Question about Sansui Audio Players & Recorders
Model 2000 dial cord stringing - Sansui Audio Players & Recorders
How do I use SKU: 15112 timer
GE 15112 timer manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15112-Manual-eng-spn.pdf
Same as Tork 652A manual
http://waterheatertimer.org/pdf/651A-652A-manual.pdf
Made for permanent outdoor usage. Outdoor usage only.
Timer has 2 grounded outlets located bottom of timer, maximum wattage for both 1000Watts
50-mini-bulb string of Christmas lights is 25 Watts
Plug timer into 125 Volt GFCI protected outlet.
Do not plug timer into extension cord.
Indicator light shows when timer has power.
Timer turns ON automatically at dusk.
Plug lights, small pump, fountain, motor into grounded outlet located bottom of timer.
Rotate dial to choose timer function.
Rotate dial to select timer function
- ON at dusk & OFF 2, 4, 6, 8 hours later - Rotated dial to number shown on dial
- ON at dusk, OFF at dawn - Rotate dial to dusk-dial
- ON continuously - Rotate dial to ON
-OFF - Rotate dial to OFF
Dec 03, 2010 | Jasco Ge 8HR Mechanical Blk Timer 2 Outlet...
How to forward calls to another extension with panasonic kx-t7630
From the intercom dial *710x ext and # where X is 2/3/4/5 for All,Busy,No Answer,Busy/No Answer. There are some other conditions and Do Not Disturb in the dialing string (and 0 cancels) but that's the basic.
You might want to review the Operations Manual (OM) under Call Forwarding to see the complete instructions.
Carl
Sep 16, 2010 | Panasonic KX-T7630 Corded Phone
The string that controls the volume pot has broken
Replace the string. Possible sources are "dial cord" used in older radios to move the dial pointer... Find it online.
Another source might be braided fishing line.
Aug 31, 2010 | Ernie Ball 6166 Mono Volume Pedal
I have a Rheem model 111250 - Can I Control Tempurature?
Remove the cover where the power cord connects (there are 2 screws on the lower side of the cover). There is a small black dial with numbers like 50, 55, 60, 65, 70. Just turn the dial to a new number.
Aug 15, 2009 | Rheem Gt199dvp Heavy Duty Tankless Water...
I have a Saalburg 5380 C 1964 radio. The tuning dial does not work. When i open the back and have a look it apears that the shaft from the tuning dial which controls the tuning capacitor(Trimmer) must be...
Hi
So you have a slipping dial pointer/tuner drive on your vintage radio. It will be old age catching up with it for sure:) The shaft may have dried grease in its bushings seizing slightly, or more likely, the dial drive cord has lost its "grip". They do stretch over the years. I recall as an apprentice having to do every faulty dial cord that came into the workshop, until we got a new apprentice that is :)
Best bet, BEFORE YOU START doing anything, even if the cord is broken, make a hand drawn diagram of exactly how the cord runs. You may be able to find one that matches up to your radio here, Short of that(as well as), take closeup photos from several angles.
Once you are confident you have an understandable diagram of how it is strung, you can proceed to mess with it.
I have to be honest, completely replacing the cord is what I found to be the quickest/most reliable way to repair them, but then I had plenty of practice in the end. If you don't have the correct type of dial cord string, then repairs can be a fiddly, but effective option to attempt.
First you need to determine if the cord is failing/stretched, or if there is a stiff bearing point. This takes a bit of hands on approach to determine. put some additional tension into the cord by pressing down on it and see if the drive improves. If it does, then you may be able to apply more tension into the drive by shortening it a little. Do this by carefully unhooking one of the retaining springs that secure an end, without removing the chord from the spring, retie the another loop knot(as many as you need to before there is no more room to do so) onto the spring to use up some cord shortening it. Apply a dab of nail varnish to any knot once secure to be sure that it does not come undone. You can just cut the knot away and retie if you wish also, just fiddly with the limited amount of string you have to work with. It often does not take much to re-tension it. Sometimes it may be as easy as fitting the spring to another tighter hook point on the large pulley(if you are lucky) This can be about the time when you are thankful you made a diagram of the way the cord is strung,as things can get messy.
If it appears that the tuning gang is seized, then a drop of penetrating oil to the bush will help it. Work it back and forwards a little to work the oil in. The large pulley attached to the tuning gang can be removed here also if you wish to work on the gang. use some tape to secure the string in place to the pulley and it can generally be removed from the gang and secured back onto the chassis somewhere, whilst keeping tension on the string. Check also the free running of any brass pulleys along the drive. It is imperative that you don't get any oil onto the cord itself or the drive surfaces of the pulleys. ... or you will need to replace the whole thing. A syringe is the best applicator of oil for these jobs. Lubricate sparingly and as a last resort only.
Worst case, you may need to completely restring the drive anyways. I did suggest that at the start.
Good luck with your dial drive repair. If you need new cord, it can be purchased from a vintage radio restorer online or just take it to a vintage repair shop in someones back shed in your neighborhood :)
regards
robotek
Nov 05, 2008 | Audio Players & Recorders
Pause in dialing
hit the # (pause) 2 times. it will change to a P. I had to put 2 pauses in my string
Apr 22, 2008 | RCA 25202RE3 Corded Phone
I have 1 1959 zenith stereo and the tuner needs repaired, i have it apart. and there is a broken string on the end of a small metal spring, how do i put it on the tuner. i can turn the tuner wheel by hand,...
1......Use new dial cord, old dial cord becomes brittle and glazed over the years.
2....the tuning knob shaft should have 2 or 3 turns of the dial cord wrapped around it.
3....the tuning knob shaft should be clean.
4...if there are any small pulleys that the dial cord rides on for smooth operation, they should be clean and free turning.
The biggest things ( as you might have guessed ) are that everything that has the dial cord running over it should be clean and free to turn if necessary.
The little spring is there to keep tension on the cord, otherwise it would loosen once it streches with age.
If you need dial cord, I believe Sony still has some. You may need to contact the Sony parts distributor for your country, but I firmly believe that it is still available.
Good luck......Rob
Mar 04, 2008 | Audio Players & Recorders
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Aug 27, 2007 | GE Corded Speakerphone with 2 Cordless...
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
