Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
JVC AV-56WP74 56
I purchased the STK392-110 ICs from service manual. I had read in an earlier post that it would come with instructions. I didn't receive any. Also what type and where can I buy a soldering gun that will do the job?
Can you help me?
Thank you,
Mattie
  • Matties Jul 07, 2008
    Guru,
    Thanks so much!! It worked perfectly!! Beautiful picture!! I went to Radio Shack and bought a 30 watt soldering iron, solder, heat sink and desoldering tool. My hubby installed them today.
    Thanks again,
    Mattie
  • JVC Master
  • 8,617 Answers
Radio shack has desoldering irons cheap. Send service manuals a email, they must have forgot. they will email the instructions right out to you and that should outline all that you need to do the repair
Posted on Jul 02, 2008
  • Sonny Berry
    Sonny Berry Jul 07, 2008
    Youre welcome. It feels good to have fixed your own TV and not have to pay alot of money to a repair tech doesnt it?
Whats the part number for convergence chips on jvc av-48wp74
There are two of them that need to be replced as a set. They are both STK392-110 Convergence Ics you can get the original oem Ics from www.tvrepairworld.com they are listed under the Integrated Circuit catagory you only need the one set. They also have the convergence repair kit listed for your model under the JVC repair kits the kit has both ICs all 12 resistors and the CD with step by step repair instructions.
Oct 17, 2012 | JVC AV-48WP74 48" Rear Projection...
I have a jvc model av-65wp74. my green convergnece wont align at all
Convergence ICs and resistors need replacement. Very common issue. The AV48WP74 -AV65WP74 convergence repair kit from www.tvrepairworld.com has the 2 ICs and associated resistors plus the CD with repair instructions.
Aug 16, 2011 | JVC AV-65WP74 Rear Projection Television
AV-56WP74 the convergence is off. blue is way out!
You will need to replace the Convergence ICs and resistors you can get the JVC repair kit called the AV48WP74-65WP74 convergence repair kit from www.tvrepairworld.com which contains the ICs , resistors and the CD with instructions,
Sep 23, 2010 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 Convergence problem. I've read about convergence problems with the JVC AV-56WP74 and I am pretty confident my set needs the convergence board repair. You mentioned to another user that you...
Hi Dave
Thanks for using FixYa. If the issue is with the failed convergence (STK) ICs which needs to be replaced then, it’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black/gray heat sink and also check theresistors as if they are short the ICs might blow again after sometime. Please check this picture:
And yes you are right there are repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 17, 2010 | Televison & Video
JVC I'Art AV-56wp74
A repair facility will charge 400 to 600.00 for the repair. Or you can repair it yourself if you can solder. As both convergence ICs need to be replaced. They are STK392-110 you can get replacement ICs at the following link with free instalation instructions with pictures so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Jun 15, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC AV-48WP34 convergence issue
Chances are there are other resistors open
Jun 01, 2008 | JVC AV-48WP30 48" Rear Projection...
Jvc
I dont have them the following link provides them to their customers who purchase new convergence Ics.
May 24, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV 48WP30 projection tv bleeding problem
You need two STK392-110 Convergence ICs. You can get repalcements at the following link, and they will provide free instalation instructions with picture so you can do the job yourself. Heres the link.
Convergence Issue
As I mentioned in the last post. I dont have the step by step. The site that sells the replacement ICs include the step by step instuctions with the new ICs. Heres the link.
Mar 29, 2008 | JVC AV-56WP74 56" Rear Projection...
Problem with A JVC projection television
The convergence ICs probably have a cracked solder joint on the foil side of the circuit board. Re-flowing the the solder would help. I will always replace the convergence ICs when doing this job. The labor remains the same and you will have to pay a few extra bucks for the parts. To fix this yourself, you will need to be able to identify the two convergence ICs,in this model they are in the front of the set, have a basic knowledge of electronics and be able to use a soldering iron (Use a dielectric compound when changing any IC attached to a heat sink). You will also have to do an alignment through the service menu. To find a servicer in your area go to: http://maps.jvc.com/cAscList/ It's the JVC servicer locater site. Call the repair shop listed and ask them what they charge for a convergence job on your set. That should help you decide which direction to go. Hope this helps.
Apr 22, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
