Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Black Ink won't work
My Brother 440CN keeps telling me that the black ink is empty and I just filled all of the ink with the same type of ink that it came with and it still doesn't work and also it won't let me Scan things. It was working fine and then things just started messing up. Thank-You Louis and Sandra Mason
E-Mail Address: sandra1962arl@yahoo.com Telephone: 802-362-3986
  • 2 more comments
  • Barb Jul 03, 2008
    My new black ink cartridge is stating no ink or no cartridge. Neither is correct. It was working fine until it was almost out of ink and needed replacing. I tried 3 different cartridges to no available. erqueenie
  • barrynk Jul 07, 2008
    Hi, have tried variouse permutations including a complete new set of cartridges all to no avail BL
  • david384 Jul 07, 2008
    This must be a common problem as I have had this on a number of occasions. One printer was replaced by Brother because of the fault and low and behold the replacement had exactly the same fault within a couple of months. Ink empty or no cartridge. I have got it working again after many attempts but do not know why it stopped working or why it started working again.
    I would be interested to know what Brother thinks the problem is.
  • Anonymous Jul 23, 2008
    I refilled my black ink manually once already but whenI refilled it this time I get the no cartridge error. I have cleaned out the the in cartridge chamber with a Q-tip to no avail. Please help WBenjamin3@aol.com
Here is what I did and it worked: I took an old cartridge, cleaned it out and filled it with computer cleaning solution (denatured alcohol?) that I bought at a big box store... when I did the clean cycle 8 times, the black finally came out... messy at first, with obvious particles. After 4 copies in black, the printer was fine. This is a pretty common problem, and the guy at the shop that is their first thing to do on pretty much every printer they see like this.... they buy cartridges loaded with solution for just this problem.... the rest of us suffer.
Posted on Aug 09, 2008
I own a mfc 440 cn aswell. and I have the same problem. I've combed the web for a while in search of the elusive answer to this particular dilemma and the closest thing to a solution came as I took a small flashlight and slowly inspected the inside of the cartridge holder where the cartridge physically connects with the printer, As I did so I noticed a small polyurethene tube that looked like it had some black ink clogged in it. I then kept searching the world wide web and found a connection with the ink in the small tube and the knowledge base on the brother website. it turns out that if the ink line gets clogged then the sensors will not properly read that a cartridge has been installed, just to add to that the printer may not always properly know whick ink line is clogged, which is why careful inspection is needed and to ulitmately fix the problem would mean taking the printer apart to manually clean the lines as well as any others that look dirty or clogged. And so for me my printer is still not working properly because I don't want to take the time to fix it, nor do i want to pay big bucks to have someone else fix it. hope this helps.
Posted on Jul 28, 2008
Go and buy a new printer
Posted on Jul 26, 2008
Indicates black ink empty when its not.
Try removing the cartridge and shaking it. Brother printers use an optical ink monitor with a float inside the cartridge. The float can get stuck sometimes and indicate incorrect ink level.
But keep in mind that printers often indicate 'empty' (on purpose) while there is still bit of ink left in the cartridge, to prevent running out of ink during printing. If shaking doesn't help, replace the cartridge.
Aug 25, 2014 | Brother MultiFunction Center MFC-440CN...
I am tired of this mfc 440cn not printing in black only mode if the colors are empty, even one. I want to print and work with the black only cartridge. How can I get it to print in that mode only. ie: ...
Yes! There is a way around the problem. On each ink cartridge there is a narrow section that a sensor in the printer reads to decide when the ink is low. Cover that spot with a piece of black electrical tape to fool the sensor and you can keep printing. This page has good pictures showing what to do.
Sep 11, 2011 | Brother MultiFunction Center MFC-440CN...
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Wont print
what are you trying to print in black? the best way to test out a black ink is to open word pad and type some thing random and print it and see if that works. if you have a all in one printer u might have 2 inks one color and one black in the printer
Jun 01, 2009 | Brother MultiFunction Center MFC-440CN...
Black Ink wont work.
I would take the ink cartridge out, grab some rubbing alcohol and a q-tip, and wipe the bottom of the cartridge where the ink gets dispersed. You should see color on the q-tip after just a few swipes. Return cartridge back into printer and give it a go!!
Please be sure to rate this solution.
Regards,
Joe
May 08, 2009 | Brother MultiFunction Center MFC-440CN...
Only black cartridge empty, but 3 full color crtrige say empty
Remove the color cartridges. On one end you can see the opaque
ink tank inside the main cart. housing. Cut a piece of black electrical
tape to fit around the three sides visible of the ink tank. Make sure the tape fits inside the housing and adheres to the tank itself. This makes the printer think your ink is always full but you can always tell when you need to refill/replace the ink(right?). Good Luck!
Dec 27, 2008 | Brother MFC-440CN InkJet Printer
I have a Brothers MFC 440CN . My Magenta ink cartridge is empty , how can I get the machine to print in black only ?
If you look at your printers software, there may be an option to "Print greyscale" or Print B & W Only.
Aug 14, 2008 | Office Equipment & Supplies
Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Feb 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
470 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
