Question about Casio Exilim Zoom EX-Z700 Digital Camera
Camera screen not working
I was using my camera then I turned it off and set it down only to pick it up a couple moments later. I turned it on but for some reason the screen was blank no matter what I do. I have charged the battery and stuff but it wont work. The light by the screen blinks red once when i turn it on and green a few times when i turn it off. The camera makes noises like normal. Why the sudden camera mood-swing? How do I fix it? [english please :)]
  • pink_kittys3 Jul 27, 2008
    i have the same problem. when i try to take a picture...the photo is fully black. what is the problem and how do i fix it?
  • Misty Hoffman May 11, 2010
    When you turn it on does it stay on? Try going into your picture taking mode and pressing menu. Then go to the setup tab and go down to reset and press right. Highlight ok and press select. That should reset your camera. Now see if it works properly. If not then you will have to send it in. It sounds like the flash is having mood swings and not wanting to work corrctly. You can call 8007062534 and then option 2 and they will tell you where to send it. Hope my Nebraska English was good enough for ya. :) LOL
  • 374 Answers
Did you follow the steps I suggested? Hope they helped.
Posted on Nov 06, 2008
No image on screen
The only solution to fix this is to get ti repaired.
or go to www.digitalcamrepair.com for help.
Goodluck..
May 10, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Touch screen frozen
the best solution to fix this problem is to get it repaired or replace if it is still under warranty.
I'll let you know if there is any other solution to fix this.
Apr 12, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Hi, I have bought this camers to use for listing items on eBay and would like to use it mainly for close up/detailed pictures. I have managed to get the camera on the macro setting for close up images but...
Go to the hardware store or even Walmart and pick up a couple of clip-on reflectors that use a standard-base light bulb. Purchase two "daylight" compact-fluorescent bulbs. Clip the units to some kind of stands and point the light on either side of your subject at 45-degree angles. Turn off the flash on your camera. Try to use a tripod if you have one. Your results will be spectacular!
Sep 09, 2011 | Cameras
Blank screen when trying to take new pictures
CCD FAILURE!
Call canon for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
Kindly Rate me WELL !
Service Advisory Link this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
May 26, 2009 | Canon PowerShot A590 IS Digital Camera
Set time screen on turning camera on
There is BATTERY LITHIUM SECONDARY (installed on MS-259 Flexible Board) requires replacement.
It requires to apart camera and little solder work, qualified camera tech job.
If you are willing to repair it yourself, let me know to help you out.
Apr 09, 2009 | Sony Cameras
Camera Frozen - Canon Powershot SD1000
Have you tried using a different set of batteries ?
Mar 05, 2009 | Canon PowerShot SD1000 Digital Camera
Camera turns on then immediately shuts off
I have the same problem - 4 fast beeps and it turns off. My guess is that the lubricants are getting old and sticky - I had a Canon SLR that developed the same problem after being in the extreme cold. Here's a couple of things to try:
  • You can still access the picture review features by holding down the review button while you turn it on (note that if you hold down the trash button you'll see the firmware version.)
  • What doesn't work: Resetting the camera from the setting menu; replacing the battery, replacing the SD card, cursing.
  • I've been able to consistently get it to function normally by hitting the camera into the palm of my hand on the left side (with the viewing screen facing you), just after turning on the camera.  If this doesn't work, keep hitting harder until it works.  Once on, the camera works normally.
Aug 16, 2008 | Pentax Optio W10 Digital Camera
Olympus FE 240 - downloading problems
Remove the Software
Restert the Computer
Plug camera in and turn on set it to the upload mode.
Windows will then fid it via the Camera/Scanner Wizard.
If there is still a problem
A cheap card reader will do the trick
Dec 13, 2007 | Olympus Camedia C-350 Digital Camera
PLEASE HELP!
There is a problem inside the camera with the wire harness/cable connection to the screen. They are know to come loose over time. If you tap rather briskly on the front of the camera right on the word Cybershot it should reconnect it. Worked on mine but you may need to do it now & again. The altenative is to have the camera dismantled and the connector pushed back onto the screen.
Now a couple months later I have a different problem, it says to turn the power on and off again when I turn it on to take pictures.
Nov 18, 2007 | Sony Cybershot S650 Digital Camera
Casio Exilim Zoom EX-Z700 Digital Camera Logo
83 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
