Question about Pentax Optio 330GS Digital Camera
Card not formated
During switch on I get this message: this card is not formated ! with all means I am unable to format any card or even the old flash card nor picture taking possible.
Battery full.
Is the only way to trough away? Or is there a Service Centre somewhere.
  • Dbrink3433 Oct 22, 2008
    every time we turnon the camera it says card not formated. Is there a fix to this and how????
  • Tim Babcock
    Tim Babcock May 11, 2010
    What size memory card are you using?
Thank you so much for your replay, I'm using the Original flash card 64 MB. after this error I tried a 512 MB flash card with the same result. I was thinking that if the capacity is high and beond the cam capacity formating at a lower capacity will be done but failed.
I really appreciate your kind support
Thank you very much
Martin
Posted on Jul 13, 2008
Memory card formatting
Hi
how to want to format you Memory card through Mobile and through computer. the both way i describe you let chose which one you look easy.
Through Mobile.
Switch off the mobile and Insert your memory card in mobile.
Step 1.
Press the white menu button.
Step 2.
Select "Applications".
Step 3.
Select "File mgr.".
Step 4.
Double-click on "E: Memory Card".
Step 5.
Select "Options".
Step 6.
Select "Memory Card Options" and then "Format".
Through -PC
Formatting your memory card, flash drive or device:
1. Double-click My Computer, or Computer (for Vista)
2. Right-click the drive letter associated with your memory card, flash drive or device, then select Format
(in the sample image below, we right-clicked on H:)
WARNING: Make sure you select the correct drive letter.
3. Select a File system type.
NOTE: Select FAT32 for 4GB or higher capacities. FAT for 2GB or lower capacities
4. Click Start.
Memory card info and old cameras
Many previous old cameras and portable devices do not work if the card is formatted as FAT32 or NTFS file system. One of the following errors may occur if your device does not support FAT32 or NTFS:
- Error message asking to re-format the flash card.
- Error message that the flash card is not formatted.
- Error message indicating that the card is anomalous.
To resolve the above error, backup your data and reformat your memory card in FAT file system.
If the error persists, re-format the memory card using your camera or portable device.
Aug 02, 2011 | SanDisk 1GB microSD Memory Card
Formating problem
i cannot access my 2GB micro sd card in computer or phone, when i opened it from computer i get message card need to be formated but when i start to format card windows says unable to format this device. please help me.
from kapil sharma
Oct 30, 2010 | SanDisk 2GB microSD Memory Card
Unable to format the 2GB Memory card. Message occurs : Windows unable to complete the format.
A hidden application is disrupting your format process download "unlocker" software application from google, install it then right click on the memory card icon you find unlocker option double click n press unlock all after this try formating your memory card will work fine
Sep 20, 2010 | SanDisk 2GB microSD Memory Card
Sandisk micro sd card forget password in nokia
Try putting the memory card in your PC and formatting it from My Computer.
If you have a camera that takes this kind of card, you can try to format the memory card from there as well.
Jan 26, 2010 | SanDisk 2GB microSD Memory Card
Card can not be formatted
There is a write protect switch on the side of the card. That may be the reason why the comp is unable to use it.
Jun 05, 2009 | SanDisk 4GB Secure Digital High Capacity...
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
The camera screen displays a "Memory card requires formatting" error message. What should I do?
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
The camera screen displays error message
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Pentax Optio 330GS Digital Camera Logo
110 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
