Question about Samsung C417 Cellular Phone
Cell tower signal strength
Is there a diagnostic code to read available cell towers and their signal strength off the phone??
    Brigadier General:
  • 7,752 Answers
Not as present
Posted on Jul 02, 2008
How do i recieve service? I can't call out or recieve calls, when i try it saids no sevice.
you have to be within a line-of-sight of a cell tower.
Your Phone has to be able to 'hear' the hello of the cell tower, and then you usually get an indication of signal strength, ('Bars') of how close you are to the tower.
Make sure the phone is fully charged, and try it outdoors in an urban area. Certain rural areas do not have enough coverage, and also your phone company has to 'turn on' that phone ID to make it work.
Sep 06, 2017 | Cell Phones
Tip
Siemens MODELS CODES & DESCRIPTIONS
*#0003*(secret code 8 digits)# All Siemens Phones: Service Provider Unlock
Siemens S25/C25
SP unlock *#0003*(secret code 8 digits)#
Show IMEI code: * # 06 #
Resets language to automatic selection : * # 0000 # then Green button
Pin Out
Data Cable schematics
Phone's connector pin-out:
1- GND
2- SB
3- POWER
4- NC
5- TX
6- RX
7- CLOCK
8- DATA
9- GND MIC
10- HF MIC
11- AUDIO
12- GND AUDIO
Siemens S1/S3/S3 Com
To view the software date and else with S3 com, S4, S4Power, Sony cmdx 1000e press with SIM removed *#06# and left softkey.
To view some other stuff with S4Power, Sony cmdx 1000e press with SIM removed *#06# and left softkey twice.
To view the software date with S3 com, S4, S4Power, Sony cmdx 1000e press with SIM installed menu 98 and left softkey twice.
ACTIVATE MONITOR MODE
Siemens S1/S3
Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 5553756, Hang-Up Button (Red Handset key)
Siemens S3 COM/S4
Menu, 9 (Phone Options), 7 (Phone Status - 8 on Some), Left Display Button (left MENU key), 7684666, Hang-Up Button (Red Handset key)
Note: Now Monitor should appear at the bottom of the Network Options menu.
MONITOR MODE
Pressing the right Display Button when in monitor mode will toggle into 1 and 2 modes
Pressing the right Display Button when in monitor mode will show a list of the six cells with the strongest signals.
Test Mode Indicators: (* = only available when call in progress )
CH Channel Number
RX Signal Strength (dB)
N NCC (Colour Code)
B BCC (Colour Code)
CI Cell ID (in Hex)
C1+ How long before phone does forced hand over. (see RX and RXAM)
LAI Location Area Identity. Display Network ID code (42F010 = 240.01) and MSC
TXPWR Transmit Power (dB)
RXAM Receive signal strength cut-off point
TS* Time Slot Number
TA* Timing Advance. Distance from tower in Km X 2
PL* Power Level
POWER table
PL: 5 6 7 8 9 10 11 12 13 14 15
dB: 33 31 29 27 25 23 21 19 17 15 13
Watts: 2 1.3 .8 .5 .3 .2 .13 .08 .05 .03 .02
LF* C1 value with continuous transmission from tower
LS* C1 Value with discontinuous transmission from tower
QF* Bit Error Rate with continuous transmission from tower
QS* Bit Error Rate with discontinuous transmission from tower
BER (bit error rate) table
QF/QS register: 0 1 2 3 4 5 6 7
% of bit sent: 0.2 0.8 0.4 1.6 3.2 6.4 12.8 25.6
Siemens S1/S3
Here's a trick to play Tetris, also known as Klotz on a Siemens S1.
Turn the phone on. Enter PIN. Before the telephone has logged in to the your GSM net do the following steps.
1: Choose F 9 (function settings)
2: Choose send own number and push the right button for choose.
3: Push 9
USE 2 as < and 8 as > , rotate the klotz with 5 and drop with 4.
[I have just heard from one of the programmers of the phone that Tetris was in the phone during development, but it was removed before it was produced. Apparently someone has the patent on games in mobile phones and Siemens didn't want to pay the licensing fees. It was either in Menu F-9-9 or it's not there at all.]
Siemens S3 Comfort
MONITOR MODE
The Siemens S3 Com series have a Monitor mode that can be activated directly from the standard user keypad. In order to activate this mode, you must enter the special access code currently programmed into the phone.
TO ACTIVATE MONITOR MODE:
Turn the phone on.
Enter the PIN access code on press OK. (Only if is enabled).
Press Menu. (Left top button).
Press 9. (Phone Options).
Press 8. (Phone Status) (May be button 7 in some phones).
You may see your IMEI Number
Left Display Button (Top left MENU key).
7684666
Hang-Up Button. (Red Handset key).
Note: Monitor should appear now at the bottom of the Network Options menu.
MONITOR MODE
Siemens S4/S4 Power
In phonebook under "Own Phone No." enter +12022243121 (which is the number to the White House) and you'll get a greeting from the people who programmed the phone.
MONITOR MODE
The Siemens S4 series have a Monitor mode that can be activated directly from the standard user keypad. In order to activate this mode, you must enter the special access code currently programmed into the phone.
Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 7684666, Hang-Up Button (Red Handset key)
Now "Monitor" should appear at the bottom of the Network Options menu.
