Question about Samsung Compact MiniDV Digital Camcorder
Cassette tape When I put the mini cassette in the camcorder, it closes and then opens up again and will not close with a tape inserted, but will close when empty. What could be the problem? and can I fix it myself?
  • 3 more comments
  • tarakates Jul 02, 2008
    When I put the mini cassette in the camcorder, it closes and then opens up again and will not close witha tape inserted, but will close when empty. What could be the problem, and can I fix it myself? I did not drop it or abuse it in any way.
  • Anonymous Nov 30, 2008
    I cant close the tape compartment it whirlls a bit and then clicks back open
  • gaurangmarin Jan 05, 2009
    Even after placing the tape inside, it keeps on saying "No Tape" and ejects it. Samsung VP D352 Camcorder. If I press it too much , sometimes it works. But off late it is not working even with that.
  • aurassique Jan 09, 2009
  • tasby12 Jan 19, 2009
    I cannot get the camera to close with a tape inside, it only closes when empty.
Mycomputer cannot see the camera in usb
Posted on Aug 31, 2008
How do I fix the tape holder system on my camcorder? The door won't lock, and the cassette won't get inside the compartment.
hi,
is it close without a cassette ? if so the reel sensor in the cassette compartment may be faulty. if the head drum not rotates the cassette drive will not work correctly, if so please loosen the head drum with a plastic rod or some tools like that. do not put your finger in hence sometimes will jam your finger. remember don"t touch the scanning chip of the head.
Oct 26, 2015 | Panasonic Palmcorder PV-GS12 Mini DV...
My Sony DCR-TRV33 won't accept a cassette. It will close itself up without a cassette tape in place, but not while a cassette is inserted. I have tried several different tapes, so it is not the cassette.
Hi wnwatkins3,
Have the same problem here. Bought my TVR33 in 2003, and its still
a good cam with 1 megapixel. But since 1 month the tape won't load. I can insert any tape in the cassette, but it won't close. Without a tape it closes fine.
My only option is to send it to frsbenelux to fix it for a few hundred euros. Hoping to find a solution on the net, i will share with ya.
greetz Ed
Jun 29, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
When I insert the cassette into the camera it won't close.
Try the following link to troubleshoot this issue:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C190805
Aug 08, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Wont load tape
HI, this is a mechanism fault beep you are hearing. the mechanism and load motor is damaged. you will need to send this unit to the Handy cam repair depot for this repair. you will need a new load motor and loading dock mechanism as well.
Jun 03, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
DCR-HC42
  1. I'm having the exact same problem. It wont accept the cassette...only half way then errors. It will close fully without a cassette as well. hmmmmm
Comment by Guest, posted on Apr 02, 2008 Load cassette, turn it on, then message says re-load cassette. Door to cassette compartment only works half way. After fiddling with power, can get the cassette door to open and close all the way, but not with cassette. Tried several brands of cassettes, no joy.
Mar 09, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
The cassette holder isn't closing......and the tape is not loading
Hi
See if this works--If you are on battery there may not be enough power .Charge the battery or use the the mains power through the transformer and see if it works.
Hope this helps
Jay
Nov 17, 2007 | Sony DCR-PC55E Mini DV Digital Camcorder
Cassette holder does not close
Try inserting another tape first. If the trouble is still there,Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Aug 20, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Cannot insert a tape
This just happened to me today, apparently in my case it has something to do with condensation inside the camera, I don't know if this applies to you but at the moment I have the cassette slot open and in the sun, hopefully it will help, two hours apparently should do it. Give it a go, it can't hurt, I wouldn't put the actual cassette in direct sunlight though, so make sure you take that out. Hope this Helps
Jul 01, 2007 | Canon MV850i Mini DV Digital Camcorder
Samsung Compact MiniDV Digital Camcorder Logo
172 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
