Question about RCA 36V430T 36" TV
36 inch RCA tv loses picture and sound, but power stays on
I have a 36 inch RCA tv (model # 36V430T) that I bought new inn 2005 that I am having trouble with . My TV will work at times fine, then there is times I turn it on and it is great for but then the screen goes black and loses picture, sometimes I also lose the sound, but the green light for power stays on. I turn the power off and back on immediately and it might work great for 30 seconds or for days, but eventually it goes back to working intermittently. Any ideas??
Thanks Mike
[email protected]
  • g68mike Jul 02, 2008
    I also noitced if the tv is unplugged, when it is plugged back in, it turns on by itself or on then off right away. Any ideas?
    New Friend:
  • 14 Answers
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
Posted on May 04, 2017
2 Suggested Answers
SOURCE:
  • 135 Answers
SOURCE: 36 inch RCA 36v430t
Mike-It looks like the power supply is going on your tv-it can be replaced. This happens, usually, when little kids are playing wth the remote or power button on the tv. Turn it off and on a whole bunch of times in a row, kids love to do that, and it burns out the power supply part- to make a CRT tv like your RCA36 incher- which is a beautiful machine- I have the RCA/PROSCAN 36 incher-LAST longer...You should always wait 5 min between turning it off and on. Don't ever sell it. This one is worth fixing. It has better color and sound Than the new plasmas and lcds-The Pros know this. Be carefull, they might try and talk you out of it-so they can fix it and have it for themselves. So what if it's not High Deff. It's a great set.
Posted on Jul 02, 2008
Popping sound then no video. Power TV off and then back on and get video for seconds to minutes only.
a capactor is going down( look like little batteries) and if any have raised tops replace
Dec 12, 2009 | RCA 36V430T 36" TV
38 '' RCA TV XBOX Model 36V550T, lost the picture
Does it only happen when you use your Xbox?
Try pulling the cable in and out between the TV and Xbox
Dec 05, 2009 | RCA 36V430T 36" TV
Water poured into the back of my tv. It's
you have to clean all the water corrosion off with rubbing alcohol and a toothbrush, then any blown or water damaged parts need to be replaced, you probably need a tv repairman.
Sep 17, 2009 | RCA 36V430T 36" TV
TV will not turn on
There is a problem with your power ic..U need to replace it...
Dont forget to rate
Sep 07, 2009 | RCA 36V430T 36" TV
Picture went out on my 36'' RCA television, still have sound.
do you have and big sound system if you do the move them away from youur tv. or you sould just bring it to a shop it must be the picture tube
Jan 26, 2009 | RCA 36V430T 36" TV
Loses Picture, Goes Black... Sound stays on
Sounds like power supply. Probably time for a new tv. You have already got almost 20 years service.
Dec 05, 2017 | RCA F36685 36" TV
36 inch 36v430t
It's simply refered to as the power supply- the repair guys will know exactly what you are talking about when you use it. You see the power supply upgrades the power to drive the tube- much in the same way a coil increases the power on your car from 12 volts to what ever it needs to turn the engine. The green light just means that you turned it on, and all the other curicuts are working. Like if your car coil is bad-you can still turn on the lights and radio-but there is not enough power to turn over the engine/turn on the picture tube. I love my 36 incher- mine is 12 years old-and was only in the shop once-and still gives a better picture than the LCDs out there. I'm a member of SMPTE. society of motion picture and television enginers.
Jul 02, 2008 | RCA F36650 36" TV
I wouldn't advise doing it yourself. All you have to do to kill yourself is touch the wrong part connected to the magnets on the back of the tube-even if it has been unplugged for a couple of days- no joke. The repair place will be better able to track down the part, and install it, and guarentee it. Be aware- it might take a week or two for them to just get the part-then they have to install it.
36 inch RCA 36v430t
RCA 36V430T 36" TV Logo
125 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
