Question about Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit
XM radio - intermittent signal
I have an XM2Go Pioneer Airwave radio. My receiver is in south window, with UNOBSTRUCTED view of horizon (2nd floor). Sometimes I get a signal and can switch channels at ease. Other times, I get "Loading", and then a channel that plays a few seconds, then cuts out for a few seconds. Sometimes, after the "Loading" it gives me a "No Signal". I've called the XM radio support number and all they do is "Resend The Signal", which sometimes works and sometimes doesn't. HELP! Brian Callahan, Searsport, ME bscallahan@yahoo.com
4 Suggested Answers
maklean
  • 1665 Answers
SOURCE: Airwave XM2go
It seems key problem
Posted on Apr 14, 2008
TOLhamRadio
  • 509 Answers
SOURCE: Airwave won't power up!
Remove back cover. Plug DC adapter into the bottom of the radio. Use an extra small paperclip or pin to push the 'reset' button just to the left of the white battery. Report back on progress.
Posted on Sep 05, 2009
  • 3 Answers
SOURCE: Pioneer xm radio suddenly stopped playing
I have same problem and sure connect did not help.
The unit works fine otherwise except will not send a signal to my car radio.
I will try removing the battery today & if this does not work I will do t paper clip reset in the battery compartment.
Posted on Dec 01, 2009
I cannot find a home docking station for my Pioneer Airware radio. Do you have any suggestions other than E-Bay? Thanks.
http://parts.pioneerelectronics.com/part.asp?productNum=XMTSE-XMPIH-01
$53.50 retail from pioneer. Any XM2GO dock should work, there are a few home docks on ebay now. You may need to modify it so it can fit your radio, but the pins are all the same.
Dec 28, 2010 | Pioneer AirWave XM2Go Satellite Radio...
I would like to connect my antenna directly to my XM2GO unit without the docking station. Where can I find an adapter?
Simple. Go to http://xmfanstore.com , click on "Antennas and Extensions" under "Shop Categories" on the left most side of the site; there you will find "XMFanStore XM2go Direct Connect Antenna Adapter" .
It plugs into the SIDE antenna port of your XM unit and you plug the antenna into that.
This URL MAY be a shortcut:
http://store.xmfanstore.com/directconnect.html
May 27, 2010 | Pioneer AirWave XM2Go Satellite Radio...
Does this device charge using a usb cord?
No, you cannot charge the AirWave with a USB, you CAN charge a SkyFi3 only with a USB, but the AirWave (all XM2Go clones) require a 5Volt 2000ma (2A) power supply either a 'wall wart' or cigarette lighter plug.
Jan 12, 2010 | Pioneer AirWave XM2Go Satellite Radio...
Pioneer xm radio suddenly stopped playing through my car radio. Got xm to restart signal back to device but that changed nothing. Sometimes when I wave my hand near to the xm device the car radio receives...
Sep 15, 2009 | Pioneer AirWave XM2Go Satellite Radio...
Aug 29, 2009 | Pioneer AirWave XM2Go Satellite Radio...
Pioneer inno will not recive xm singal
Are you still having this problem? Sounds like you just aren't getting a good signal. Antenna is not properly mounted, not getting good singal.
Or, the antenna and/or cable is damaged.
Apr 02, 2009 | Pioneer XM2go Inno Satellite Radio...
Air ware xm2go
The unit has an internal antenna (that is really poor) that is activated when you unplug the external antenna. This is why you get some signal when you unplug the unit.
I assume the problem is the antenna itself.
My suggesion is that you charge up the unit, take it to a place that sells XM equipment AND has a demo unit working. Be sure to take your docking station with you (it has the plug in for an external antenna). Ask the sales rep to please connect your unit to an external antenna to test your unit as you are trying to determine if your antenna is bad. If it works, you need a new antenna (cable may be cut on the inside or antenna may have water/weather damage). If it does not, then there is an electrical issue inside the unit and the unit itelf will need replacement/repair.
Jul 03, 2008 | Pioneer AirWave XM2Go Satellite Radio...
Pioneer xm2go power surge
I have the same problem with my XM2Go. The screen is blank. I ordered a replacement battery but it still doesn't work.
I could really use some help.
Vince
Mar 18, 2008 | Pioneer AirWave XM2Go Satellite Radio...
Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit Logo
102 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
