Hi there, i have a philips 37" lcd tv, model:37PF7320/79.When i switch it on the tv swiches itself off and on also a clicking sound can be heard (coming from the power board), ive also noticed the main board with all input plugins has a green led light blinking on and off also.Now ive managed to stop this wierd behavior by timing the clicking and pressing the programme or power button to make the tv stay on, but the screen doesnt power up and the sound for a tv channel is very faint, but the led on the main board is still blinking on and off, PLEASE HELP !!!
  • vitto187 Jul 02, 2008
    Hi there, i have a philips 37" lcd tv, model:37PF7320/79.When i switch it on the tv switches itself off and on also a clicking sound can be heard (coming from the power board), ive also noticed the main board the one with all input plugins has a green led light blinking on and off also.Now ive managed to stop this wierd behavior by timing the clicking sound and pressing the programme or power button to make the tv stay on, but the screen doesnt power up and the sound for a tv channel is very faint, and the green led on the main board is still blinking on and off, PLEASE HELP !!!
    Master:
  • 638 Answers
Its the power supply problem
it is very common in lcd tv,
they are repairable ,check whether any bulged capacitor is seen on the board ,replace it ,if not familiar with soldering do not try to do it your self a local technician can do this the cost will not more than his service charge.
feel free for further assistance rate the solution as fixya if this helps you to solve your problem.
Posted on Jul 02, 2008
    Genius:
  • 1,665 Answers
Following comment found helps.
Most LCD faults experienced are of two types
1 Dead (Psu faults)
2 Display Panel Faults
1 Dead NO pic or Snd
Some have external power units, the ones with a 4pin plug are usually the fault
even if they measure +12v coming out, test by substitution
The Psu are Just like any Psu using SMPS(chopper), so use normal PSU fault finding techniques
Start with , Any power from secondary of chopper transformer, at the diodes)
usual PSU voltages are 5v,3.3v 12v (the 12v feeds the CCF tubes power generators)
If yes the psu ok, If no check for 320v across mains smoothing capacitor
If 320v ok but no output, check for shorts on the output lines (schottly diodes)
If the PSU is running and there are any leds glowing on the front
check to see it the flurecent tubes (on each side) are glowing
they usually have their own supply generators powered by 12v from PSU
Ps anyone know where to get:- schottky 120v 10a double diodes t220 case or similar?
2 Display Panel faults
Vertical (source) faults are usually within the actual panel (Lines/Bands down Picture)
Horzontal (gate) faults are unually within the actual panel (Bands/Lines across the screen)
All faults that are within the panel aren't repairable (I know specialist repairs are possible , But the COST)
there is a firm calle D'lec why not ask them for a price
Permanant Missing or Lit spots are often found , and are normal (most screens have a few)
For actual usual faults check my online database for your actual make/model (if any)
  • 790 Answers
Hi
This power oscillaion trouble! vitto187 if you have experience in electronics repairing i cant teach you how to fix this problem... the problem is the oscillation circuit thats why the power on and off....
Thanks!
  • carlos fernandez Jr.
    carlos fernandez Jr. Jul 02, 2008
    sorry for wrong spelling, i can teach you!!!
  • 105 Answers
This a same problem which i have als o felted in the cold seasons this may be due to the failure in the circuit
Tv will not turn on. Makes on going clicking sound only.
http://www.shopjimmy.com/philips-996500042146-power-supply-unit.htm That is the most likely cause of your problem.
Aug 25, 2015 | Philips 42PFL5332D 42 in. LCD Television
Model 37PFL5322D/37 phillips tv has a fast clicking sound in the power supply, what will cause this.
possible the main relay in the power supply board may need soldring or you could have a stickey relay
Jul 13, 2012 | Philips 37PFL5332D 37 in. LCD Television
I have a philips 37" flat screen TV, when I switch
hi,
There is problem with the back light of your tv. In LCD tvs CCFL are used as back light to give light to independant pixels. CCLF lamps required high voltage to light. This high voltage is provided by the inverter board inside ths tv. If any one of the chopper transformer (high voltage transformer) have some problem then the inverter will shuts off itself preventing damges to the power supply.
You have to check the 24V from the power supply. If its ok the you have to check the inverter board.if avilabe replace the same. if you are not able to do the same i will prefer to consult some one experienced in it. Back light inverter board will look like one in the picture.
ok
Aug 03, 2011 | Philips 37PF5321 37 in. HD-Ready LCD...
PHILLIPS PLASMA TV MODEL #42PF9431D/37 Heard
Hi, Usually any "Pops" are an Electrolytic Capacitor "blowing up" quite literally, or "Gassing" as it is called. This happens due to some sort of power problem. Capacitors hate AC Voltage and Current, and Heat and Over Voltage. All of which, I have no doubt it was exposed to before it went "Pop" This is only a symptom of a far greater problem, to come, no doubt, soon, the rest of the set will fail too. Please DO NOT USE. this set any more, you risk fire or explosion or both. If you MUST use it at least unplug at bed time. Theses days home repair except for the most rudimentary problem is not feasible, setting aside the safety aspect. In my professional opinion, I would recommend, that you get a "Quote" for repair from a Philips Authorised Service Agent This is very important, that you contact a Philips head office and ask for a referral. This way at least you can make a decision to repair or replace.
Apr 01, 2010 | Philips 42PF9431D/37 TV
Philips 37pf9975/12 wont switch on
i have a Philips 37pf9975/12 and after about 1hr it switches itself off the green light stops on the side but you loose picture and sound. if you push the stand by button it clicks for about 1 min and then turns itself back on???????
Jan 09, 2009 | Philips 37PF9975 37 in. HD-Ready Plasma...
Philips lcd tv swithes itself of 37pf9731d/10
I fixed this by replacing the off/on switch which seems to bypass the stand by transformer which i think was causing the problem hoppe this helps someone
Dec 28, 2008 | Philips 37PF9731D 37 in. HD-Ready LCD...
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
