Question about Apple iMac G5 Desktop
IMAC G5 Boot problems
I trying to diagnose this for vendor of mine. The iMac starts up but then goes to a black box screen that says I need to restart this computer, in three different languages. After restarting numerous times it still goes right to the same screen each time. I am currently running Disk Warrior to rebuild the Directory structure. Any other suggestions?
  • 1 more comment
  • Anonymous Aug 05, 2008
    how to boot windowsxp os
  • harold_20000 Aug 05, 2008
    how to boot windows xp opirating system  for replace
    imac a1058.
  • Anonymous Mar 16, 2014
    Hi i have Imac all in one G5 of 2004 when i boot up the computer the screen start playing with kind of pixelated but sometimes the screen is fine. some people on the web have suggested to use external monitor to see if it is a monitor or graphic card but i cant find the adapter which is mini vga to vga. when i save a screen dump picture on usb and open it from another computer the picture is clear any idea what the problem is please!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
This sounds like the HDD hard died. Sometimes you can hit "option" at the startup to see if the HDD is corrupt. If you see a file with a questionmark in it, then you need to reinstall the OS, BUT before doing this, restart it and hold "apple T" it make the HDD and the computer a giant external hardrive. Just get a firewire cable and backup the hard drive onto another system before reinstalling.
If you see a disk icon come up, there is definate directory problems as it still recognises that it has a hard drive. Disc warrior might fix it.
Posted on Jul 02, 2008
I need to unlock a iMac running OS 10.6.1
Step 1:
Turn off your iMac G5
Step 2:
Power it back on. Right when you hear the startup sound, hold down Command and S together. This will bring up a black and white terminal prompt.
Step 3:
If at this point, it asks for a password (firmware password), power back down the iMac, change the amount of RAM (remove one stick of RAM and leave the other in), turn the computer back on and when you hear the start up sound hold down Command + Option + P + R. Keep holding until it restarts again. Once it restarts again, let it boot up, then shut it down again and put the stick of RAM back in. This will reset the firmware password and should allow you to continue onto the next step.
Step 4:
Once you are successfully at the command prompt, type the following commands, pressing enter after each line.
mount -uw /
rm /var/db/.AppleSetupDone
shutdown -h now
Step 5:
That's it! Once you boot back up, you should have a brand new administrator account that you can use to access all files and remove other accounts.
Dec 25, 2012 | Apple iMac G5 Desktop
Imac intel blue screen
Can you start up in Single User Mode? Restart and hold down the command/Apple & the "S" key.
Apr 17, 2012 | Apple iMac G5 Desktop
How do i fix my imac computer if a black console screen doesnt let me boot up the computer
Hardwares problems maybe, it's better to take it back to Apple , they should be helpful.
Android 4.0 Tablet PC
Dec 26, 2011 | Apple iMac G5 Desktop
I have an iMac G5, system 10.4, that gives me a white screen with the apple logo and lots of fan noise when I try to boot up. What's going on?
It is having difficulty with the system folder, try starting with the left hand shift key held down, if not boot from CD, select language as if you are going to do an install, on the next screen the top menu has a utilities folder, in this select disc utlility, select your hard drive and then select repair, let this work and if OK or repaired (if it says it cannot repair then you need a repair utlity like DiskWarrior) then repair permissions, this can take a while with a big HD, then in utilities select start up disk and select your HD and restart.
Dec 13, 2010 | Apple iMac G5 Desktop
G5 stuck on white screen
Have you got the Snow Leopard boot disc that came with your machine?
Pop it in the iMac, restart the computer with the "C" key held down. That will boot the imac to the DISC. Once there go to the top menu and run a Disk Utility Repair on the hard drive.
Let me know what happens, I can help with this ;)
Nov 02, 2010 | Apple 24" iMac Desktop
I'm having some problems with my Imac G5. It crashed a long time ago, so i added a new hard drive, and am now attempting to install the OS again. i believe it's 10.3. It will install the first install...
I have to assume that you mean you REPLACED the hard drive, as there is no room for two drives in an iMac.
If I had this machine in my shop, I would start by resetting the SMU (there are several models of iMac G5, each with a different procedure) and then resetting the PRAM at boot by holding down command-option-P-R until I got the boot chime three times. Then I would boot it from an external OS drive and run DiskWarrior over the internal drive to straighten out any file system corruption. Or, if the drive is brand new, I would erase and format it with "write zeroes to all records once" just to verify the drive and map out any bad blocks.
Then I would try the installation again. When the machine rebooted, I would hold down command-V as I heard the boot chime, just to watch the console messages in real time and see what appears at the point of hang, assuming it continues to hang. From that point, I would be able to diagnose more about where to look for the problem.
Thanks for the detailed report by the way. I apologize if my plan of action involves a lot of accessories you don't own, but the fact is you don't have a trivial problem to diagnose here.
Oct 29, 2010 | Apple iMac G5 Desktop
Imac G5 will not boot up.
When you boot up g5 hold down the command button (apple logo) and the letter s at the same time to but the g5 in single user mode. When it boot in single user mode type fsck -f so it can check disk on the hard drive and repair Mac OS X. After it done doing check disk type exit and see if it will boot up regularly.
Mar 09, 2017 | Apple iMac G5 Desktop
IMac Intel wont boot
It sounds like you need a new motherboard.
May 06, 2009 | Apple iMac G5 Desktop
IMac G5
you need to contact apple support for the same
Jun 23, 2008 | Apple iMac G5 Desktop
Apple iMac G5 Desktop Logo
1,073 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
