Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Tv won't power on
We had a slight power failure(glitch?) and the tv turned itself off, but the timer light won't stop blinking(fast). I've tried the system reset, but the light continues to blink (won't stop). I've turned off the power strip and left it off for 10 minutes, when I turn the power strip back on, the light starts blinking again.
Any help will be greatly appreciated.
BobW
  • Anonymous Nov 23, 2008
    I have the same problem, the power light blinks but won't power on, tried the reset, but it doesn't change, bought the tv used and it worked great at the person's house I bought it from, please any help would be great....
I trashed the set and bought a new one.
Posted on Jul 08, 2008
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Timer light blinking and tv won't turn on
Not much info to go off of, and the video is a bit blurry. Try unplugging the tv for a minute or two, make sure to leave it unplugged to allow power to dissipate. Then try again. Otherwise I would suspect power supply problem.
Apr 10, 2013 | Televison & Video
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
Timer light continues flashing; won't turn on/off
Could be an open internal fuse or power supply failure
Jun 25, 2017 | Mitsubishi WD-65731 65" HDTV
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
JVC tv i'art blinking timer
It is protecting you and itself with high probability.
Power supplies in modern electronic devices are designed to cycle if there is a fault in circuitry they are servicing and because of the design, also will not turn on completely if they are failing.
The older style of power supply was 'dumb' and unable to do this so could cause fires if the failure wasn't teh 'right' kind to blow the main fuse.
I agree with the manual; this is a job for a tech.
Aug 23, 2008 | JVC AV-32260 32" TV
Fast blinking timer light and tv will not turn on
it sounds like the 1000 mfd 16vdc caps on the dm board have gone bad, but with out a model number it is hard to be sure..
Nov 29, 2007 | Televison & Video
Power Failure, now the power/timer blinking light won't stop blinking
Four bad caps in DM module = common repair for qualified
Mits tech.................................T.
Nov 03, 2007 | Televison & Video
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
168 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
