Question about TruTech PVS31170S1W 17 in. LCD Television
TV will not come on
I had a power surge and my tv will come on I think that it could be the fuse could you tell me the on I would look at all the location to fix my tv is to far away a live in north Minneapolis, MN red light is on, but the tv won't turn on. Replaced batteries in remote. Unplugged & plugged tv back in. ...Nothing.
    Brigadier General:
  • 6,966 Answers
It is unlikely to be just a fuse since as you posted, the red light is lit. Other than a reset (unplug for some time/hours), there is no user easy diagnosis/repair. DIY (do-it-yourself) would require at least some familiarity with electronic components and circuitry, use of a DVM and a soldering iron and access to a service manual or at the very least a schematic diagram with voltage readings. Perhaps it would be to your advantage to seek the services of a qualified professional to save you time and effort.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 02, 2008
  • 2,071 Answers
Your tv parts is ok,...only the solder joint is crack or cold thats why function abnormally ,only the standby light is lit because of the voltage is trap cannot passed to oscillate the system ,.due to disconnet the joint of the parts is need to resolder or reheat the joints ...the power supply section, horizontal section , vertical section and to the microprocessor ic ,so it will be better again.
Find a tv technician to do the works ..in order to avoid high voltage shock this not cost too much because only reheating works...
  • 6,487 Answers
Hope it not serious. Do a hard reset and try again. You can do the reset by unplugging the power cord for a couple of hours; then power it up again.
If the reset does not solve the problem then it is serious! The blinking light means the set has gone into protection mode. This is when the system has detected a short or something that is drawing excessive current. The protection system shuts down the main power supply in order to prevent further damage to the set.
In the majority of cases the blinking light means the main power supply has gone bad, but it could also mean other things as well.
Repair is usually on the expensive side, unfortunately. You will need to find someone who can go inside the set, take some measurements in the power supply and track down the ailing part of the set.
Hope that helps........
No power indication at my tv
try this first
How to Reset TV After Power Surge eHow
sometimes there is more than one fuse on power supply
Jul 24, 2015 | Televison & Video
50"sony led no picture or sound after power surge
I think you just have to switch on the TV again. the switch number 5 on the right side of the TV should be pressed once.
Jul 27, 2014 | Sony Televison & Video
Seiki sc-601gs tv will not turn on
Most tv's have a fuse near the power cord right inside the back panel. Good luck
Mar 15, 2014 | Televison & Video
Tv will not turn on with remote or botton on side
the tv was on a surge protector line, what i notice that i had it plug in a cheap surge protector when i pull from wall i notice the adapter were burn and the cheap surge was burn at that time when i go to cut tv on i could hear a surge like sound. i tried to put it in another plug it wont come on, i open back of tv looking for fuse i could not find it or reset button can solve this problem i hit input button on side it still wont come on. i do not think there is any problem with picture it has something to do with power.
Aug 17, 2011 | iLO LCT32HA36 Television
I had to unplug my tv today (actually the TV is plugged into a surge protector, so I unplugged the surge protector.) when I plugged the surge protector back in the TV wouldn't go on (acts as if its...
There should be a surge release button on the surge protector to bring the protector back to normal (should be red in color) Some surge protection devices have this option so just check if your s has it. If that is not the case than I think that you might have blown a fuse in your TV.Might just have to open it up and change the fuse within with the same ratings, but please be careful because do have high voltages so get an experienced technician to do this for you.
Good Luck.
G.
Jun 29, 2011 | Televison & Video
Because of a power surge, i think i fried my tv, are there any safety procautions inside that might protect the tv, such as fuses, or would it just ruin the tv?
there are fuses and MOV's to protect for surges.
mov is metal oxide varistor, a resistor that shorts out when the voltage rating is exceeded causing the fuse to bluw.
always right after the fuse on the circuit board on the powersupply board
Mar 30, 2011 | Sony KDL32L5000 32 in. LCD HDTV
We had bad weather lights went out ..had tv plugged into a power surge plug ...now that i have power back tv wont come on
Some will say a surge protector will save electronics. I can tell you they may not help at all. A power surge is extremely fast and can over ride the surge protector. If you think you can repair this TV, I would certainly remove the back cover and inspect. Occasionally the only problem for repair is to replace the main fuse. Remember, this happens rarely. Most cases after a surge the TV will need to be inspected by a TV tech. Almost anything, in a power surge will damage the TV. There is no certain area that will not be damaged, expect it any where. Thanks for asking and show all hands of support!
Mar 30, 2011 | Philips 47PFL3704D 47 in. LCD TV
Tv does not turn on after a thunderstorm and several attempts at power returning to the home. The power went on briefly then shut off several times, now the television will not turn on. We had the tv...
Check the main fuse in the power supply, the TV also has small surge protection devices (MOVs) installed after the fuse, any surges the come along and big enough will cause the main AC fuse to blow. When you surge protector, EVERY connections must go through the surge protector, for example, the AC cord of the TV is connected to the surge protector, the cable connection did not go through the surge protection, the surge then can get to the TV through the cables.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 21, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
The tv died
My ilo Does This Every time We Have A Power Outage Did You Reset It????? Unplug The Tv And Hold Down The On Off Power Button For 30 Seconds Then Release And Plug It Back In And Check.
Jan 07, 2009 | iLO 3200 32 in. LCD Television
Sony Bravia LCD TV is tripping the fuse in the house
These things draw a huge surge current when turned on. What size fuse are you blowing? These things can surge 10-12 amps on turn-on. What about a fuse with a reset button. They will take alittle more surge before they go. Don't matter about the insignia working before because the cheaper sets tend to stay powered up more when off....thus not surging on from a dead start. Could you try a different plug on a different circuit/fuse? and see if that makes a difference. If you have a 15 amp fuse, then your pretty close with other stuff plugged in. What size is your service? Do you still have an original 60 amp box with screw in fuses? Is it an old house?
Sep 08, 2008 | Sony Bravia KDL-40S4100 40 in. LCD TV
TruTech PVS31170S1W 17 in. LCD Television Logo
71 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
