounds like your trying to connect a "analog device" to a "digital" telephone. If you wish to connect the answering machine to answer your line or lines, you should contact your facilities maintenance department and see if they can "hardwire" your telephone line (your primary phone number), to another jack in your office so your answering machine will work by being placed in "parallel" with your phone system and your primary phone number. If you have more than one phone line (number) you wish for the machine to answer, you will need to ask for a "analog extension" from your digital phone system and have it programmed to ring when any of your roll over lines ring. However, keep in mind the machine can only answer one call at a time, the other simultaneous callers will get a ring no answer until the first caller has hung up. Good luck, hoped to help. CG
Jan 07, 2008 | Panasonic KX-TM150B Digital Answering...
Avaya 6408D+ Answering Machine Logo
51 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
