Question about Video Game Consoles & Games
Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
  • 287 Answers
To make a router connection to Xbox Live:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console with no disc in the disc tray.
  8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
Posted on Jul 02, 2008
I cant get internet from my rouder
Wired or wireless? Shut down the computer. Unplug the NetGear. Unplug the ISP modem, remove battery, if applicable, Check ALL cables and connections, reseat ALL connections. plug in the ISP modem, wait for selftest. Plug in the NetGear, wait for selftest. Reboot the computer. Try connecting with a Ethernet cable if you are trying to connect wirelessly to verify. If that fails, contact your ISP to verify signal comming in. Have a ISP tech come out to analyze the signal.
Jan 06, 2013 | NetGear Computers & Internet
My router is not obtaining an ip address through WAN port. I use my rouders WAN MAC Address to identify my rouder to my ISP provider. I can see this MAc address under Internet Connection on the rouder...
Try using the MAC address of the ethernet adapter and clone it to your router. Your ISP might be recognizing the MAC address of the LAN card of the computer.
To get the mac address of the computer go to the command prompt and type ipconfig/all.
You may also need to contact your ISP to clear arp in their end, so that they will detect that you have a router. I hope this helps!
Feb 12, 2010 | Computers & Internet
My ethernet was working fine utill it stoped lighting up
try starting your xbox up with out the hard drive play a game for a little while. and plug your drive back in. This is a hard drive problem. But remember the xbox has 4 memory chips that keep info even when you shut it off.
Aug 03, 2009 | Microsoft Xbox 360 Console
For some reason you can only have the component leads with optical cable, if you put hdmi cable in there is no connection for the opticle cable out.
Jun 10, 2009 | Microsoft Xbox 360 Console
Can't join into party
That happened to me once. You should check the wireless device or your ethernet cable( whichever one your using ). If your ethernet cable isnt plugged in on the way it will only let you log into xbox live and that may be it. Lastly try resetting your router and make sure all the wires are plugged in good.
Also Check your NAT settings. If your trying to connect to a friend, You or your friend most probably do not both have an OPEN connection. To find out if you do or dont, go to your xbox's network settings and run a test, if it comes up with a "More Information" button click it, and it will tell you what type of NAT, your xbox is set too. However if it does not come with a More Info button, then your xbox is OPEN.
Make sure both you and your friend do these tests.
If one of you is not OPEN, then you will need to either open some ports up or turn on DHCP and UPnP. But I wont go into detail until you've done the test.
Hope this helps.
May 24, 2009 | Microsoft Xbox 360 Console
Hello my name is steve
1. Make sure the Cable is properly connected to the back of the Xbox.
2. Make sure the Cble is properly connected to the inputs on the TV (Color coded if using component or composite cables).
3. Look on the large part of the cable where it plugs into the Xbox. There is a switch with two settings: HDTV and TV. If using the component cables (Green, Blue, Red + White Red), turn the switch to HDTV. If using the composite cables (Yellow, White, Red), switch it to TV.
4. If the problem persists, contact Microsoft at 800 4MY - XBOX . It's a toll free number but it isn't 24 hour.
plz Rate"
Dec 17, 2008 | Microsoft Xbox 360 Console
Xbox live wont log on
chek if your ethernet cable fine or your wirless connection isnt that cood easily be the problem but other wise just run an intial set up a few times it shood work...
Nov 15, 2008 | Microsoft Xbox 360 Console
hi. about that, 1 question, is your tv non hd? if not. you can do almost anything on psp to the tv wit that, but not games. to play games, you will need to use a hd tv and another type of cble named. psp component cable.
you need those to two to play psp to the tv. what a drag isnt it?..
Aug 03, 2008 | Sony PlayStation Portable (PSP) Console
Can not connect to xbox live
Using a wireless USB device for xbox live isnt supported. Try connecting through a modem.
May 17, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
297 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
