Insignia LCD new vertical line.
I have an Insignia NS-LCD32 tv. I purchased it in December 2007. It has worked great until this week, when it began to form a vertical line on the screen. When the line initially forms the cable picture wavers in and out (only in the vertical line- the rest of the picture is fine,) then changes to a solid color, then later a rainbow stripe. The line goes away after intermittent periods of time. It is also present when I switch to the DVD input.
Any ideas? I can't seem to find my receipt and I'm freaking out that my brand new tv seems to be dysfunctional.
  • 1153 Answers
SOURCE: Vertical portion pixelats then forms
Note
In some cases, there are minor defects in some parts of the screen. Points that do not light, points with
brightness different from that of the periphery, or points with color different from that of the periphery.
Some pixels will always be on or always off. Please note that this is not a malfunction. So what this says is that it's not the Plasma Cell problem, its more like a bad board inside. You will need more info like schematic and find out which area the bad part is in.
Posted on Jan 04, 2008
SOURCE: Insignia NS LCD32 standby light blinking off and on. No Power
I had this problem as well. Actually best buy just left my hosue to fix it. This is the second time they were here to fix it. The first time they said a part was loose. This time they had to replace a part.
Posted on Apr 01, 2008
  • 61 Answers
SOURCE: insignia ns-lcd32
Bubulica2000,
There is two reasons to have no display on your screen.
1.LCD panel itself is deffective.
2.Main board(mother board is Deffective)
How to recoganize the problem?
There is 5VDC going from main board to LCD invertor ( different model different pin so I am not able to tell which pin or Jack is)
Check while unit is ON mode it should read in between 3VDC to 5 VDC.If this volt is correct your LCD panel is Deffective.If no voltage appear in this pin Simply change Main board(mother board)
Dont forget to rate!!
GoodLuck
Dals123
Posted on Oct 21, 2008
  • 11 Answers
You can download the manuals from the Insignia website at:
http://www.insignia-products.com/c-14-lcd-televisions.aspx
Jerry
Posted on Dec 08, 2008
dgjtex
  • 405 Answers
SOURCE: i have the following tv, Insignia
Power supply board most likely, I have one just like it with the same problem in my shop right now.
Posted on Dec 26, 2008
Where is the location of T CON board on NS LCD32
Cheryl, I will post links to what the T con board looks like so when you remove the rear panel from TV, you will be able to compare and find it easily.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
INSIGNIA NS LCD32 Con Board LC320W01 SLA1 6870C 0142B 2L
Amazon com INSIGNIA NS LCD32 CON BOARD CPT 320WF01C SD Electronics
Mar 23, 2016 | Insignia NS-LCD32 LCD TV
Need to setup my tv #NS-LCD32 have no remote
You are going to need an original remote for that set.
Dec 20, 2012 | Insignia NS-LCD32 LCD TV
Color separation ~ Insignia 32" NS-LCD32
1. Unplug unit from wall for 3 minutes;
2. Press & hold Power button for 1 minute;
3. Plug in unit.
OR:
1. Unplug for 3 minutes.
2. Plug in unit.
3. HOLD Power Button as unit starts ... hold until the unit flickers on then off twice.
This effectively returns the components to factory specs, much like resetting a computer. It offers a *temporary* fix, lasting 45 minutes to hours. All depends on the unit.
Mom has an Insignia 32" with the same color separation problem, which worsens as the day progresses. Best results achieved while television is cold.
Dust in the unit could contribute to the problem ... try to keep the unit dust free as possible.
Sep 16, 2012 | Insignia NS-LCD32 LCD TV
Insignia ns-lcd32 has developed a vertical shadow.
Unfortuntly you have a panel that is going out. This is not cost effective to fix.
Apr 11, 2012 | Insignia NS-LCD32 LCD TV
Insignia NS-LCD32
Most likely either the main board (processes all signal) or even an issue with the power board (supplies wrong voltage somewhere).
In either case not cheap.
Mar 23, 2012 | Insignia NS-LCD32 LCD TV
I have a insignia ns lcd42hd 09 tv that on the left half of the screen has ghost images and sometimes vertical lines in it and i noticed when i shake it the screen goes back to normal but i have to do this...
I am also having a problem with my Insignia NS-LCD42HD-09. When I turn it on it is distorted and ghostly. It usually clears up within 10 minutes, but it can revert back at anytime. The television will be 3 year old this December. Does anyone have any advice (other than calling the Geek Squad)
Sep 07, 2011 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Purchased model NS-LCD32 second hand with no
Since you are getting the signal from the satellite, leave the satellite receiver ON and press input on the TV buttons until you get the signal back, wait 2 seconds after pressing the input button. Make sure the TV is on channel 3 if you are using the antenna input.
Let me know if you need further assistance.
Jun 13, 2009 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
172 people viewed this question
Top Televison & Video Experts
Electro Med Services...
