Question about Kyocera Office Equipment & Supplies
I have a mita dc1255 copier. When coping the copies come out dark with horizontal lines. Any idea what the problem could be.
  • 148 Answers
One, it might be the optics in the machine are dirty, two the cleaning blade for the drum may need replacing.
Hope that helps...
Lbcoaster
Posted on Jul 02, 2008
What happened when my Kyocera Mita KM5035 Copier is unable to copy after refilling the toner?
there are many reasons for this .first make sure you installed the toner container very well. second type 1087 twice to service menue then type 30 to chick motors then exit and type 130 to adjust toner mode when the machine stop turne it off-on
Nov 19, 2015 | Kyocera Mita KM-5035 Printer
I experienced horizontal white lines copy on my fs1135 mfp could anyone had an idea? . pls. help me with this experts
This normally means you have issues with your laser or developer. I would try changing developer first.
Feb 03, 2015 | Kyocera Mita FS1135MFP Black Toner...
Dirty and light copy of my Kyucera KM 1505 copier machine
Clean the optical parts (lens,mirrors),and the poligon motor mirrors.
Apr 08, 2013 | Kyocera Mita Office Equipment & Supplies
Getting a dark line on the copy pages. Need a new
Mite be a problem with your doc feeder. Are you using a doc feeder? If so raise up the doc feeder and place an orgnial on the big glass instead of feeding the orginal thur the docfeeder. Does the line disappear? If it does then the **** glass the small glass used by the docfeeder has a mark on it or dirt. Is your machine a printer also? Does the print have the mark/line on them also. Do any of your machine's internal reports have line on them Meter Read print outs etc.
Apr 25, 2010 | Kyocera Mita Office Equipment & Supplies
Dark horizontal lines appear across copies
This is usually caused by a dirty main charger grid, try cleaning it per the instructions in your operators guide. If you don't have the guide you may be able to download one from the Minolta Website at
http://kmbs.konicaminolta.us/content/support/supporthome.html
Sep 04, 2009 | Minolta Di151 All-In-One Laser Printer
Degradation of copies produced by Mita ai3010 copier
Please put the copier machine in the horizontally,and check the developer level in the developer station.Check the magnetic roller.If the copy degrade in the normal size (paper is positionly normal) the problem is in the optics section.In this case remove the mirror obturation plates,alligniament,clean the expo lamp.If the copy is degrade in the RS tray you need the check the developer unit,change and alligniament the doctor blade value (0,35mm) and change the drum collars.
Aug 18, 2009 | Kyocera Mita Office Equipment & Supplies
Mita DC-1860 horizontal streaks after new drum
You say 'horizontal", but I imagine your paper is actually travelling 'laterally' or or sideways through the machine right? That means that the lines are actually running vertically based on the paper direction.
Is that 2" wide line visible on your drum?
Drum cleaning blade has likely failed....it should ALWAYS be replaced with a new drum.
Feb 25, 2009 | Office Equipment & Supplies
Mita cs-2114 copier with flashing "replace unit" light
after you see "---" within 2second press"stop/clear" again thenyouwill see"00" show out then enter 60 press print
Dec 09, 2008 | Office Equipment & Supplies
Dark horizontal line on canon np6050 copy
Did you try to run the wire cleaning funcation in the add. funcation mode? It could be that a wire cleaner got stuck in that spot and if you Run Wire Clean it may move it bake to Home Position and out of the way... Good Luck
Sep 19, 2008 | Canon NP 6050 Copier
Mita dc 1560 prints are dark
nadark_1@yahoo.com
replace the Drum and the blade
Jul 14, 2008 | Kyocera KM-1505 Copier
149 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
