Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Primary slave drive fails(black screen)
What does that mean
  • brownekoffe Jul 02, 2008
    my computer has a an error message diskboot failure insert system disk press enter but dont have a disk for booting but can get into the bios screen what do ido next to get my computer working
  • Dave May 11, 2010
    This appears to be a warning generated by the PC BIOS. Are you able to continue booting to XP?
The major problem is that it is telling me diskboot failure insert system disk press enter
Posted on Jul 02, 2008
Operating system not found
hi goodner,
getting the error "operating system not found" means that the hard drive where the Operating System is installed (i.e. Windows XP, Windows Vista, Windows 7), Cannot be found by you BIOS upon the boot sequence.
When you turn the PC/Laptop, you normal see a screen that flashes flashes with screen that displays the ff:
Primary Master:
Primary Slave:
Secondary Master:
Secondary Slave:
The Primary master should have a value right next to it. If not, either the hard drive is faulty and needs replacement, cable is loose,
If you have a value to it and stil gets the same error the operating is corrupted and needs to be re-installed.
Jan 29, 2013 | Computers & Internet
How do I go into bios to make my primary 1 hard drive found
During the boot process you will see on the screen to press a certain key to enter setup usually the delete or f2 key this will vary depending on your operating system and computer
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Hope this helps.
Nov 25, 2012 | Computers & Internet
Go into the BIOS and make sure you are trying to boot from the Primary Master Drive first. If not, move the Master Drive to the 1st boot position.
If the above fails, you could just remove the power cord, remove the case and notice how the two drives are connected and remember it. There will be one cable that provides power to the drive from the power supply on each drive. Also, there might be one cable that connects both drive, or there might be one in each drive, etc. I would disconnect the power and cable on one of the drives and try rebooting. If it fails and you have one cable that connects both drives, try the other cable connection and reboot. If it still fails, then I would try doing the same thing with the other drive.
If all the above fails and your system has the IDE (whereas the cable has about a 2 inch end with about 20 holes that plug into the 20 pins on the hard drive) interface, remove the drive to check and see if the little pin on there along is set to Primary, Master or Cable Select. Normally on a two drive system they will be set to CS for Cable Select and the IDE Cable based on how it is plugged into the drives determines which is Master and Slave, but older systems might have the Master and Slave setup.
Apr 09, 2012 | Sony VAIO Digital Studio PCV-RS410 PC...
How to connect the primary and secondary drives
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
Hope this helps you
Apr 05, 2012 | E-Machines etower 633ids PC Desktop
Im getting this message primary slave hard disk error the model is WD3200AAjs
Most (older) motherboards have two "channels" for devices (CD, disk-drives, ZIP drives, LS-120 drives).
Each channel supports two devices: one "master" device and one "slave" device.
Check the "primary" channel, not the "secondary" channel.
Check the "slave" device, not the "master" device, on the "primary" channel.
The device either has failed, or is announcing that it soon will fail.
Feb 28, 2011 | Computers & Internet
When i installed hard drive and set the jumper on primary master it dint show up and in bios the txt is showing like that primary master drive 0 (not installed)
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test or replace all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard)) drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
? single or master :::::
???????????????? slave? :::':
Feb 06, 2011 | Seagate Barracuda 7200.7 40 GB Hard Drive
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
320gb sata11 is not seen by bios
I have you tired using a different SATA connector or even SATA power connector, try and see if this helps...
Jun 12, 2009 | Computers & Internet
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Feb 26, 2009 | Computers & Internet
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
27 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
