Question about RCA F36650 36" TV
36 inch 36v430t
What is the name of the part? Is it just called power supply??? (even though the tv still has power- green light stays on). What is it??
Thanks Mike
g68mike@aol.com
  • g68mike Jul 02, 2008
    Would this be a resistor in the power supply or you think the entire power supply could be bad? Nothing with any of the solders?
    I also noticed when the TV is plugged in, it turns on by itself or on then off right away. ANy other ideas?
    Thanks
    Scholar:
  • 135 Answers
It's simply refered to as the power supply- the repair guys will know exactly what you are talking about when you use it. You see the power supply upgrades the power to drive the tube- much in the same way a coil increases the power on your car from 12 volts to what ever it needs to turn the engine. The green light just means that you turned it on, and all the other curicuts are working. Like if your car coil is bad-you can still turn on the lights and radio-but there is not enough power to turn over the engine/turn on the picture tube. I love my 36 incher- mine is 12 years old-and was only in the shop once-and still gives a better picture than the LCDs out there. I'm a member of SMPTE. society of motion picture and television enginers.
Posted on Jul 02, 2008
TV wants to turn on but can't. Green on-light goes on, then sounds like a relay clicks off and it tries a couple times, but nothing happens.
Check and replace the shorted component/s in its horizontal output section circuit. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 10, 2013 | RCA 36V430T 36" TV
Water poured into the back of my tv. It's
you have to clean all the water corrosion off with rubbing alcohol and a toothbrush, then any blown or water damaged parts need to be replaced, you probably need a tv repairman.
Sep 17, 2009 | RCA 36V430T 36" TV
TV will not turn on
There is a problem with your power ic..U need to replace it...
Dont forget to rate
Sep 07, 2009 | RCA 36V430T 36" TV
No light, sound nor green button
maybe a lizard is die inside and shock your power supply circuit
Jul 01, 2009 | RCA 36F530T 36" TV
My rca 36" tv went out the green light is blinking but no sound or picture
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 23, 2009 | RCA 36V430T 36" TV
Mitsubishi Big Screen Digital 65 inch
you have a short in power supply the light should stay on check all power supply parts
diodes,power transisters
you need to test all parts, i could fix this in
30 mins
need help call 0403960527 jeff......
Feb 16, 2009 | Mitsubishi WS-55807 TV
Rca 36" 36v430t
Without seeing the actual set, I can only suggest some of the common things that can cause this. Based upon your description, I would first look for a poor solder connection where the AC cable connects to the board. Look in that area for any charred spots. Let me know if there are any. The bussing usually is arcing of the AC power.
Dan
Oct 23, 2008 | RCA 36V430T 36" TV
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
36 inch RCA tv (model # 36V430T)
I wouldn't advise doing it yourself. All you have to do to kill yourself is touch the wrong part connected to the magnets on the back of the tube-even if it has been unplugged for a couple of days- no joke. The repair place will be better able to track down the part, and install it, and guarentee it. Be aware- it might take a week or two for them to just get the part-then they have to install it.
Jul 02, 2008 | RCA F36650 36" TV
36 inch RCA 36v430t
Mike-It looks like the power supply is going on your tv-it can be replaced. This happens, usually, when little kids are playing wth the remote or power button on the tv. Turn it off and on a whole bunch of times in a row, kids love to do that, and it burns out the power supply part- to make a CRT tv like your RCA36 incher- which is a beautiful machine- I have the RCA/PROSCAN 36 incher-LAST longer...You should always wait 5 min between turning it off and on. Don't ever sell it. This one is worth fixing. It has better color and sound Than the new plasmas and lcds-The Pros know this. Be carefull, they might try and talk you out of it-so they can fix it and have it for themselves. So what if it's not High Deff. It's a great set.
RCA F36650 36" TV Logo
61 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
