Question about Frigidaire Refrigerators
The hose on the water dispenser has popped out of the hole. There's no clamps or anything and there's not enough slack to pull more hose. I can push it back in with my finger, but as soon as I turn the water back on, it pops out again. How do I fix it?
I also had this problem. I could not get the hose to stay, so I found a flexible straw to extend the hose. Pushed the straw through the hole and trimmed it.
Posted on Jan 09, 2010
My washer is leaking water out of the dispenser area . The hose for the water underneath the dispenser seems to be clogged how do i fix this?
Hi, follow the instruction below to clear the clooged hose.....
  • Pull the washer 2 to 3 feet away from the wall so you have enough room to access the drain pipe.
  • Locate the drain discharge hose where it comes out from the back of the washing machine. Typically it will be a 1 1/2-inch hose and leads to the drain in the floor, wall or laundry tub.
  • Detach the discharge hose from the drain. The hose may be secured by a squeeze clamp or screw clamp or it may just be inserted directly with no clamp. Use pliers for the squeeze clamp, screwdriver for a screw clamp or pull the hose straight up, depending on how it is secured.
  • Insert the pipe snake into the open drain until you feel the clog release. Typically this will be very close to the top rather than several feet down.
  • Check the drain hose section that is attached to the washer. If there is another clogged area, you will be able to see it; snag it with the wire and pull it out.
  • Replace the drain discharge hose into the drain and check all connections to ensure there will be no water escaping.
  • Move the washer back into place. It will now drain properly.
Nov 28, 2010 | Maytag Neptune Washer
GE ESS22XGMCWW side by side, water line broken and leaking, need to replace hose. Looking for detailed schematics for water system and parts information.
Please CLICK HERE and browse the sub components and you'll see the diagrams.You can also order for a service manual if you wish to.
Goodluck..
Jun 17, 2008 | Refrigerators
Water dispenser in door is spraying water everywhere, water comes out of nozzle and out of manufacture hole in dispenser
try to pull slack in hose with long nose pliers about 1/4 inch then trim off with a razor blade.
Aug 25, 2009 | Refrigerators
Water leaks from bottom
check for cracks and corrosion on the outer tub.thats where the water must be leaking from.good luck.
Dec 25, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Installing a built-in LG dishwasher; got everything ready to go, but a problem with the hot water line coming in. It is barely long enough to reach to the front where I've installed the elbow. Since I have...
Hi, best way would be to install a "spring" attached to the back of the dishwasher. The hose would connect to that and easily "pull-away" when moving or "pull-tight" taking up the slack. A much simpler method is to tie a piece of string to the hot water hose, feed it up and over the top of the dishwasher where you can hold on to it in front. As you push the dishwasher back, take up the slack by gently pulling the string.
Good Luck!
Nov 30, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Machine doesn't dispense detergent
Here's a few suggestions you can try. First, open the dispenser tray far enough to where you can see inside. Enter diagnostics mode by selecting DRAIN SPIN, NO SPIN and pushing ANY button under OPTIONS 4 times (it has to be the SAME button, though). This will enter the washer into diagnostics mode which checks the hot and cold water fill functions, the dispenser tray functions, tumble, spin and drain. Watch inside the dispenser tray to see if you can see any water flushing through the various compartments (detergent, bleach, fabric softener). The water should be fairly steady and forceful. There's not much else, besides gravity, that forces the detergent into the wash tub. Now...if you don't see the desired water flushing action that you should see, check the overhead portion of the dispenser cavity. Pull the tray all the way out for this. There are a series of holes where the water is forced through. Sometimes these holes become clogged and will not allow enough water in during the fill and rinse cycles. It's usually the fabric softener side that becomes blocked, though. You can take some cotton cotton swabs and perform the tedious task of cleaning each hole if they are blocked. I've had to do this before and it does fix the problem. The other possiblities are the fill valve not allowing enough water pressure through (but, you didn't mention anything about a slow fill problem), or a kinked or blocked hose coming from the fill valve. If you wish to check the fill valve, turn the water off and remove the hoses from the back of the washer. Check the inlet screens for clogs. If you have hard water, well water, or BOTH, it is common for the inlet screens to get accumulated with sediment. Again, some cotton swabs will clean the majority of the sediment from the screens (you can use a little white vinegar as well). If you wish to check the inlet hoses from the fill valve, remove the top of the washer by removing the three torx screws along the back of the washer. The top will slide back then lift off. There are a series of hoses from the fill valve to the dispenser. Check to see if any of them have become kinked. I hope this information is helpful to you. Post back with comments if you need further assistance.
Jan 29, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
REPLACING FRIGIDAIRE FRS26H7C ACTUATOR
darlenek,
There is a trick of sorts. If you go to the bottom hinge of the freezer door you will find the same tube. Pull carefully and give yourself as much excess tubing to pull up through the door. Do not pull too hard or too much. This will give you more slack on the top end to work with. Once you get it reinstalled in the hole in the bracket, you probably will need to pull "carefully" back down through hinge to reinstall the dispenser bracket assembly.
I hope this helped you.
Please don't for get to rate me if I have helped.
supertechks
Jan 26, 2008 | Frigidaire FRS26R4A Side by Side...
WATER LEAKING FROM FRONT BOTTOM
try onscrewing top panel on machine...when machine agitaes strongly a hose my pop lose up from top.
Jan 22, 2008 | GE WBVH6240F Front Load Washer
LG front loader not draining properly
My LG front loader is stopping during the drain cycle (making a humming sound as if it is trying to drain, but can't....What can I do?
Nov 02, 2007 | Kenmore 44102 Front Load Washer
Bleach/softener dispenser
Try to push a plastic straw through the hole in the dispenser. This hole could be blocked with lint.
Oct 21, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Refrigerators Logo
69 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