CH Channel Number
N NCC (Color Code)
B BCC (Color Code)
CI Cell ID (in Hex)
C1+ how long before phone does forced hand over. (see RX and RXAM)
RXAM Reeceive signal strength cut-off point
PL* Power Level
Power Table
Siemens S6/S10
In Phonebook, store as your own number: +12022243121
Then you get the sun and two palms in the display, also a greeting message of the "MMI-team".
It has been said that the phone number is the number of the Capitol building in Washington, DC (but not sure).
Siemens S15 Secret Menu's
Press * -> # -> 7 -> 4 -> 3 -> 6 -> 3 -> 6 -> 7 -> * -> 8 -> 3 ->
7 -> 8 -> # ,press clear key to clear screen and return to
stand-by mode
press Menu, it will show additional menu
Menu 3.3.4 Band selection,
Menu 3.3.4.1 Automatic band selection,
Menu 3.3.4.2 select GSM 900 only,
Menu 3.3.4.3 select GSM 1800 only,
Menu 10 Engineering,
Menu 10.1 MS info,
Menu 10.2 software detail,
Menu 10.2.1 software version,
Menu 10.2.2 EEPROM version,
Menu 10.3 Test/production details
Menu 10.3.1 Hardware deta
Menu 10.3.2 production deta
Menu 10.3.3 Service deta
Menu 10.3.4 Mechanical deta
Menu 10.1.1 MS info on, then on the screen show these, for example:
FCN RXL C1 C2
642 011+11+91 -> PAGE 1
CID DSC CB
11211 045 000 -> PAGE 2
BCC NCC TN
000 002 00 -> PAGE 3
RXf RXs RQf RQs
00 00 00 00 -> PAGE 4
ATa APa Hn Hf
001 000 05 00 -> PAGE 5
DTU DTD HP CI
+ ? - - -> PAGE 6
MM CC RR
IdNS Nul Idl -> PAGE 7
on Aug 30, 2009 | Nokia 9500 Communicator
Why does screen read 'Searching' also have no dialling tone
Dear Pam,
The symptom you are having occurs only on a cell phone, and it happens when you phone is out of range of a tower.
Cell phones use signals that are relayed from towers, which is why many phones do not work at all way out in the country.
They are too far from a tower.
Most cell phones have some sort of an icon on the screen showing a thing resembling a tower, with some lines or bars along side it, showing you the strength of your signal.
The more lines or bars, the stronger your signal.
When you get too far from a tower, you will have no bars, and no reception.
God bless your efforts.
Dec 20, 2016 | Lands Phones
Sony experia E4 keeps on losing the network and how do i fix that?
That would be a signal problem not a phone issue. Contact your service provider and see if they can change your cell tower priority to boost the signal strength..
Sep 07, 2016 | Sony Cell Phones
What is solution of network not available ?
You are too far away from a cell tower. Buy a device that boosts the signal strength. This may not help you if you live where there are mountains or large hills.
Oct 18, 2015 | Cell Phones
NO NET WORK AVAILABLE
Data will only work when you have a Wi-Fi hotspot, or your signal strength is LTE, data on most carriers will not be provided with just a cell tower cell signal
Apr 01, 2015 | Cell Phones
How does a mobile network jammer work
A mobile phone jammer is an instrument used to prevent cellular phones from receiving signals from base stations. When used, the jammer effectively disables cellular phones. These devices can be used in practically any location, but are found primarily in places where a phone call would be particularly disruptive because silence is expected. A cell phone signal jammer is used to stop nearby cell phones from sending or receiving signals to and from the cell phone tower. A cell phone works by communicating with its service network through a cell tower or base station. Cell towers divide a city into small areas, or cells. As a cell-phone user drives down the street, the signal is handed from tower to tower.
Cell phone jammers block cell phone use by sending out radio waves along the same frequencies that cellular phones use. This causes enough interference with the communication between cell phones and towers to render the phones unusable. On most retail phones, the network would simply appear out of range. Most cell phones use different bands to send and receive communications from towers. Jammers can work by either disrupting phone to tower frequencies or tower to phone frequencies or both.
Cell phones are full-duplex devices, which means they use two separate frequencies, one for talking and one for listening simultaneously. Some jammers block only one of the frequencies used by cell phones, which has the effect of blocking both. The phone is tricked into thinking there is no service because it can receive only one of the frequencies. The jammer also stops Internet use through Wi-Fi network and even blocks Bluetooth connections. The cell phone signal jammer also puts an end to text messaging, so students cannot SMS each other, while the teacher is trying to teach.
Interestingly, jammers are life saving devices for military. Terrorists use cell phones to trigger explosives. Army can use a jammer to make mobile phones go dead, so that army technicians can deactivate the bomb.
Jan 28, 2013 | Cell Phones
No network in 1600 nokia phone how to solve it
It depends on the signal strength(ie tower location)of your service provider.Contact your service provider and if still remains the same you need to change your service provider(ur sim)with good signal strength in your area.
Oct 03, 2009 | Nokia 1600 Cellular Phone
Motorola v300
I don't have any way to test the signal strength. Have you tried it from different areas of town, are you even close to a tower? Try dialing *611 which should take you to your CSP and you would know if the phone even communicates with the tower.
MM85
Jul 26, 2008 | Cell Phones
Cell phone
Hai
It seems your area is having less signal strength or its far from the mobile tower of your service provider.
Its a problem for lots of people around.
Try change the service provider or move to the nearest of the tower location.
Rabby
Jun 16, 2008 | Motorola Mobility RAZR V3
Samsung C417 Cellular Phone Logo
94 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
