My usb port won't work - Computers & Internet
  • 4 Answers
RIGHT CLICK ON MY COMPUTER SELECT PROPERTIES>HARDWARE THEN DEVICE MANAGER AND CHECK FOR ANY YELLOW EXCLAMATION MARK IN THE USB SECTION AND RIGHT CLICK ON IT AND SELECT UPDATE (U HAVE TO BE CONNECTED TO THE INTERNET TO GET THIS DOWN.WHEN THATS DONE U WILL BE GOOD TO GO. GOOD LUCK!!
Posted on Jul 02, 2008
Tip
Ipod not charging when i connect it to the usb port. or iphone.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices
If your iPhone iPad or iPod touch won charge
How to Fix an iPad iPhone or iPod Touch That Won Charge Anymore
Help My iPad Won Charge
Help My iPod Battery Won Charge
ipod do not charging when connect it to the usb port Google Search
on Dec 06, 2017 | Computers & Internet
Coby touch screen mp3 won't plug into anything
I use one of my other usb cords for my amazon and it works fine
Sep 23, 2012 | Coby MP828 MP3 Player
My frontal USB port won't work?
If this item is still under warranty return it, or try a system restore before this happened, not possible! Do a complete recovery of the operational system, if this fails to activate the front usb ports it indicates a hardware issue.
Jul 12, 2012 | HP Pavilion dv6000z Notebook
LG laptop usb ports not working
do you have the program needed to get what you have on your flash drive? If you don't have a photo program or pdf program or what ever to open it, it won't work. try connecting something else that uses USB port to it and see if that works, then you will know if its a program problem or your computer. if its the computer, you can replace it.
May 07, 2012 | Computers & Internet
Usb port won't recognize mouse
the usb port may be damaged or bad solder connections, do a system restore taking the it back before the problem occured. "long shot"
Mar 19, 2012 | Toshiba satellite c660
SE-084C Won't work on mac is there a soultion to this?
According to the samsung website the SE084C it can be used with a mac see http://www.samsung.com/ph/consumer/monitor-peripherals-printer/optical-disc-drive/dvd-rw-drive/SE-S084C/RSPN/index.idx?pagetype=prd_detail
Are you using it via a usb hub or is it plugged directly into the usb port of the mac. As it is powered via usb, on the hub it may not have enough power getting to it, so plug it directly into the usb port. If you already have it plugged into the usb port change the usb port and finally check that the usb cable is working, if it isn't change it. Hope this helps.
Jan 08, 2012 | Computers & Internet
Team promark keyboard won't work
If it has a USB plug, try attaching it through a different port hub, i.e. not the usb port right next to the one that didn't work. If that doesn't work, test the usb port with something else first. If the USB port is not the problem, you may need to download a driver for the keyboard.
Jan 03, 2012 | Team International Team ProMark Carolina...
Pc won't recognise scanner after installation I am looking for a free windows 7 driver update. problem is I have 2 usb ports close together and don't have a usb hub...any suggestions
ok, you purchase a 4 /8 port USB first. This is a adiitional device which is insatll through USB port. after that you can get additional 4/8 USB port.
Thanks.
May 13, 2011 | Computers & Internet
Netgear wna 3100 won't install on my windows xp. I have uninstalled it 3 times. It won't recognize the adapter. Then it does. Then in the end it won't recognize it even though it's there...
My adapter constantly loses connection completely to the router and cannont be re connected unless i unplug and replug back in the USB port. What a joke!?
May 06, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
