Question about Hampton Bay 24002 Ceiling Fan
Tahiti breeze fan
Our ceiling fan chain broke the one that monitors the off on and speeds what do we do? Model # 344 476
Buffalo12980
  • 625 Answers
SOURCE: how to replace or repair center fan speed pull chain
the chain goes into the switch and operates a round contact plate. just get a new three speed switch.
Posted on Aug 22, 2007
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
SOURCE: breeze ceiling fan not working
is the plastic relay inside
Posted on Jun 10, 2008
  • 323 Answers
SOURCE: we have a light kit on the hampton bay tahiti
Home Depot should stock them. If not, you should be able to order it online from them. Hampton Bay make fans exclusively for Home Depot.
Posted on May 26, 2009
woobie dog
  • 1273 Answers
SOURCE: need replacement globe for ceiling fan
Measure the diameter of the opening for the light to fit into the fixture. Lowe's/HomeDepot/W-Mart and similar carry replacements.
--W/D--
Posted on Aug 04, 2009
Where can I purchase a Jin you e70469 ceiling fan switch.
ebay 14 bucks
Jin You E70469 Pull Chain Switch for 3 Speed Ceiling Fan 4 Wire 1 2 ...
https://www.ebay.com > ... > Lighting Parts & Accessories
item 2 ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire -ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire. ... item 3 OEM ZING EAR ZE-208S 3 SPEED CEILING FAN PULL CHAIN CONTROL SWITCH E-89885 DR73 -OEM ZING EAR ZE-208S 3 ...
Exhaust Ceiling Fan Switch 2 Speed Pull Chain Blower Jin You ...
https://www.ebay.com/itm/...Ceiling-Fan-Switch...Jin-You-E70469...-/132376583704 Replaces Jin You E70469, Santa, Gardner Bender GSW-33. The control module provides two speed setting for your fan. 2 Speed Pull Chain Switch. 3" (7mm) Brass Chain. Spark Electric Components LLC. Width 11/16" (18mm). ' eBay!
Jin you e70469 ceiling fan switch Google Search
Dec 12, 2017 | Dryers
Hunter ceiling fan pull chain for fan broke
First write down which color wire goes in which slot on switch.Turn power off! Disconnect wires from defective switch by inserting a paper clip or something a little bigger into the wire connection.Then press the spring down and release the wire to insert in new HUNTER switch. DO NOT CUT WIRES!Call 1-888-830-1326 with model # to order the correct switch.
Mar 24, 2013 | Hunter (25417) Ceiling Fan
Chain broke on two hunter fans...where do I get kit to repair?
They should have chain switches at your local lowes or home depot.
Jun 16, 2011 | Hunter SPEED CONTROL. 3 SPEED Ceiling Fan
The chain that control on/off and the speed broke
mcdevito75 here, You"ll have to remove the cover that"s holding the switch. Hopefully you can just un-screw this cover from the ceiling and lower it down the chain that supports the fan from the ceiling, the fan motor itself is bolted to the ceiling beam so that"s not a problem. NOW!! to get a new switch It"ll have to be a 2 or 3 position switch, you may be able to match the switch up at a large hardware store, Home Depot etc. First I would check around and see if you can get the switch, check local hardware stores. The maybe hire a handy man/woman to do the job. If I'm accurate the job is not bad for anyone who is handy.
Jul 21, 2010 | Hunter Dryers
How to attach an on/off chain to a ceiling light- the original broke off somewhere inside. The fan switch is intact. This is one unit.
You need the little coupler thing that connects to the ball that makes up the chain. If you dont have the coupler ... you could get one at your local Ace Hardware store ... or you could just purchase a similar switch which would have the coupler on the chain.
Jun 07, 2010 | Leviton 1689-050 Pull Chain Fixture Switch
Fan chain broke and i want to put it back together
If the chain broke from inside the fan you will need a new switch $6 at any home improvement store and if its just the chain links you can buy a another replacement one. Make sure you tell them which switch is broken, fan or light so you get the right one and how many speeds if its the fan
May 01, 2010 | Hampton Bay 24002 Ceiling Fan
Ceiling Fan Chain Broken Off
You have to kill all power to the fan and start taking it apart till you get to the switch. There's usually just a bottom plate to remove. Sometimes lights. Replace switch and reassemble. If some chain is still connected to the switch you can add chain to it and won't have to replace switch.
Oct 04, 2009 | Dryers
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
How to replace or repair center fan speed pull chain
Jan 31, 2007 | Hampton Bay 48670 Flemish Pewter Finish...
Hampton Bay 24002 Ceiling Fan Logo
120 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
