Question about Refrigerators
Refridge hums then you hear a click,lights dim like the compressor turned on then another click a few seconds latter.this same cycle repeats .evaporator and compressar fans stay running.
  • 481 Answers
It sounds like a bad:
  •   start switch (on the side of the compressor) or
  •   compressor itself
  • the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
  • so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Posted on Jul 02, 2008
Ran out of gaz and cant start the car anymore how do i fix this thanks
You mmay have to cycle the ignition several times. That is, turn it on for a few seconds, and then off, and repeat. Have someone stand at the fuel cap, and listen to make sure the pump is running for a few seconds when you turn the key. They should be able to hear it hum for a few seconds, and then stop.
Feb 24, 2013 | Cars & Trucks
Ge refridgerator model sts16abserww, stopped cooling, down at the compressor I hear a slight click then wait a few seconds and hear another click (NO buzz between clicks), then wait a few minutes and the...
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 14, 2011 | Refrigerators
Fridge/freezer doesn't work although light on
Hi David and welcfome to FixYa. I am Kelly There are a few things to try before you go replacing parts.
1. after the unit has sat with no power for about 30 minutes plug the unit in and listen for an attempted sart on the compressor. An attempted start will only last for approximately 40 seconds. During that attempted start listen to see if you actually hear the compressor turning. If you hear it turning and it again shuts off wait another 30 minutes and try it again. (On a unit that has been in storage for more than 6 months it can take a few attempts to get it going.) If it just hums and does not move then your compressor is locked and as it attempts to start you will notice a slight dimming of the house lights. Don't give up on it right away... do about 4 cycles of the plug it in.. listen for the 40 seconds then the CLICK of the compressor thermal overload switch. If your not hearing a CLICK after 40 seconds or so then there can be a compressor PTC relay / thermal overload (KliXon) problem or the possibility that the run capacitor has failed. After all of these have been checked out then you start looking at controls and power. Give it a few more tries to see if it takes off. If it does not then just repsond here and someone will help you.
Thanks for using FixYa,
Kelly
Apr 10, 2010 | Liebherr KDPes 3142 Premium
There are power surges every few minutes that last for a few seconds. Other lights on the same circuit dim. This is really a Hampton Bay HB40 which I understand is the same unit. What can I do?
it sounds like the compressor is trying to start. if it hums and clicks then either the compressor relay or the compressor is bad. find the compressor and tap on the relay cover with the end of a screw driver. if it starts then change the relay
Dec 03, 2009 | Fedders RDG40 Dehumidifier
Amana fridge/freezer compressor problem
Unplug unit.
It's not possible to tell which without replacing the starting system. Hard start kit would be fine. RCO410 is common. If it starts the unit the next check would be an ampmeter clamped onto one of the power leads. The ampmeter for refrigerators of that age may read around 2-5 amps when running. If it's much higher than 5 Amps after it's running be prepared to replace the compressor. Maybe it won't quit today...but it won't last with high amperage. If it doesn't start with this kit you need compressor.
Sep 08, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerator and freezer not cooling
Hi, If the lights are dimming, the compressor is drawing to many amps when trying to start. If the refrigerator is under 5 years old, I would check into the warranty. If it is over 5 years, You will be better off to get a new refrigerator.
I hope this gives you an idea on what is happening.
Vic
Jun 27, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
Refrigerators Logo
1,007 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
