The noise is most likely caused by the different wear pattern on the tire that came from the rear of the car. The difference in the alignment between the front and rear suspension systems causes the tires to wear accordingly. It will take some time for the tires to wear in to their new environment. The noise should go away gradually. You should also check your tire pressure to make sure you don't have an improperly inflated tire.
It is probably issue with the alignment of tires or may be ur dealer did,nt put the right tire for ur cx 9. This is the default tire specification
Front Tire Size
P245/60HR18.0 BSW AS
Rear Tire Size
Front Wheel Size (in)
18′ silver alloy
Rear Wheel Size (in)
18′ silver alloy
preasure light sensor wont go off
