Question about E-Machines eMachines Desktop PC
Hard drive u see my computer the hard drive were the cd is supposed to go in wont close.  I put in a cd and the thing just opens up again.  i accidently kicked it up when it was open and now it wont close it will open after i close it and it wont read it if it stays in.
Emachines
Posted on Jul 23, 2008
  • 92 Answers
The Disk Drive Is Broken Get A New One
Posted on Jul 02, 2008
Refer Acer m3970 Can not Install windows 7 of new hard drive
Factory back-up discs and recovery discs are intended to repair defective installations or to kick-start an installation that refuses to start so it is unsurprising they will only go so far.
Your system disc might be defective. This is a problem I have had with XP in the past. It is possible your CD/DVD drive has a dusty lens and is unable to read the disc properly or perhaps the new hard drive has a problem.
I suggest you instal the new hard drive as a slave in another computer and format it and run the chkdsk utility. If all is well reinstal in your computer.
Take a close look at your system disc checking for flaws and perhaps put a lens cleaning disc in your CD/DVD reader before trying again.
Oct 27, 2016 | Seagate Computers & Internet
Can I put a bigger hard drive in my Dell Latitude c600 laptop?
You need a laptop IDE hard disk.
If I could be offurther assistance, let me know. If this helps or solves the issue, please rateit and give a testimonial for my response.
Mar 07, 2011 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
The cd drive in mycomputer dissapear i have a thosiba computer i have put a cd in thecd drive and when i went to my computer an go to cd drive it wasnt there i don know if i removit by accident or what...
Open up the registry by typing REGEDIT in run box. and go to the follwing location.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
on the RHS you will see lower and upper filters simply go ahead and delete both the filters.
Open up the device manager (type DEVMGMT.MSC in run box) and uninstall the CD/DVD drive and restart the PC.
Once again go to Device manager give a Right click on the CD/DVD drive and update it.
Than check ............Your CD/DVD drive will be there in My computer.
Aug 02, 2010 | Toshiba Computers & Internet
Pc945gz7mc-k52h
Put your hard disk to another computer format all drives unallocate the drives and aloocate in newly again..then istall the OS newly then put back in your system and check whether it works...
Sep 26, 2008 | Computers & Internet
Satellite A60-A692. I opened it in order to clean it of dust. After replacing back the hard disk, the computer asks for the CD that restores the system. Even though I do not like to loose all the data that...
That error message means invalid destination disk, which means your hard drive. Often just moving your computer will cause bad things to happen!
You should back track and make sure you have all tight connections. Accidents happen!!
Possibly your hard drive went out but as a last resort, try reinstalling your operating system.
Jul 13, 2008 | Toshiba Computers & Internet
Harddrive not readable by my computer.
well you could buy a hard drive enclsure (usb) then open up the seagate and take out the hd (unplug it form the ribbon cables) then plug it into the enclosuer and try plugging that in. may or maynot work becouse the hd itself may be "fried"
May 13, 2008 | Seagate FreeAgent Go 80 GB USB 2.0 Hard...
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
Windows
hard drives dont read cd's
does the door close?
if not close it.
1)left clik my computer
2)double clik the cd rom drive, making sure theres a disk in it.
3)right clik on my computer
device manager
look for a yellow exclamation point or red X where the cd-rom is.
high light the cd-rom
right clik
uninstall
restart the computer
windows will detect and re-install the cd-rom drive.
try a cd
if that doesnt work update windows
also buy a cd-rom cleaner at your local electronics store
clean the drive w/th cleaner
try a cd
if updating your driver for the cd rom drive and all ive suggested then its time for a new cdrom drive
Dec 09, 2007 | Dell OptiPlex GX260 PC Desktop
CD drive stuck please help!
Hi I guess ya mean that the CD tray will NOT open? If this is the case... then ya can "Open" it by way of a paper clip straightened... and then insert one end into the hole provided, on the front of the CD... There is a small hole usually just above the LED, inset & push it in until the mechanisim releases.. the tray should pop open and ya will B able to recover ya DVD...
Aug 30, 2007 | LG (GCR8525BK) Internal 52x CD-ROM Drive
E-Machines eMachines Desktop PC Logo
67 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
