Question about Compaq Presario 5000 PC Desktop
Diskboot falure insert systemdisk press enter
Thats the error,can get to the bios need to know how to get this computer started because it will no start
    Scholar:
  • 160 Answers
For solving your problem do the following
1. Check that the power connectors and data cable are connected properly
2. Replace the Data Cable with another
3. Replace / Change the power connector
4. Remove the HDD and check it by connecting to another pc
Let me know! that your problem is solved and rate me as Fixya
Posted on Jul 03, 2008
    Genius:
  • 2,785 Answers
Plz check with new data cable, if the problem persists then your hard drive needs to be changed
Posted on Jul 02, 2008
Mainboard GA-G31-ES2C Warning: Backup BIOS checksum error BIOS Auto-Recovering...
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen to press delete to enter setup
Jul 23, 2011 | Gigabyte GA-G31M-ES2L Motherboard
My computer will not boot it keeps restarting. Its saying it can not load hive file or its log or alternate. Its corrupt absent or not writable. Can someone help? Iwas thinking it might be the bios but not...
Open cpu cabinet and reattach the RAM memory.
Reconnect both connection to harddrive.
Most of the time this error comes because of RAM need reseat into it's position.
Then check if you still face same issue then you need to fix error on harddrive.
For that when you power up the computer press F8 key then enter into safe mode and if you able to enter in safe mode.
Then first remove temp files from computer.
Go to start->run or press windows key + R key then you can see run type in run "%tmp%" then press ok then delete all temp files then type in run "prefetch" press enter delete all prefetch files.
Type in run "chkdsk /r" then press ok then press "y" then restart computrer then it fix error on harddrive.
Also scan computer with updated antivirus then it works fine.
But if you are not able to enter in safe mode.
Then you need windows disk for that insert that disk into rom then enter in bios and set first boot device as cd/dvd rom then save settings and exit from bios .
Then it boot with that windows disk.
Then enter in recovery console then type "chkdsk /r" then it fix error then check if still same then again boot with disk.
Then follow the procedure on screen and choose options are when it ask for "Repair previous windows" .
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 18, 2010 | Dell Dimension 2400 PC Desktop
Laptop will not start up the toshiba oening page shows on screen then the screen goes blue with only the cursor showing
Feb 17, 2010 | Toshiba Satellite Pro L300 Notebook
Need help please and thank you
For that you need to fix error on harddrive.
For that You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Feb 05, 2010 | Compaq Presario 5000 PC Desktop
MOTHERBOARD PROBLEM HELP....THIS IS MY 3RD POST ABOUT THE
You have a corrupted bios file or files. This is what the checksum means. You need to download the correct bios onto a floppy disk. That floppy disk needs to formatted as a system / startup disk BEFORE you copy the bios files to it. Then put the floppy into your floppy drive, turn the pc on and try to get into the bios screens. If the keyboard error is preventing this, go to the mainboard manufacturers website and check the correct manual for the board looking for the procedure to recover from a bios failure. If this board if no older then 5 yrs, it should have this feature. Follow the recovery procedure to rewrite your bios. When that is fixed, undertake the bios update procedure. ONLY do this if you fully understand and accept the risks otherwise, take it to your local professional. If your board does not have the recovery feature, replace it !!unless you are able to replace the CMOS chip with one which has the correct bios burnt onto it. As most modern boards have CMOS chips glued and soldered to the board, this may not be an option..If the bios chip is socketed, contact your local computer shop, or the boards manufacturer to request a replacement. Your issues all arise from your bios issues so fix that and all should be well..
Dec 12, 2009 | Foxconn WinFast K7S741MG Motherboard for...
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
My W3410 eMachine desktop won't Boot at all!!!!!!
Sounds like a harddisk failure unfortunately. You might want to boot your original OS disc and perform a repair (non-destructive), this may either confirm an HD crash or fix the problem.
Jul 03, 2009 | E-Machines W3410 PC Desktop
Disk Boot Failure
you need to select ur harddisk as the first bootable device., that option is in BIOS settings. When switch on the system before loading OS press F2 to get the BIOS settings and select boot option in the menu and select your harddisk as the first bootable device. Restart the system now. If the same error is displayed your harddisk data cable may be failed or your harddisk may be corrupted...
Jul 11, 2008 | Computers & Internet
Primary slave drive fails(black screen)
the major problem is that it is telling me diskboot failure insert system disk press enter
Jul 02, 2008 | Microsoft Windows XP Professional With...
Disk boot failure
there are multiple reasons for this
1. hard drive failure
solution: replace hard drive reinstall operateing system
2. computer is not set to start from hard drive
solution: enter bios and set computer to start up from hard drive
3. Hard drive not detected or cable loose.
solution: check are the hard drive cables connected well. try disconnecting and then reconnecting.
4. Hard drive file system corrupted and unable to find start up files
solution: you can use the windows xp to enter repair console and try to correct the corruption with chkdsk command if that doesnt work you have to reinstall operateing system
Apr 04, 2008 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
22 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
