Question about Nikon Coolpix S51c Digital Camera
Nikon Coolpix: indicates that the card is write protected - which it is not..
When i switch on my Nikon Coolpix s51c it shows the card is write protected . I have tried to change the memory card - same problem persists. The camera works fine with its small internal memory. Is there any way to reset it? Any suggestion?? Thanks!! Eva
    Master:
  • 638 Answers
Its not the card problem nor the device problem .just adjust the switch and mode properly.a camera shop can do the adjustment free for you .
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jul 02, 2008
  • 105 Answers
Rest the camera to the default and try
  • 13,433 Answers
Make sure the small switch in the memory card is set to the right position.
Let me know how it turns out.
  • 3 more comments
  • Ekse Jul 02, 2008
    (Try both)
  • Ekse Jul 02, 2008
    Theres a reset all function in the camera - setup menu.
  • Ekse Jul 02, 2008
    Also, take out the memory card, plug it into your pc and format it.
    open my computer - right click on the memory card and select format. Fat 32 I beleave. defaults settings - format.
    Try it again on the camera.
  • Ekse Jul 02, 2008
    ok, take the camera to nikon for service, do you have warranty on it?
    Or you can take it to a local camera shop they can look at it or direct you to someone.
  • Ekse Jul 02, 2008
    when you take it in for service remember to take the memory card with you so they can test it and make sure it works.
    Let me know if you need anything else.
    Thanks,
    Ekse
What is mesage "memory card write protected " in nikon coolpix4500
It means that the camera 'thinks' that the Memory Card in the camera has been switched to 'Write Protect ON". If there is no Camera Menu Item to override this function then remove the memory card from the camera and check along the edge. You should find a small black or grey slider button that will move. Hopefully it will be labeled for Write protect ON and OFF.
Reinsert the adjusted card and see what happens. If the error persists then try another card. This link might help:
Good luck.
User Manual Coolpix 4500 Guide to Digital Photography Nikon Knowledgebase
Mar 02, 2015 | Nikon Cameras
My nikon coolpix digital camera s51c say memory card is write protected... and will not let me go to format card... what do i do... pls help
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 09, 2012 | Nikon Coolpix S51c Digital Camera
Memory card is write protected as my nikon coolpix screen shows and no any option is getting for picture click
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 24, 2012 | Nikon Coolpix 4500 Digital Camera
I have a nikon coolpix and says memory is write proteted how can i get it to work with out this?
Take a look at the memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 05, 2010 | Nikon Coolpix S51c Digital Camera
My camera is saying that my card cannot be used ( sd card) I erased the pictures on it and still it comes up with that. last time I used my camera it worked fine. What do i do?
Try formatting the card in the camera using the camera's format feature located in its menus. If offered "low level" format, select it. Note that this will also totally erase the card, so do this only after you're certain that all needed photos have been backed up to your computer.
Dec 02, 2010 | Nikon Coolpix S51c Digital Camera
MY MEMORY CARD IS WRITE PROTECED MY CAMERA WONT WORK
Remove the memory card from the camera. On the side of the card, there is a tiny button. Push it to the other side of the tiny groove on which it sits. Voila your card is no more write protected. If you are still lost, let me know.
Sep 01, 2009 | Nikon Coolpix S51c Digital Camera
Nikon coolpix s51 digtal camera memory card says can not be used?
hi..
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
You need to unlock the card itself. Take it out and look for a tab on the left. It should be pushed up.
thank u
rate me
Jul 22, 2009 | Nikon Coolpix S51c Digital Camera
My nikon camera coolpix 1600 memory card is write protected. Plea
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
Apr 28, 2009 | Nikon Coolpix S51c Digital Camera
SD cards have a slide switch along one edge. Slide it away from the contacts.
Nov 21, 2008 | Nikon Coolpix S51c Digital Camera
I have a nikon coolpix s51c digital
Jun 19, 2008 | Nikon Coolpix S51c Digital Camera
Nikon Coolpix S51c Digital Camera Logo
82 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
