We keep getting an F7 error message on our JT950 GE oven. We can clear it with the clear command although it comes back. Is there a grounding problem, control panel problem? Thanks
-   How do I fix the F 7 error message?
-   Guest
Jan 01, 2009
-   The ovens continually beep and flash F7. The only way that I have been able to stop the beeping is to switch the breaker off.-   BILLYSKY2
Jul 19, 2008
-   my oven has been beeping F7 all nite....I unplugged the oven as manual says, but it returns........what next, call a repair man??????
-   krzack
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem so far.
My oven is also a JT950 and the builder installed it in our home back in 2000. Our F7 issue started about 2 years ago. For a few months, "clearing" the panel and/or shutting the oven off at the breaker panel would temporarily solve the problem. About 1 1/2 year ago, however, the F7 would come on and continually beep. A repairman looked at the oven and replaced the control panel at a cost of $600 (ugh...). That solved the problem until a month ago when the F7 continuous beeping began again. There was no way I was going to pay another $600. for "temporary" repair and I was thinking of replacing the oven. Luckily, I came across the above-mentioned fix-it information and took a chance by following the simple instructions provided.
Comments:
Aug 30, 2008
- I just wanted to say that the fix-it I did has worked since I repaired the oven per the e-mailed instructions I received from Charlie at hutchipop@yahoo.com. I am so happy! If you have not yet tried this repair, please contact Charlie and ask him to e-mail it to you. His e-mail is free and his fix-it could save your oven.
The insulation in the ribbon cable is poor. The conductors in the cable are crossed. The ribbon cable is actually two ribbons pressed together, and the conductors between the two cables are shorting or becomming crossed. Lift the two cables apart, place a piece of paper between them, fold the edges of the paper over the cable so that it does not slip out, and make sure to shove it all the way down to where it will meet the plastic display panel housing. There, problem solved.
7/31/09: had the same F7 code and beeping on my JT950 GE double oven. GE wante several hundred in parts and labor. Came across Charlie's fix. I emaile him and he promptly emailed me back a PDF with easy instructions and pictures on how to cure this problem. It is not equipment failure, but something known as "silver migration" of the ribbon strips (Google the term). In short, problem was fixed for FREE. Thank you Charlie.
I have removed my electric wall oven and cooktop and am replacing them with used westinghouse...
(More)
I have removed my electric wall oven and cooktop and am replacing them with used westinghouse (paf-808w) drop in unit that requires 2 phase. Do i need to have both circuits come out together (currently 2 mtrs apart) for the electrician or can he convert the single phase?
ge profile double oven, model # jtp56bowlbb, appx. age 2000. push any button and number 6 comes up...
(More)
GE PROFILE DOUBLE OVEN, MODEL # JTP56BOWLBB, APPX. AGE 2000. PUSH ANY BUTTON AND NUMBER 6 COMES UP ON DISPLAY, CLOCK CANNOT BE RESET. THE BROILER WORKS BUT NOTHING ELSE.
