Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
Problem with hammer drill
Hi ,
the motor gets power and rotate very slowly and the trigger gets hot very quick and at the base of the battery it makes noise , the battery pack works fine cause am using it on another drill,its new but i live in the caribeen to much work to bring it back thank you for answering ,
best regards
  • 26 Answers
I'm afraid u have to replace your armatures..
Posted on Aug 05, 2009
My paslode doesnt work! battery is charged but when i fire the fan makes a wee noise! i opened it and put battery in and pulled trigger and the fan move half a turn. what could this be?fan or wiring?
Morning Andrew,
When was the tool last serviced? Seems rather strange that the fan has only turned 1/2 a rotation. Sometimes, the trigger unit can fail on this tool but.... I'd suggest that you don't try too many times as potentially, you could burn the fan motor out?
Just a thought though, if you disconnect the power to the fan, can you either see or, hear the spark being generated?
Regards
Alex Leigh Co Limited
Apr 08, 2015 | RTO PasLode 900420 Impulse Framing Nailer
Trimmer line is spinning but slowly, like it has lost power.
Sounds like just what you said "it's lost power" Are you sure the battery is fully charged? Try another battery if you have one. There is no clutch to slip on this type trimmer. It's got to be either the battery is not putting out enough to turn the motor or the motor itself is bad.
Aug 23, 2014 | Black & Decker 18volt Cordless Trimmer 18v...
Torque limiter quick to engage Why?
Usually it is a worn clutch that will cause this.
May 26, 2014 | Drills
Milwaukee 18V Hammer drill shuts off while drilling
Brushes to the motor could be the cause or heat sensor in the battery pack it switches off or even bad connections on motor check the spades connections could be loose
May 13, 2017 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
Dewalt 36v SDS 234 drill issue! Could someone please help? When I pull the trigger on the drill the motor runs but the drive only turns for about 1 second and stops even though the motor is still running....
DeWalt says:
Number of drilling modes
3 modes. Rotation only, hammering with rotation, or hammering only with rotation stop for light chiselling applications in tiles and plaster and impact stop mode for rotary drilling only in wood and steel.
Maybe yours is doing the second one?
Dec 02, 2017 | Dewalt Drills
How do I unlock the chuck to get the bit out
Finally got it the normal way. Put the drill in reverse. Hold the outside ring very firmly and slowly run the drill (in reverse direction). It was stuck. After about 5 bursts on the trigger, it finally came unstuck.
Sep 01, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Hi my 18v xrp combi drill which is about 18 months old seems to have problems with the trigger. At times the speed of drilling is very slow but can suddenly speed up without any additional pressure on the...
YES. You have dirt and grime inside.Go to a Lowes or Home depot and look in the nail gun dept. Get a can of Paslode tool cleaner.( white aerosol can with orange and black label) $8 a can. While running tour drill,(over a sink or outside) spray it all inside aroud trigger and motor,turn in all directions and watch how much gunk will wash out. You'll be suprised at what a difference this will make and it will prolong the life of your tool. Works great on all battery powered tools and air tools ! I highly recommend it, but don't buy them out of it , leave some for me. I;m allmost out of it.
May 31, 2011 | Dewalt DCD970KL XRP HeavyDuty XRP 12"...
The fan motor makes a noise but doesn not start rotating, if you rotate the fan the motor kick in and continues to work until it os turned off.
The motor probably is not starting because the bearings are a bit stiff....
Take the hood apart and give it a good cleaning, being careful to not get the motor wet...
Then if you can get the hood in a position to run some light motor oil down the shaft and into the motor... spin the shaft as you do this... get oil worked into the motor bearings then it will probably work again...
heatman101
Jan 17, 2011 | Broan-NuTone Broan Range Hoods Rangemaster...
Apparently the motor is working but the timer is not running
These dang power packs don't have replacement parts. You can see if the manual override turns lights on and off. The power pack makes a humming noise. If the timer is not rotating, then try setting the current time.
Malibu manuals are located on this page
Normal 0 false false false MicrosoftInternetExplorer4 http://www.malibulights.com/customer_service/owners_manuals.aspx
If you buy another one, be sure to match up total wattage of bulbs to the power pack wattage.
For example 10 - 20 watt bulbs = 200 Watts >> you should buy 200 Watt power pack
15 - 20 watt bulbs = 300 Watt power pack
Oversized power pack will burn out the bulbs
Also if you let bulbs burn out, it will shorten life of power pack
Unplug the power pack when working on the bulbs
Oct 17, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
143 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
