Sound fades out
When i first turn on my system the volume is ok. the longer it is on it fades to near nothing. i have another system connected for another room and its volume stays on target. my system is close to 12 years old. i hope you can help. thanks, debbie
  • 682 Answers
Change volume control with new good brand one.
Posted on Jul 08, 2008
Cable for phillips subwofer computer system not working. Is there a replacement i can buy
switch on the speaker system remove the jack connected to your pc.give full volume / off volume,
just touch the jack pin from your finger.check the sound is coming.
if sounds well your speaker is ok.problem with pc.
if not in woffer ic has to be replaced.
Nov 07, 2013 | Philips MMS171 Computer Speakers
I have Fender Hot Rod Deluxe and Blues Deluxe amps.After the amps are in use for 20-30 minutes, volume just flat out fades to almost nothing. I have had it checked out and technician could not reproduce...
I want you to do a test. while using the amp plug a pair of headphones into the preamp out... note you will only hear stuff on one side if they are stereo phones and the sound may be fairly weak... while the unit is operating correctely then unplug phones and use it. When it fades out plug in phones compare the level when it was OK... If the preamp output fades lower as well, then we know problem is in the preamp section...
We can do a lot of troubleshooting without opening the amp.
I see nothing in the scheamtics that should be an issue causing this...
Since it didn't fail for the tech, think "what was different?". Are you connecting something else? Foot pedal? Temperature? :Loudness of playing?
Now what else is in common to these two units... AHA! The guitar...
If your guitar has a battery in it, the 20 to 30 minutes fading would correspond to a battery failing and then recovering after you unplug the guitar for a while.
Apr 23, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Sound volume knob does't respond
Chances are that it's a digital volume control.
The fact that it turns down again means it's probably fixable.
Open it up (switch it off first), and fetch a soldering iron. Look around for wires that go from the volume control and see if any are loose connections/broken wires etc etc. Solder these again, and it should work.
If you don't fancy this, take it to a hifi shop and they'll fix it for you (there'll probably be a fee involved)
Jan 13, 2010 | Teac DCD2831 Mini Hi Fi System w/3 Speed...
My ibm product key is....QC6Y-F93J9-H6YWB-J4R47-6DO8G...THE PROBLEM IS THAT THEIR IS NO SOUND COMING FROM MY CPU..ITS A BUILT IN SOUND SYSTEM AND ONLY SOUND IT MAKES IS BEEP FOR WARNINGS.IN CONTROL PANEL...
Plug in ONLY the regular wired speakers and ONLY to the green port on the back.
Make sure they are powered up and the volume is about half way.
Ok now you need to call up ether the sound card application or preferably the windows volume control from the bottom toolbar.
Click Open Volume Control.
A box with sliders in should appear. make sure that volume control, wave, sw synth, aux, cd player, line in
are all about half way and that none of them have ticks in the box at the bottom.
If any of those are missing click options then properties from the top left and put a tick besides any that were missing (nothing else)
Now close the slider box.
Put a normal music cd in your cd/dvd player on the computer and set it to play with windows media player.
You should now have sound out of the speakers.
Double check that EVERYTHING is ok.
If there is still no sound check the control panle for any hardware issues and rectify those
Sep 22, 2009 | IBM Computers & Internet
Sony Wega 32in with a volume problem
use it with energy of any shockwave
Jul 11, 2009 | Sony Televison & Video
The sound from my speaker fades in and out, but the handset works fine.
Since this problem just started, I would first check to make sure there is nothing stuck inside the mic's port. Also, if you have a fan on in the room, that can also cause your speaker to fade in volume.
I say both of these because if the phone thinks you're saying something, your speaker will fade in volume. Whether you're talking or it's just air noise, the volume will fade.
May 22, 2009 | Vodavi 30-Button XTS Telephone
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
Car Audio Fade
sounds like you got a bad stereo. it happens. i've i had the same thing happen, but the volume went up instead of down. check all the wires and make SURE they are all hooked up right.
Jan 10, 2009 | 2000 Jaguar Vanden Plas
Technics SU-g75 Amplifier. No longer any volume. Fuse is OK, display is fine, just no volume??
ALL speaker jacks must be loaded and closed for any sound to come out of this system. Missing one speaker, or one bad connection and you will get no sound or some will work and some will not. speaker wires need to go deep into speaker jack holes.
Aug 04, 2008 | Audio Players & Recorders
Ford 6000 eon radio unit - unit has no volume on fm stations, or occasionally the vlume comes on when first turned on and then fades after about 20 - 30 seconds. It finds stations on automatic search but...
Alas
This is a very common fault with these units, repair is a little expensive, as it's the FM tuner unit. It's an ebay job I'm afraid, pay around £45 for a second hand 6000 with code.
Aug 03, 2008 | Audio Players & Recorders
102 people viewed this question
 Grubhead
Grubhead
