HP LaserJet 4 plus Printer Logo
Posted on Dec 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error message 41.3 paper error How do I fix?
JDTec
Level 3:
  • HP Master 4,338 Answers
  • Posted on Dec 16, 2010
JDTec
HP Master
Level 3:
Answers
4338
Questions
0
Helped
2128070
Points
14653
Error 41.1 41.2 41.3
  • Defective connections. Reseat J205,206,207 and laser scanner connectors.
  • Paper multifeed or wrong size paper being used.
  • Paper size selection doesn't match the paper being used.
  • Cassette is overfull or improperly adjusted
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
6answers
Fax machine says error 41 unplug and call brother.
unplug all the connections and reconnect everything back.also checkout for any blocked paper or any paper jam.also remove and check out the cartridges from the printer and reinsert.either its the internal circuit failure error and has to be repaired to make it proper. thanks.
Brother MFC 3100 Printer/fax
This is the only reference I could find on error 41: How can I clear the message Machine Error 41 from the display? (ME41)
Machine Error 41 indicates a mechanical malfunction of the Brother
machine. Unplug the unit from the power source and then plug it back
in.
If the error message continues to be displayed on the LCD, please call
Brother Customer Service at 1-800-284-4329 for assistance. The Customer
Service center is open Monday through Friday, from 9:00AM to 7:00PM,
excluding holidays If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Error 41 shows
Error 41 is a printhead failure. The only way to fix it to replace the printhead there unfortunately is no way to recover the printhead. If you decide to replace the printhead please do not leave the machine of for extended periods of time (causes the printhead to dry out as it can not do its cleaning cycles), use only genuine ink (I see a lot with this failure with non-genuine inks or refills) and do not cheat the ink system by running empty inks (Dries out the printhead). Just a few tips to extend the life of your printhead.
5helpful
4answers
Brother MFC 3220c machine error 41
I had the same problem with a Brother MFC3420C after replacing the print head with a new one the same error 41 occured 4 weeks later.
I finally fixed the problem (see photo's) and sent the parts back to Brother :-)
Don't buy Brother Inkjet technology its all ****!.
Their laser technology seems to be much more robust and reliable, have had a Brother HL-1440 since 2004 and its still running well.
http://www.flickr.com/photos/48446421@N05/sets/72157623635891898/
Error 41
error 41 means that the printhead is defectiv. It has to be replaced. Sorry, no chance to fix it anymore.
4answers
Error 41 on Brother MFC-3420C. I have tried unplugging and restarting. There aren't any paper jams or visible problems. There is dial tone to machine but fax will only ring when called, no start tone...
Hi,have the same problem since yesterday. Look on fixyourownprinter.com. """You can fix the ERROR 41. Go to www.bopparts.com and look up part# LK0935001. They sell it for $39.99 and it is very simple to install""".Good luck.
Machine Error 41
Error code 41, Print cartridge is bad and gone out. Needs to be replaced by authorize dealer for just under $100.00 ($55.00 part & $40.00 Labor).
k24674
Grand Canyon Tech
Grand Canyon Tech
