Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Incoming faxes Only prints 1 out 10-15 sheets sucesfull, the others are just the header or half of the fax then goes blank. It prints a bleap at the top then blank the rest of the sheet but its different for how much it prints for every sheet.
    Novelist:
  • 106 Answers
I just want to know also if you have a problem in printing, scanning or copying. If so, it might be an issue with ink cartridges. However i would like you to follow these steps. Just click the word "SOLUTION" below.
CLICK HERE==>> SOLUTION
Please, let me know if the issue is still not resolve, so that i can go ahead and give you another possible solution for that.
Thank you so much.
adonscott
Posted on Jul 05, 2008
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
When i receive a fax everything is perfect,when i send a fax it reaches the destination where im sending it as a blank sheet of paper
If you are able to receive fax and it is printed out fine, there is nothing wrong with your printer. If the other person is receiving blank fax, you may be placing the documents to fax in opposite way, If you are placing the paper upside ( with text ), try to face it down and fax. It should work.
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 03, 2011 | Lexmark X6170 All-In-One InkJet Printer
I have a lexmark all-in-one printer, model # x4270, when I fax someone, when received, the fax is a blank sheet of paper?
try and make a copy with the fax... if it comes out the same way... turn the paper face up if it was face down or vice versa and try again... if it works then fax the same way and see what happens... if all goes well then keep copying and faxing that way... if that works but fax does not work... print an internal report... if that does not print then you have main board problems... if internal prints print then you have a problem with your ccd... thats a big long strip that rests right under the keyboard... thats what does the scanning... if that is bad... then when you fax... or copy it will be blank or black... depending on what is blown on it...
Dec 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
Printing blank pages when receiving fax
Ask if the ones sending are sending legal size, it may be using 2 sheets to get all from a legal size document.
Jul 29, 2009 | Brother MFC-8460N All-In-One Printer
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Confirmation
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Oct 14, 2008 | HP LaserJet 3055 All-In-One Printer
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Always feeds a second sheet
You may need to repalce your pick-up roller and your stop roller
Mar 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Fax Confirmation Sheet
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
91 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
