Boot problem my notebook won't start with an xp os... need to fix it but won't boot thru an external cd drive (there's no internal drive by the way).... can anyone suggest what to do? i've tried F2, F8 and F10 and selected boot source but still won't work.... please help me, i need this for my studies...thank you
  • kaloi817 Jul 03, 2008
    its toshiba portege 344oct, F10 displays advance boot options but all options won't work... it stops.
    it worked for me for a long time until this thing happened....xp os disk won't boot as well (external cd drive).... thanks for your concern...god bless!
  • Niels Boehme May 11, 2010
    What model notebook do you have? Manufacturer and model number.
    What options do you have under boot sources?
    How far do you get during the boot process. Can you go safe mode, for example?
    Do you know if you installed some sort of software or driver before this happened?
    Sergeant:
    Champion:
  • 306 Answers
Try booting up with a xp os disk
Posted on Jul 02, 2008
My laptop wnt boot up no matter safe mode or the other start menu's what am i to do
Do you have an external CD or DVD drive to plug into it? If so, and if you have a Windows installation disk, you can boot from the disk and do a chkdsk scan on the drive to make sure the drive doesn't have errors. If the drive doesn't have errors, you'll need to do a rebuild of the operating system.
If the drive did have errors and chkdsk says it fixed them, try booting into windows again.
If it still won't boot, do the OS rebuild.
If it reports there is no hard drive, you've got bigger issues and will need to have the unit repaired.
Jul 07, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hi, I'm installing widows xp in HP Compaq nc6220, but after setup loading files the mesaage (bottom of setup screen) "Setup is starting windows", then it did'nt contiue the installation,...
1 many times the the CD cant load as the files in the CD are corrupt or the CD is not read by the drive corectly...so get a new WinXP CD
2 try an external CD drive if your BIOS alows to boot from USB drive....(connect the external CD drive to the USB and make necessary changes to the BIOS boot seq in the BIOS screen...
BIOS screen can be enabled by pressing the F1, or F2 or the Del key as on as you start the PC
3 once in BIOS screen look for boot seq and change the boot drive to the foll
1st boot device - USB CD / DVD rom drive
2nd boot device - internal CD rom drive
and so on
if you can do the above then try the WinXP installation using the external CD rom drive....
else there is a little complicated method of using a pen drive thru USB (will discuss that later) provided your BIOS alows booting from USB
for more PC related issues visit my website
reg
kris
suresh_krishnan1961@yahoo.com
www.sureshayyar.110mb.com
May 18, 2011 | HP Compaq nc6220 Notebook
How can i reformat my Blue IL1 notebook?? i think it has a virus... it doesn't continue loading, it restart when it reaches the windows xp logo... thanks for the help
Hello, you relly need to reformat it you can use an os installer suach as linux or windows using a usb flash drive, but you have to transfer the installer cd to the usb drive by using the wintoflash application. Once you've done that now you can reformat and install os in your notebook using your usb flash drive.
Sep 12, 2010 | CTL IL1 Notebook
Samsung notebook states cannot start as windows file missing and to use disc to repair, however as it is a note book there is no disc drive or disc.
You need a repair/reset CD, and you may need an USB external drive to read it if yours doesn't work or isn't available. The CD may be obtained by Samsung tech support. For Windows XP and Vista you just select OS installation and hit 'R' for repair.
Alternatively you can note down the name of the missing file, locate and save it on a USB key from a computer with the same OS version, and boot the PC using Universal Boot CD (UBCD). Then just copy the file where it should be. Unless you're short a specific driver or VXD, most other files are drop-in compatible.
May 31, 2010 | Samsung X05 Notebook
XP is corrupt and needs re-install. DVD drive is dead. Can I boot from a USB stick and are there specific settings (I tried using default settings for WinsetupfromUSB - boots to my Dell D530 - nothing on...
it would be easier to use an external dvd/cd drive if in case your internal dvd drive is defective. thereon, you can start re-installing the XP OS using the external dvd/cd drive. hope this will help your problem. thanks
Feb 08, 2010 | Toshiba Satellite A75-S229 Notebook
Toshiba tecra m2v s330
Try borrowing a compatible HDD instead of buying a third one for testing and check if the same error exists. Try also using an external DVD drive to see if your internal CD-ROM is defective. Try also using another Windows XP CD installer. You can also use other OS installation CD to check it. Otherwise, there is something wrong with your lappy's motherboard due to tear and wear, heat, vibration, misuse and shock.
Mar 20, 2009 | Toshiba Tecra M2V-S330 Notebook
Ways to load OS
External Floppy disk drive or External CD/DVD drive. Might be easier to just replace the internal drive.
Feb 17, 2009 | Dell Inspiron 4000 Notebook
Problems installing xp sp2 from an external cd drive
a external cd rom hooked to a usb port with no os is not goin to work u got to find a internal one that will work with ur pc then u can install xp sp2 Looking To Help Shaun
Nov 15, 2008 | Acer Aspire 3000 Notebook
I don´t have internal cd, only external(usb)
You will need an internal CD drive for the machine in order to load XP. If it doesn't recognize the external in the boot menu, then there is no setting to get it to.
Jul 23, 2008 | IBM ThinkPad 600E 2645 Notebook
Laptop won't boot from external CD drive yet internal one is unresponsive
if you want to boot a cd e.g windows xp os disk then you have to go to the bios by pressing del or f2 or f8 ot f10 depending on the motherboard you use. try to find boot option -> boot priority or first boot device.if you find boot priority then select cdrom as first priority . if you find first boot option then also select cd rom. sometime if your disk is not bootable then it won't boot.
Jun 20, 2008 | Computers & Internet
Computers & Internet Logo
249 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
