Question about HP Deskjet 6940 InkJet Printer
Cartridge errors on HP97 / bad TSR?
Hello Bob-
I hope you don't mind me directly asking you a question regarding strange behavior on several HP 9- series cartridges I have here at work. I've noticed you have extensive HP experience in printers and I am actually ex-HP as well.
We have several printers: Deskjet 5740, Officejet 7310, Deskjet 6940. I have 3 cartridges (one each 93, 95, 97) that are not accepted by any of these printers- the cartridge light flashes immediately on insertion and when I run the 10-tap it gives stat=8. The specific error and message I have found under the system events section is 69961 "pen in chute 0 has t", which I believe means a TSR failure? Here is the kicker- all 3 cartridges seem to have good TSR's, as measured by my trusty multimeter (in the 70-72 ohm range, like others I have around that are working fine). I also have ruled out printer contact issues as these printers accept many other cartridges well, have had their contacts cleaned, and the cartridge errors are very repeatable only on these particular cartridges. Are you aware of any other reason we could be getting this error message?
Also, if there is a print job in the queue and I run a tap test, the print job then successfully prints with good print quality, so there doesn't seem to be a major electrical issue with these cartridges.
Thanks in advance for your advice!
    Scholar:
  • 137 Answers
Hi Scott -
Sorry, I do not have any additional ideas as it seems you have checked things I would have suggested - cleaning the contacts. (I presume you did clean the cartrdige contacts in addition to the printer contacts.) The TSR may be correct but may be encoded incorrectly, which could cause an issue as this would make the printer "think" the cartridge was too hot or too cold. The printer will refuse to print with certain ID errors. A 10-tap will bypass this test as a diagnostic aid. Does the 10-tap show a "good" nozzle diagnostic? If there are repeating missing nozzle segments across all three colors it would indicate an interconnect issue.
If the cartridges are original HP cartridges I would check the warranty date (two years warranty from date of manufacture) as shown here. If the cartridges are still in the warranty period contact HP for replacements.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Posted on Jul 03, 2008
How do I reset a re-filled HP97 tri-color printer cartridge for an HP 7310 all-in-one printer. I have re-filled the cartridge at walgreens, re-installed the re-filled cartridge, but the diagnostic still...
if it continues to show "empty cartridge" that means. the printer is not accepting the refilled cartridges..
You will have to try with a new genuine HP ink cartridge.
Oct 13, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Hello, despite my HP2840 Q3960A black cartridge is new, he tells me to replace it counts as printed pages at 5% coverage but at 100%. After several attempts to remove the chip and its re-enter again gives...
There may be a defect in the toner cartridge causing the odd behavior. You can try resetting the printer settings to factory default or upgrading the firmware. You can reset the settings through the printer's menu. The link below should allow you to download the latest firmware and it should provide instructions for performing the update.
HP Color LaserJet 2840 All in One Printer
Jul 16, 2010 | HP LaserJet 2840 Printer
Pen in chute 1 has tsr failure.
Your black ink cartridge is bad.
Pen = ink cartridge
chute 0 = color cartridge holder
chute 1 = black cartridge holder
tsr = Themal sensor resistor
Jun 18, 2010 | HP Photosmart C4180 All-In-One InkJet...
Screen showing the message "remove and check right cartridge". Have done this several times and still can't print
I've had the same error:
Hold down the following keys:
Photosmart Express, Photo Fix, Reprints, Print Photos and then Help.
You'll get the message: "Enter Special Key Combo"
Press OK.
Scroll over to Reports then self test: and press ok, it should print. a selftest report.
If you get an error Pen in Chute 1, or 2, has tsr failure: Call/Chat with an HP technician.
Jan 19, 2010 | HP Photosmart C4180 All-In-One InkJet...
Hp6940 ink and printing problems
you may have a bad print cartridge or it has gone bad...
Dec 21, 2009 | HP Deskjet 6940 InkJet Printer
Printer slow after putting in a refilled cartridge
Sounds like the TSR is out on your cartridge. The TSR is the heat sensor for your print head. If the TSR goes out it cannot tell the printer that the temp at the print head is at ok levels. So the printer assumes the print head is really hot and at risk of fusing its nozzles so it prints really slow (the faster the printing the hotter the print head gets). It is possible, but not very likely, that the ink in the cartridge is of such low quality that it is not cooling the print head properly as it flows through the nozzles. Thus the TSR tells the printer to print really slow so you don't burn up nozzles. If you got this cartridge refilled at a store or on-line I would return it and get your money back. I recommend Cartridge World for refills because if this happens to one of their refills they will give you a new refill at no charge.
Oct 15, 2009 | HP PSC 1610v All-in-One Printer
Cartridge erro
HP's troubleshooting guide for this error is available here and has several causes for the cartridge light blinking, including an open door, a cartridge not properly seated, tape left on the cartridge or a defective cartridge. See the guide for troubleshooting steps.
If troubleshooting indicates the cartridge is defective try cleaning the cartridge contacts as shown here. (This is for a different series of cartridge but the same principle in cleaning applies).
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Aug 14, 2008 | Office Equipment & Supplies
Wrong cartridge error have beenusing for over a wk hp psc 950
This can occur if the printer misreads the electrical ID of the cartridges. You may be able to cure the issue by cleaning the cartridge contacts as shown here.
It is also possible the cartridge has failed electrically. In this case check the warranty information here if it is an HP original cartridge or contact your dealer for warranty information.
Also make sure you are using a #15 black and #78 color cartridge, other cartridges that look similar such as the #23, #17 or #41 color or #45 black are not compatible.
Regards,
Bob Headrick, Micrisoft MVP Printing/Imaging
Jun 09, 2008 | Office Equipment & Supplies
Ask about HP cartridge for HP AIO 7310
Your problem is language and diffrent countries my friend. USA has there cartridges and other countries has theres. The data from the cartridge is language specific. So your American printer can not understand your Denmark cartridge. Also I am guessing there is a diffrence in the size of the cartridges. Therefore rendering your Denmark cartridges useless for your American Hewitt Packard printer.
Aug 19, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP Deskjet 6940 InkJet Printer Logo
1,386 people viewed this question
Ben Johnson
