Question about HP PSC 2410 All-In-One InkJet Printer
Cannot get the printer to work after installed a new black cartridge
I got the message: "Press OK to print align page". Tried many options but cannot get rid of the message.
Thanks for yourhelp,
George
    Scholar:
  • 130 Answers
Download the software fron the internet use the softeware to aling the printer
Posted on Jul 04, 2008
I have Lexmark X125 and get message "Check Cartride" I put a new Black Cartride in and get message " None Changed" Printer won't print. What can I do?
What is the black cartridge version that you are using on your Lexmark X125 printer? If you are inserting a photo cartridge on your printer, please follow these steps: 1. Remove the black cartridge and insert the photo cartridge. The printer LCD screen will display CARTRIDGE? NONE CHANGED. 2. Press the Options button to select NEW RIGHT and then press Start. The printer LCD screen will now display RIGHT CARTRIDGE? 3. Use the Options button to select the STD PHOTO cartridge type and click Start. An Alignment page will then print. When the Alignment page is fully printed, the LCD screen will display CARTRIDGE ALIGN. 15 [00-30] A , where - 15 represents the straightest line on the page; - [00-30] is the value range you can select from, between 00 and 30 - A represents the line in each section. 4. Use the numbers on the keypad to select the number of the line you think is the straightest. As you press the number, the LCD will change to the next line automatically. Select the number representing the straightest line in each section.
Source: How to Install the Photo Cartridge in Standalone Mode
May 10, 2011 | Lexmark X125 All-In-One InkJet Printer
Installed a new HP black ink cartridge; the officejet 8500 pro will not print any black print. The color ink works okay.
First print a self test page on the printer and check if you have black print on it or not.
To do that Go to your printer :-
Press Setup button -->Go to print report-->hit ok--> use arrow keys and choose the self test page.--> hit ok.
If you have the self test page fine then try to make a black copy from the printer.
Put a black font printout on the scanner glass facing downwards. Press copy black
Check if you have the black ink working.
If yess then there is some thing on the system you are doing wrong. May be the printer properties needs to be set or some settings needs to be checked.
If no then try to clean he ink cartridge and try to align the cartridge on the printer.
To align Do this
Press setup-->use arror keys to navigate to tools -->and choose the option align cartridge or align printer.
If you do not find the option in the tools option try looking for it in the print report...
On the computer Go to printer under control panel and right click on the printer and go to print prefernces --> go to the TAB called colors and under color options -->choose print in greyscale--> and under that choose the Black only option. --> hit apply and then hit ok.
Now try printing..!
Let me know if any of these steps works....
May 12, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
What ink cartridges does a canon mp520 take? currently using 5 PGBK black, have been told I can use 8 black, but don't know how to install it
Your printer uses 4 cartridges: PGI-5 Black and CLI-8 (Cyan/Magenta/Yellow). Unless you have a slot for a fifth cartridge, CLI-8BK cannot be used in your printer.
As for installing new cartridges:
  1. Turn your printer on.Open the printer's lid. The printer will automatically move the ink cartridges to the center of the opening.
  2. Unplug the printer's power supply cord from the electrical outlet to avoid the risk of an electrical shock.
  3. Remove the printer cartridges by first pressing down on the top of each cartridge housing. Pressing down on the cartridge housings will cause the top of each housing to automatically lift up, thereby exposing the cartridges. Lift the cartridges out of each cartridge housing to remove them.
  4. Install the replacement ink cartridges by first removing the orange safety tape located on either the top or the bottom of each cartridge, depending on the particular type of cartridge. The safety tape ensures that the cartridges do not leak ink before being installed. To remove the tape, simply pull the orange tab on the end of each piece of tape away from each cartridge. Position each cartridge into its cartridge housing so that the printed words on top of the each cartridge faces towards the front of the printer, then close the tops of the cartridge housings.
  5. Plug the printer's power cord into an electrical outlet, then close the access panel by pressing down on the panel.
  6. Turn the printer on and allow the printer a few minutes to recognize the new cartridges, then insert at least three pieces of paper into the paper tray, which the printer will require to align the cartridges.
  7. Align the new cartridges by selecting either the "Clean and Align" or the "Cartridge Alignment" option, depending on the particular printer model. Some Canon models require the user to align the cartridges through the printer's software program. Select the "Print Properties" option in the printer's program, then select the "Clean and Align" option. The printer will produce several printed pages to confirm that the cartridges have been aligned. Other Canon models allow the user to align the cartridges directly from the printer. These printers features a display screen on the printer. Press the "Menu" button on the display, then use the arrow keys to select "Settings." Press the "OK" button, then use the arrow keys to highlight "Maintenance." Press the "OK" button, then use the arrow keys to highlight "Manual Head Align." Press the "OK" button, then use the arrow keys to highlight "Yes." Press the "OK" button one final time, then allow the printer to produce the printed pages confirming that the cartridges have been aligned.
Apr 07, 2010 | Canon PIXMA MP520 InkJet Printer
Cartridge alignment
Put a teeny tiny bit of oil (3 in one on fingertip) all over the slide (chrome bar that you see looking into the printer from the front) and retry. Just a thin film, NOT enough to drip.
The self test and align 'scan and print' procedure is timing out.
Mar 27, 2009 | HP PSC 2175 All-In-One InkJet Printer
Error message after replacing the black cartridge
You must replace both ink carts to get an alignment.
Dec 29, 2008 | HP PSC 2210 All-In-One InkJet Printer
I have replaced both my color and black cartrigages for my x2500 printer, restarted the computer, and it is still giving me an empty cartrigage message
is this a pc or mac?
for windows general make sure you folowed these steps:
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Dec 01, 2008 | Lexmark Office Equipment & Supplies
Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
WILL NOT ALIGN-
The following error message appears on the LCD panel1.gif on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected.
Feb 13, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer will not copy
It Does keep asking if it fails to get it right, usually it fails to get scan of alignment page completed correctly because it fails to see one of the colours printed on its alignment page correctly,
I would guess that you should change colour cartridge as well (these I have seen deplete themselves trying print black when black ink is not present.
There is also a way of telling your printer to forget about alignment would you like to know how......Press and hold the Setup button, and then press Options (or Copy Options ).
Here is a link to how an alignment page should look and HP answers to your problem, please rate my solution for me.
Nov 21, 2007 | HP PSC 2175 All-In-One InkJet Printer
Ink cartridge alignment problem
well, what i did, and it seemed to work, in the short run anyway. i took and threw my hp in the back of a waste management truck,  then i called amazon.com and i ordered a new epson printer,
Oct 26, 2007 | HP PhotoSmart C4180 All-in-One Color...
HP PSC 2410 All-In-One InkJet Printer Logo
44 people viewed this question
Seeker5211
Seeker5211
