Please update the drivers and firmware on the printer. Then, you can restart both the printer and the GPSu21 device before attempting to print again. Thank you.
1) Try to restart you system with the printer unplugged.
2) Try to Pause the printer and then delete the items in the que
3) If this doesn't help Delete the printer and re-install it.
you may need to turn off your print services on your pc. pull up the printer que on the pc. delete the jobs in the que. right click my computer. go to mange. go to services and applications .go 2 services. double left click. look for print spooler. right click. choose stop. then go to printer and reset job. turn off printer. turn on printer. restart your print spooler. close all windows and try to print
Envelpopes should be printed using the feed tray located in the front of the printer not through the paper cassette. Try this:
Follow these steps to print on envelopes from a computer running Windows.
NOTE:
For specific details on formatting text for printing on envelopes, consult the help files in the word processing software. For best results, consider using a label for the return address.
Click File , and then click Print .
The Print dialog box opens.
Depending on the software program, click Properties , Options , Printer Setup , or Preferences .
The printer Properties dialog box opens.
Click the Paper/Quality tab.
Select Envelope as the paper type.
From the Size drop-down list, select the applicable size. To create a custom size envelope, use the following steps:
On the Paper/Quality tab, click Custom .
Click in the Name text box, and then enter a name for the custom envelope size.
Click in the Width text box, and then enter the width.
NOTE:
Make certain the size is in inches. Click the Use Millimeters/Use Inches button to toggle between using millimeters and inches to define the custom paper size.
Click in the Height text box, and then enter the height.
Click Save .
Click Apply to save the settings.
Click OK to print the envelopes.
NOTE:
An error message might display asking to load an envelope into the manual feed tray. This might occur even if the envelopes are loaded. Make sure the envelopes are loaded, and then click Continue . The product will continue printing from whichever input tray contains the envelopes.
you are installing the drivers may be not correct. u remove the printer driver and install the proper driver again otherwise it may be spooler problem then u have to reinstall the os and configure printer dirver
Click Start - Printers and Faxes - Open the Printer - on the menu Printer click and select cancel all documents, and also press the cancel button on the printer, turn off the printer and Restart your system, turn on your printer again while you restart your Computer.. Now you'll see there's no more print queue .. Good luck...
Firstly turn the printer off and leave it off for a few mins. This should clear the buffer.
If not then can delete the printer "from control panel", restart PC and then re-install the printer....but make sure you have/can get the driver for the printer first!
Does it show "Printing" or "Spooling" in the job queue window?
Open the Job queue window, then highlight and cancel the print job. Send a small print job to the printer and make sure that the PC and the printer are communicating.
If the failure re-occurs, then clear the queue again and close it and restart i=the queue.
