Question about Compaq Presario sr1111nx 2.53GHz Celeron Computer (SR1111NXRB) PC Desktop
Helping Friend.. with above COmp
After Boot ti goes to C:\ with a dos Dir on HD and list 2.)+ Gb of space on C:\.. The SEt-up shows 80GB.H.D It should hav XP Home syst on H.D. (it's 80 GB H.D) where is the other space and is their a system hidden?? I cked for a D -Z drive and none except D: = the CD dr. Can I assume the XP system was wiped out by store or a former user orr is it hidden somehow on the H>D>?.
  • 92 Answers
I Is Another Partition Created By The Sytem. Leave It Alone.
Posted on Jul 02, 2008
Looking for a list of Dos Commands the old ones one c:/dir c:/dir/p and so on.
dear friend here is the link for dos commnads that your looking for .......http://www.computerhope.com/overview.htm.........rate me if its helps u.............
Nov 28, 2010 | Computers & Internet
How to format only C: Drive( in NTFS) in 160 GB Hard disk
It sounds like you are booting into DOS. Dos is an old system which does not recognize NTFS partitions, only FAT/FAT32.
What you need to do is use Hiren's Boot CD (download off google).
Use it to boot and use the NTFS4Dos utility first. Then start Dos:
Or once you boot into Dos mode with the CD, type:
A:\>NTFS4DOS
.............it will list harddrive partition letters.........
A:\>C:
The above may look different as A:\> can be any drive the cd assigns. C: is also an example as you will see your drive letter in the list of harddrive partitions detected.
If you need more laptop computer repair help please visit our Tech Tips page at http://www.laptopmart.ca
Mar 09, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Can't get computer to turn on (compaq presario 5000)
Either your Hard drive (hd) crashed or your hd cable or port is faulty. if your software is corrupt boot with a boot disk (assume you are using XP or Vista), press R on the blue options screen. you will be given a black dos prompt screen. Type in fixboot and type Y for an answer.
Oct 26, 2009 | Compaq Presario 5000 PC Desktop
I installed a new WD Cavier 500 Gb hasr drive ot
Your problem could be that the hard disk is not ACTIVE.
Boot up with a DOS disk (floppy or CD or USB) and run FDISK, select 4 to Display Partition Info. If the C drive does not have A under Status then press ESC and select 2 to Set active partition and then set Partition C to active.
Sep 06, 2009 | Western Digital Computers & Internet
Barracuda hard disk 80gb
More than likely, since you say you did a DOS install of the OS, you did not set the FDISK parameters to set your primary drive. Insert the DOS CD you used to format the system. Boot to a DOS prompt and run the FDISK command. It should have an option, I believe it is number 2 or 3 to "Set primary drive". Select your hard disk 0 as this drive and you should be fine at rhat point.
Sep 17, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
No booting
The problem is Operating systems are co-dependent on hardware.
If the motherboards, processors, ram, video adapters, etc don't match you would not be able to swap hard drives and expect to boot.
You could try pressing F8 on boot and try to access safemode.
If it does boot into safemode immediately it will want to reactivate windows.(because of all the hardware changes.
If it still can't boot, you may want to put the 80 gig in as slave to the 40gig and ghost the 40 gg hard drive over to the 80.
If you don't want to lose your data on the 80 gig then reboot with an xppro cd and reinstall windows in the same partition overlaying the installation on top of existing windows directory.
the new windows will have to be activated but all data will still be there.
Apr 15, 2008 | HP PSC 2210 All-In-One InkJet Printer
I have a 2000 1100 series computer with a 37 GB hard drive thats out of space. I ordered a 80 GB and installed it but it still only shows the 37 when i go the my computer icon how do i clone the 80 GB to...
jjfsrm,
to clone ur 80gb,u must have a cloning software..
and if u wanted that the 80gb is ur first drive,u should install ur operating system on ur 80gb..and of corz the jumper on ur 80gb hdd must be on primary position,and for d 37 should be a slave..
ur 37gb is the first boot thats why it is on the primary,but if u put ur 80gb into primary,ur computer will not function well coz it does not have the o.s..
Apr 07, 2008 | Computers & Internet
Installing 2nd Hard drive
Sounds like you have them both set to 'master' and is doesn't know which one to boot from.
Jan 15, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
Would a SCSI disk and a IDE disk work together?
This solution works on WIN98 and I don?t see a reason why it wont work on you If there is something that you were missing you might want to check with anther expert. This solution is a little complex so I hope ill be able to explain it well enough: 1. Make a boot disk so u can format and install windows. 2. Define the new HD as MASTER and hook it up to "primary IDE" 3. Disconnect the SCSI and pull the board out. 4. Reset the comp from the boot disk u made (HD is connected) 5. Get in "bios settings" and make sure that the new HD is defined as "primary drive" In the 1st IDE 6. Now, perform a FDisk on the new HD, define partitions, do a reset and format the HD Install the operating system you wish to have, make sure it works well. 7. install the SCSI board and its HD make anther reset. 8. now the comp is supposed to make boot and recognize the SCSI, it is possible that you will need to define your system configurations but for that, regretfully, I cannot guide you Although this is not necessarily have to happen. Good luck
Feb 23, 2006 | Cybertron Intel Pentium 4 2.66GHz Serial...
Compaq Presario sr1111nx 2.53GHz Celeron Computer (SR1111NXRB) PC Desktop Logo
47 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
