Question about GPS
Resetting time are you talking about a garman???
  • 6,487 Answers
Yes.. sorry for the late reply..
Posted on Jul 03, 2008
Garman 225w won't start, stops after "loading
The micro usb port is at the back. Connect Vehicle Power Cable to the nüvi and connect the other end to your computer, your nüvi does not operate as a GPS unit - it goes into some sort of charging mode. However, if you FIRST turn on the nüvi in the battery mode then go into the test mode (press the battery icon for about 8-9 seconds) from the main screen, THEN PLUG in the USB cable, and finally exit the test screen, your nüvi will restart (reboot) and it will operate just like it was plugged into the cradle connection in your vehicle.
This mode will charge the battery
AND operate as a GPS.
It works with my computer USB cable, my cell phone charger and my car charger for my cell phone.
Don't forget to turn off the nüvi before unplugging.
Jan 08, 2011 | Garmin nuvi 255W GPS Receiver
My Garman GPS touchscreen
Hardware issue and needs replaced. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Jun 16, 2010 | Garmin Nuvi 660 GPS Receiver
CHARGING MY GARMAN GPE C330. DO I LEAVE THE GARMAN ON OR OFF WHEN CHARGING . THE BATTERY WAS DEAD ON MY WAY BACK FROM MY LAST TRIP.IT WAS OK GOING UP I HAD IT PLUGGED IN TO CIG LIGHTER BUT GARMAN SEND...
Disconnect from cigar lighter and connect to the USB port of your computer or any AC adapter over night. By morning the battery will have recharged and be ready for use. This seems to happen with the GPS is left connected to a vehicle's cigar lighter for an extended period of time. You can do this USB / AC adapter recharge procedure as often as needed.
I hope this helps!
Jun 08, 2010 | Garmin nuvi 250W GPS Receiver
The Garman works when out of the vehicle but when in the vehicle the Garman reads "cannot detect satellite"
try reseting the unit - the reset button is under the antenna.Keep in mind that satellite acquisition is only possible outdoors or in a vehicle. Last case scenario try a hard reset (will erase all your saved places and bookmarks) - hold your finger on the upper right corner of the nuvi's screen while turning on the nuvi keep your finger pressed until the popup window appears - touch yes to clear all user data.
May 25, 2010 | Garmin Nuvi 350 Car GPS Receiver
How do I reset the Garmin 1300t? It is locked up
turn it off and unplug it from power, then press and hold the lower right corner of the screen, then power it on. when it comes on release the power button and you will see a message similar to: do you really want to erase all your data? YES, release your finger when you see that message, then follow the on screen prompts.
bill
Oct 14, 2009 | Garmin nuvi 1300 Car GPS Receiver
Need new instruction manuals garman GPS map492 sereal #70405694 & Garman Fishfinder 400c sereal #12c005161 thanks milton
you should be able to get them from garmin website and download them in PDF for free
Jan 26, 2009 | GPS
Change time setting on garman gps
to change the time or restore it to normal.
in the main screen press on the tool icon or settings icon
in the settings screen select time
in the time settings you can press on Restore settings
to restore the original time or change it from the time zone
setting, you can also change the time format and daylight saveings on the same page.
Jul 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330
pins on the mount are broken
Mar 31, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
35 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
